Turn signal for bicycle by Bluetooth
Hi, I'm not very good at English. I can Connecting 2 Arduinos by Bluetooth using a HC-05 and a HC-06. I need help My project turn signal LED for bicycle.
I need send Arduino to Arduino via Bluetooth HC-05(master) and HC-06(slave)
This my code ,need you more help code send Arduino to Arduino.
This code need use HC-05 and arduino
int led1 = 0;
int led2 = 1;
int led3 = 2;
int sw1 = 8; //turn left
int sw2 = 9; // turn right
int sw3 = 10; // middle signal
int val;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(sw1, INPUT);
pinMode(sw2, INPUT);
pinMode(sw3, INPUT);
val=digitalRead(sw1);
if(val==HIGH)
digitalWrite(led1, HIGH);
digitalWrite(led1,LOW);
val=digitalRead(sw2);
if(val==HIGH)
digitalWrite(led2, HIGH);
if(val==HIGH)
digitalWrite(led2,LOW);
val=digitalRead(sw3);
if(val==HIGH)
digitalWrite(led3, HIGH);
if(val==HIGH)
digitalWrite(led3,LOW);
and i need help make code for HC-06 recive
Please put your code in its own window as seen in other posts. This can be done by placing     [code]  and [/code]  around the code or use the </> icon. This makes it easier for others to read.
You can edit the original post to include the code tags.
How to use this forum
Please give a circuit of how it is connected so we can make sure the code agrees with connections.
Weedpharma
And, while you're at it... check the Placement of opening and closing braces {}.
