Turning decision
Hi there. I'm building an obstacle avoiding robot, and it uses an ultrasonic sensor to tell where it's at and where to turn. When it detects it's close to something, it looks left and right then goes to the direction of the greatest distance. The problem is, only one wheel really turns when it is making a direction change. I can't find the error. If you can help it would be great. Keep in mind that it uses an H-bridge with two DC motors.
"#include <Servo.h>
Servo myservo;
int pos=0;
int trigPin=3;
int echoPin=2;
int leftmf=10;
int leftmb=11;
int rightmf=8;
int rightmb=11;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(13, OUTPUT);
pinMode(leftmf, OUTPUT);
pinMode(leftmb, OUTPUT);
pinMode(rightmf, OUTPUT);
pinMode(rightmb, OUTPUT);
digitalWrite(trigPin, LOW);
myservo.attach(4);
digitalWrite(rightmf, HIGH);
digitalWrite(rightmb, LOW);
digitalWrite(leftmf, HIGH);
digitalWrite(leftmb, LOW);
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH, 32760);
distance=(duration/2) / 29.1;
Serial.print(distance);
Serial.println("cm");
delay(100);
if (distance<20)
digitalWrite(rightmf, LOW);
digitalWrite(leftmf, LOW);
digitalWrite(13, HIGH);
for (pos=90; pos<180; pos+=1)
myservo.write(pos);
delay(5);
int leftdistance;
delayMicroseconds(15);
leftdistance=(duration/2) / 29.1;
Serial.print("left distance=");
Serial.println(leftdistance);
for (pos=180; pos>=1; pos-=1)
myservo.write(pos);
delay(5);
int rightdistance;
rightdistance=(duration/2) / 29.1;
Serial.print("right distance=");
Serial.println(rightdistance);
for(pos=0; pos<=90; pos+=1)
myservo.write(pos);
delay(5);
if (rightdistance>leftdistance);
digitalWrite(rightmb, HIGH);
delay(250);
digitalWrite(leftmb, HIGH);
digitalWrite(13, LOW);
delay(250);
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the "Code" icon above the posting area. It is the first icon, with the symbol: </>
How to use this forum
int leftmf=10;
int leftmb=11;
int rightmf=8;
int rightmb=11;
Two different declarations for pin 11. ??
"#include <Servo.h>
Doesn't the compiler complain about that double quote there?
Please remember to use code tags when posting code.
