Turn on servo and LEDs in minutes and hours helpme
I try to start a servo the 15 minutes to 3:45 minutes, there are 3 pushbuttons,
The first of on and turned off.
The second with 3 leds that control minutes of 15 to 45 minutes.
And the last with another 3 LEDs in periods of 1 to 3 hours.
The problem is that the start on and off if it works, but when setting the minutes and hours, only the leds turn on and there is no signal on the servo.
If someone could tell me where my mistake, thanks
#include <Servo.h>
boolean sessionStarted = false;
int hours = 0;
int MAX_HOURS = 3;
int HOURS_START_PIN = 5;
int minutes = 0;
int MAX_MINUTES = 3;
int MINUTES_START_PIN = 2;
boolean readingHoursInProgress = false;
boolean readingMinutesInProgress = false;
boolean readingSessionBtnInProgress = false;
unsigned long endTime = 0;
unsigned long MINUTES_MULTIPLIER = 60000; // 1000 for seconds, 60000 for minutes
unsigned long HOURS_MULTIPLIER = MINUTES_MULTIPLIER * 60;
Servo servo;
  for (int pin = 2; pin <= 7; pin++) {
    pinMode(pin, OUTPUT);
  // SERVO
  servo.attach(9);
  servo.write(0);
  delay(250);
  if (!sessionStarted) {
    readMinutes();
    readHours();
    showCurrentTime();
    if (millis() > endTime) {
      finishSession();
  if (sessionStatusChanged()) {
      startSession();
      finishSession();
void finishSession() {
  servo.write(170);
  fleshLED();
  servo.write(0);
void startSession() {
  fleshLED();
  sessionStarted = true;
  endTime = minutes * 15 * MINUTES_MULTIPLIER;
  endTime += hours * HOURS_MULTIPLIER;
  endTime += millis();
void fleshLED() {
  for (int i = 0; i < 5; i++) {
      digitalWrite(pin, HIGH);
      digitalWrite(pin, LOW);
boolean sessionStatusChanged() {
  int sessionBtnInput = analogRead(A2);
  if (!readingSessionBtnInProgress) {
    if (sessionBtnInput > 1000) {
      readingSessionBtnInProgress = true;
    if (sessionBtnInput == 0) {
      // react only after user releases button (can be implemented everywhere)
      return true;
  return false;
void readMinutes() {
  int minInput = analogRead(A0);
  if (!readingMinutesInProgress) {
    if (minInput > 1000) {
      minutes++;
      if (minutes > MAX_MINUTES) {
        minutes = 0;
      readingMinutesInProgress = true;
    if (minInput == 0) {
void readHours() {
  int hrsInput = analogRead(A1);
  if (!readingHoursInProgress) {
    if (hrsInput > 1000) {
      hours++;
      if (hours > MAX_HOURS) {
        hours = 0;
      readingHoursInProgress = true;
    if (hrsInput == 0) {
void showCurrentTime() {
  // show minutes
  for (int pin = MINUTES_START_PIN; pin < MINUTES_START_PIN + MAX_MINUTES; pin++) {
    digitalWrite(pin, pin < MINUTES_START_PIN + minutes ? HIGH : LOW);
  // show hours
  for (int pin = HOURS_START_PIN; pin < HOURS_START_PIN + MAX_HOURS; pin++) {
    digitalWrite(pin, pin < HOURS_START_PIN + hours ? HIGH : LOW);
