Turn your Uno into a VGA output device!
Hey @Nick Gammon How can i increase the font size from 8X8 to 8X12 ?
Please reply....
I suppose you would change the font definition:
byte screen_font [8] [256] PROGMEM = {
Go from 8 rows to 12 rows. Then you need to re-make the fonts from scratch. And change the part where it copies the font data to the screen to allow for sending 12 rows rather than 8.
VGA library - now with TV output
http://forum.arduino.cc/index.php?topic=150517.0
Gee thanks Nick!
Now I have quit procrastinating and repair my spare 19" Flatscreen.
I really want to try you project. I have a few interesting ideas and will soon have 4 Arduino UNO3 to work with.
I may end up offering a Shield on Ebay, supporting VGA and interfacing with 3 UNO3's. If I do, I'll send you one free.
Keep up the good work.
Thanks for the challenge.
Hey , just came across this Papilio VGA shield.
http://www.robotshop.com/productinfo.aspx?pc=RB-Spa-805&lang=en-US
Not bad, it's exactly the same, except on a nice little breakout board.
The code they link to looks nothing like mine, but the PCB looks like it might bring out the connections and the resistors nicely.
McHa:
I spent some time with your code (and description) and I could not get gotoXY work properly.
I'm sending data from other arduino and I wanted following:
CLRSCR
GOTOXY 5,5
print some text
Could you please point me to some good and working solution to that? Thx.
McHa
This is working for me:
 char gotoXY [] = { ESC, GOTOXY, 1, random(29) };
  sendString (gotoXY);
  sendString ("Hello");
I hope that helps. I'm feeling around in the dark myself!
Thanks for all this Nick. After many long nights of fumbling around in the dark — with several video and VGA out libraries — I finally go this working.
Despite it's simplicity, I'm hopeful that it will fit the bill — finish line placings display for a Pinewood Derby racetrack. I'll let you know if it all comes off!
Beardy241:
Sounds interesting.
Can you share your sketch finally?
Thnks.
@2leon76 — Still working on it — it's a bit of a mess!!
@Nick Gammon
There's been some pulling out of hair here! Over the last couple of months I've been working on the various sub-systems for my Pinewood Derby Car Race Control setup — and progressively, each part came good.
Last weekend, during the process of putting everything together, the whole lot fell apart. Disaster! After through-the-night troubleshooting I eventually got the project back on track - so to speak - apart from one nasty bug. Every time the text-sending Arduino issued a sendstring command the display placed a spurious character at the start of the string. It started out as a white on black bullet point.
Going back to your sample code eradicated the problem so I figured the problem was on the text sending end.
I began hacking at my code wildly — starting by commenting out everything that wasn't a Wire command. It worked! So I started uncommenting various categories of code - like servo commands, button code etc. E v e n t u a l l y … it came down to the button!!
I have one button to control the system — press it to start the race, press it again to reset everything for the next race. I wondered if it might be a conflict with the pin I was using. This is when I discovered that changing the pin changed the spurious character! Huh!?
After much head scratching, this is what it comes down to…
When I do this…
int buttonPin = 2;
void setup ()
  pinMode(buttonPin, INPUT);      /// race control button
  digitalWrite(buttonPin, HIGH);  /// internal pullup resistor
  Wire.begin ();
  TWBR = 4;   // fast .. fast .. I2C : 16000000 / (16 + 2 * 4) = 666666 Hz
}  // end of setup
I get spurious characters appearing at the start of every sendstring.
Removing the buttonPin variable…
// int buttonPin = 2;
void setup ()
  pinMode(2, INPUT);      /// race control button
  digitalWrite(2, HIGH);  /// internal pullup resistor
  Wire.begin ();
}  // end of setup
… everything plays nicely!
Yep. Assigning the button pin by number, rather than by variable, sorts everything out!
Has anyone else experienced this — or am I 'special'!? :stuck_out_tongue:
I'll take this opportunity to thank you again for the whole VGAout thing — it's brilliant (in a wonderfully retro way!)
kr Marcel
addendum to the above…
Now I apply the 'fix' to my project code rather than the basic test code the spurious bullets are back! This time black on white!
I'll let you know what happens.
Nick,
I tried your mono text driver and it works well, however I am trying to get the display to scale to 128x72, and although I have been able to get output, it does not look like the display will scale correctly on other displays.
Changing the line:
const int horizontalBytes = 20;  // 160 pixels wide
To:
const int horizontalBytes = 16;  // 128 pixels wide
...In the code you had posted decreases the number of bytes, but I think the issue is that there are 16 clock cycles per 8 pixels, and I would need to adjust that .
If I understand your formula correctly for timing it is:
125 * 20 * 8 = 20000 nS (20 uS).
...So to output 16 bytes it should be:
125 * 16* 8 = 16000 nS (16 uS).
It might be though that 120 is more ideal than 128, as it is an even unit of 480, and it would be better to target that output resolution, and use 4x wide "pixels" instead of 3x wide "pixels"?
I don't know if you can easily achieve that. The ratio of 16 clock cycles per 8 pixels is because the hardware clocks out SPI at CLK/2. If you changed that (eg. CLK/4) you would get 32 clock cycles per 8 pixels.
See further down the page on my forum for the colour version. That uses a tight loop to clock pixels, but I only got 60 pixels horizontally that way.
Nothing much further to report apart from my Pinewood Derby Car racetrack had its first outing last weekend and it worked pretty well!
As for the VGA output, it was good but every time my code issues a GoTo command it deposits a bullet point on the screen!
Has anyone else come across this?
I'm using seeeduino.And there's a compiling error in VGA_output that I can't figure out.
UBRR0 = 0;  // USART Baud Rate Register
VGA_output:302: error: 'UBRR0' was not declared in this scope
I really want to know how to solve it.Please give me a little help. :slight_smile:
I did post this as a separate post but no responses so far, so I'll cheekily tag it on here:
Anyone have any ideas on how feasible it would be to modify the VGA output code to synch to an existing component video signal to allow it to be used as a text overlay for RGB video???
Please don't hijack a thread about C++ coding and handling external variables with a question about VGA output.
newbee123:
Hi, i want to display the sms that receive from the arduino gsm modem together with mega2560 to the monitor via VGA output.....
which part do i need to modify the code so that the sms can be display on the monitor everytime the modem receive a message?
You would modify the "Video text sender" sketch on my page:
richardtheboffin:
I don't know. The timing is very critical in the existing sketch, sychronizing may or may not be achievable. I haven't tried it.
