Turn on/off LED using voltage range as a criteria
Hello,
I am trying to cut off charging for a battery when the voltage reaches 13.8V and as well turn on a green Led to indicate battery is full. similarly, i want the same for the low voltage cutoff; That means when voltage gets to 10V and below, it triggers a relay that disconnects the load from it. I modified a sketch from the lessons i got from Dronebot on the use of voltage sensor and my code is not working whether on proteus or on ground. kindly assist.
// Define analog input
#define ANALOG_IN_PIN A0
// Floats for ADC voltage & Input voltage
float adc_voltage = 0.0;
float in_voltage = 0.0;
// Floats for resistor values in divider (in ohms)
float R1 = 30000.0;
float R2 = 7500.0;
// Float for Reference Voltage
float ref_voltage = 5.0;
// Integer for ADC value
int adc_value = 0;
// other parameters for battery control and user interfaces
int redled = 13;
int greenled = 12;
int blueled = 8;
int cutoffhigh = 7;
int cutofflow = 4;
void setup(){
// Setup Serial Monitor
Serial.println("DC Voltage Test");
pinMode(redled, OUTPUT);
pinMode(greenled, OUTPUT);
pinMode(blueled, OUTPUT);
pinMode(cutoffhigh, OUTPUT);
pinMode(cutofflow, OUTPUT);
void loop(){
// Read the Analog Input
adc_value = analogRead(ANALOG_IN_PIN);
// Determine voltage at ADC input
adc_voltage = (adc_value * ref_voltage) / 1024.0;
// Calculate voltage at divider input
in_voltage = adc_voltage / (R2/(R1+R2));
// Print results to Serial Monitor to 2 decimal places
Serial.print("Input Voltage = ");
Serial.println(in_voltage, 2);
// Short delay
if( in_voltage >=0.00 && in_voltage <=10.00){
digitalWrite(cutofflow, HIGH);
digitalWrite(cutoffhigh, LOW);
digitalWrite(redled, LOW);
digitalWrite(greenled, LOW);
digitalWrite(blueled, LOW);
else if(in_voltage >=10.10 && in_voltage <= 10.80){
digitalWrite(cutofflow, LOW);
digitalWrite(redled, HIGH);
else if( in_voltage >10.81 && in_voltage <= 12.29 ){
digitalWrite(blueled, HIGH);
else if (in_voltage >= 12.30 && in_voltage <= 12.49){
digitalWrite(greenled, HIGH);
else if (in_voltage >12.50 && in_voltage >=12.6){
digitalWrite(cutoffhigh, HIGH);
else {
Welcome to the forum
  if ( in_voltage & gt; = 0.00 & amp; & in_voltage & lt; = 10.00)
Where did you get the code ?
It appears to be full of HTML commands
I dont understand this. Could you help modify my code
Please start by explaining where you got the code as I assume that you did not write it. If you did write it then please explain what you think that line of code and other lines like
actually do
this is dronebots leson on interfacing voltage sensor with arduino for printing out dc voltages on the serial monitor. I modified it by adding output pins that represent different voltage levels with the aim of turning on/off leds or relays at those levels
You seem to have messed up the original code when you copied it. How did you copy it ?
Here is the first example
 Arduino DC Voltage Demo 1
  dc-voltage-demo.ino
  Use Arduino A/D converter to measure voltage
  Use external voltage divider with 30k & 7.5k resistors
  Results displayed on Serial Monitor
  DroneBot Workshop 2021
  https://dronebotworkshop.com
float R1 = 30000.0;
float R2 = 7500.0;
int adc_value = 0;
void setup(){
void loop(){
  // Short delay
Which of the examples did you start with ?
Is it even getting compiled?
Do you have an IDE available ?
