I am trying to create a code that makes my car turn randomly left or right. I managed to create a code that can only make it go forward, I understand the concept of making the car turn by turning off one motor but I just can't seem to figure out how to make them randomly turn left or right.
This is my code currently:
#define drive 11 //sets pin 11 for first motor
#define fwd 10 //sets pin 10 for drive to go forward
#define bkw 9 //sets pin 9 for drive to go backward
#define drive2 6 //sets pin 6 for second motor
#define fwd2 5 //sets pin 5 for drive2 to go forward
#define bkw2 3 //sets pin 3 for drive2 to go backward
pinMode(drive, OUTPUT);
pinMode(fwd, OUTPUT);
pinMode(bkw, OUTPUT);
pinMode(drive2, OUTPUT);
pinMode(fwd2, OUTPUT);
pinMode(bkw2, OUTPUT);
//max speed for both motors
analogWrite(drive, 255);
analogWrite(drive2, 255);
digitalWrite(drive, HIGH); //turns on first motor
digitalWrite(drive2, HIGH); //turns on second motor
digitalWrite(fwd, HIGH); //makes drive go forward
digitalWrite(fwd2, HIGH); //makes drive2 go forward
digitalWrite(bkw, LOW); //stops the backward function
digitalWrite(bkw2, LOW); //stops the backward2 function
Note: I am using a L293D chip to control and I have DC motors from the simple Arduino Kit
Your two-wheel car has nine possible movements, so rather than "0 = left, 1 = right"... why not try using a switch(random):case to pick one of nine...
switch (random(9)) { // oops! should be 0 to 8... thank you @nolasca
case 0: forwardSkidLeft(); break;
case 1: reverseSkidRight(); break;
case 2: forwardSkidRight(); break;
case 3: reverseSkidLeft(); break;
case 4: rotateLeft(); break;
case 5: rotateRight(); break;
case 6: forward(); break;
case 7: reverse(); break;
case 8: allStop(); break;
Presumably you want the car to go straight most of the time.
Pick probabilities for each action, use a much larger random number, and have ranges of values cause specific behaviors.
This brings up memories of exploring the city. Flip two coins (these were ancient monetized trading devices), head/head = left, tail/tail = right, head/tail straight. No backwards. "T" no straight. "5-points" two rounds.
