Turning LED's on with button press
Currently using this code as a means to power on solenoids to hit various materials. One is a potentiometer and other two are 'manually' controlled.
I want to add 2 LEDs so that every time the buttons are pressed, they also light up. finding this harder than i suppose it should be? Moreover, is it possible to turn the potentiometer to a point where it turns off? Right now when turned all the way up it holds the solenoids which makes a loud noise if its 'on'
//potentiometer
int potentiometer = A0;
int potRead = 0;
int redLED = 7;
int isOn = 1;
long now = 0;
//button
byte led2 = 8;
byte button2 = 5;
//button2
byte led3 = 9;
byte button3 = 6;
// set the digital pin as output:
//potentiometer
  pinMode(redLED,OUTPUT);
  pinMode(potentiometer,INPUT);
  digitalWrite(redLED,HIGH);
// button
  pinMode (led2, OUTPUT); // pin to LED anode, LED cathode to resistor, resistor to Gnd
  pinMode (button2, INPUT_PULLUP); // button connects pin to Gnd when pressed
//button 2
pinMode (led3, OUTPUT); // pin to LED anode, LED cathode to resistor, resistor to Gnd
pinMode (button3, INPUT_PULLUP); // button connects pin to Gnd when pressed
} // end setup
// potentiometer.
   potRead = analogRead(potentiometer);
  if(millis() > now + potRead){
    digitalWrite(redLED,isOn);
    isOn = 1 - isOn;
    now = millis();
 //button1
 if (digitalRead(button2) == LOW) {
 digitalWrite (led2, HIGH);
 else {
 digitalWrite (led2, LOW);
 //button2
  //button1
 if (digitalRead(button3) == LOW) {
 digitalWrite (led3, HIGH);
 else {
 digitalWrite (led3, LOW);
} // end loop
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Give links to components. Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
the following code toggles the solenoid, redLED, every cycle set by the pot which has a value from 0-1023. at the slowest rate is toggles every ~1000 msec. maybe you should add some code so that it doesn't toggle the solenoid when the pot is set above or below some value
        isOn = 1 - isOn;
        now = millis();
led2 and led2 should turn on as long as the corresponding button are pressed (held)
Well I've looked at your code and I can't see anything about solenoids in there anywhere. And I'm puzzled by the idea that one of the solenoids is a potentiometer?
Steve
This is an incorrect use of millis() for a timing delay. It can cause timing errors due to integer overflow.
