Hello community,
I started using arduino this week and here I am a couple of late night sessions in, in need of someone more experienced looking over my code.
I'm trying to make the popular soil irrigation system.
The idea:
I want the system to
take a sensor reading
write the reading to an SD and seriell monitor
if the soil is dry -> turn on pump only as long as it's dry, then immediately turn off
repeat after interval
My problem:
I tried many different versions now but they always end in one of these two scenarios if the soil is dry:
the pump turns off immediately when the desired moisture is reached. However, the reading isn't printed beforehand (when it's still dry) but only after the moisture level is back to the desired level which makes the data look like the soil was never dry.
the moisture value is recorded properly. However, the pump doesn't stop until the next cycle, thus probably flooding everything.
Here is one of the codes, in this one it's scenario 1. I think it comes down to the while loop and the use of return. Without return, I'm flooding everything, but with it my data isn't logged probably, and I just can't figure out how to rewrite the code.
Moisture sensor is in A0, Relais in D2.
SD-Karte CS in D4, MOSI in D11, MISO in D12, SCK in D13.
// Feuchtigkeitssensor und Relais
#define Sensor A0 // Feuchtigkeitssensoranschluss Analog Pin A0
#define Relais 2 // Verbindung arduino zu Relais IN
int interval = 1; // in minutes
int Feuchtigkeit; // moisture
long ttimer;
long timer;
String runTime;
// getting SD card ready
#include <SD.h>
#define PIN_SPI_CS 4
File myFile;
pinMode(Relais, OUTPUT);
if (!SD.begin(PIN_SPI_CS)) {
Serial.println(F("SD-Karte nicht gefunden oder nicht lesbar!"));
while (1); // Ende
Serial.println(F("SD-Karte OK!"));
if (!SD.exists("arduino.txt")) {
Serial.println(F("Kein Logfile auf der SD. Erstellt arduino.txt..."));
myFile = SD.open("arduino.txt", FILE_WRITE);
myFile.close();
// Prüft erneut
if (SD.exists("arduino.txt"))
Serial.println(F("arduino.txt auf der SD-Karte gefunden."));
Serial.println(F("arduino.txt nicht gefunden,"));
runTime = millis() / 60000;
ttimer = millis();
if ((timer + interval * 60000) < ttimer) {
timer = millis();
hauptprogramm();
write_data();
void hauptprogramm() {
int Feuchtigkeit = analogRead(Sensor);
if (Feuchtigkeit > 350) {
Serial.println("Wasser marsch!");
while (Feuchtigkeit > 350) {
digitalWrite(Relais, HIGH);
Feuchtigkeit = analogRead(Sensor); //re-check
return;
else {
digitalWrite(Relais, LOW);
Serial.println("Feuchtigkeit ok");
void write_data() {
Serial.print(" (");
Serial.print(Feuchtigkeit);
Serial.print(" @ ");
Serial.print(runTime);
Serial.println(" min)");
if (myFile) {
myFile.print(" (");
myFile.print(Feuchtigkeit);
myFile.print(" @ ");
myFile.print(runTime);
myFile.println(" min)");
myFile.close();
else {
Serial.println("Fehler beim Datenschreiben.");
Not sure if this is related to your issue, but using future time stamps is a big no-no. You should emulate the BlinkWithoutDelay example to see how millis() timing should be performed.
You are determining the sensor value at multiple places in your code... by the time you get to the logging routine it will always be "not dry"... either because it was "not dry" to start with, or is was "dry" but you watered it in a previous step - hauptprogramm() .
Remove this statement from both write_data() and from hauptprogamm()
using while-loops is blocking. It means you stay inside the while-loop until the while-condition is no longer true.
If you want to do a second, third, fourth thing in parallel to the main activity in the while-loop you have to add code for this second, third, fourth thing inside the while-loop.
This is unconvenient.
There is another approach to realise a functionality without any blocking:
The basic principle is:
let do all looping - and if I say all I really really REALLY mean ALL looping do by function void loop().
If void loop() does all the looping executing code is conditional to:
flag-variables
if-conditions
switch-case-break;-statememets used in state-machines
Your code has only two modes of operation:
pumped switched on
pumped switched off
With only two modes of operation a state-machine is not nescessary.
As soon as your code has 3 or more modes of operation a state-machine is useful
So here is a modified version of yur code that does
check feuchtigkeit all the time because the code is non-blocking.
Function loop() is looping all the time very fast and
prints the message "Wasser marsch" only one time per switching on the pump
writes value of variable Feuchtigkeit only once per minute
prints the message "Feuchtigkeit OK" only one time per switching pump off
switches on/off the relais depending on the sensor-threshold beeing higher or lower than 350
// variables used with function millis() MUST be of type
// UNSIGNED long
unsigned long WriteDataTimer;
boolean MsgWasserMarschPrinted = false;
boolean MsgFeuchtigkeitOKPrinted = false;
String runTime;
#include <SD.h>
File myFile;
Serial.begin(115200); // make sure to change baudrate in the serial monitor too
if (!SD.begin(PIN_SPI_CS)) { // getting SD card ready
while (1); // Ende
if (!SD.exists("arduino.txt") ) {
myFile.close();
// Prüft erneut
WriteDataTimer = millis(); // initialise timer-variable with actual time
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
// read sensor ONCE at top of loop and use this value
// for everything until next iteration of function loop()
// check if one minute has passed by since last time the function was true
if ( TimePeriodIsOver(WriteDataTimer, 60000) ) {
// if one minute has REALLY passed by
write_data();
hauptprogramm();
if (!MsgWasserMarschPrinted) { // if not yet printed
MsgWasserMarschPrinted = true; // change flag to true (printed)
MsgFeuchtigkeitOKPrinted = false; // reset oposite flag
else {
if (!MsgFeuchtigkeitOKPrinted) { // if not yet printed
MsgFeuchtigkeitOKPrinted = true; // change flag to true (printed)
MsgWasserMarschPrinted = false; // reset opposite flag
void write_data() {
Serial.print(" (");
if (myFile) {
myFile.print(" (");
myFile.close();
else {
Thank you for the improvement suggestion & explanation @StefanL38
It's my first time coding and I basically just tried out all the control structures until I found the one that worked best ... I read about while blocking things in the code, but just couldn't figure out how to do everything in the loop function. Thanks again
aren't your measurements likely to always be the same, something just > 350?
and correct the problem pointed by @anon57585045, why not simply either just turn the water on or off every check interval if 1 minute rather than immediately checking to stop?
consider
// basic regulator
enum { Off = HIGH, On = LOW };
#define Period 10
#define Thresh 350
#define Margin 10
unsigned long msecLst;
void loop ()
unsigned long msec = millis ();
if ((msec - msecLst) > Period) {
msecLst = msec;
int val = analogRead (A0);
Serial.println (val);
if ((Thresh + Margin) < val)
digitalWrite (LED_BUILTIN, On);
else if ((Thresh - Margin) > val)
digitalWrite (LED_BUILTIN, Off);
void setup ()
Serial.begin (9600);
pinMode (LED_BUILTIN, Off);
