Hi i am trying to write a code to turn on the growth light LED for 14 hours and then turn off for 10 hours. Can anyone please tell me how to do it ? also if possible, if there is any coding example for me to understand better it will be good
also the coding is to be integrated with my future PH level coding so I cannot use the delay() function to delay it for 14 hours
Hi thanks for your reply. the suggestion you given me works but i have a question, when i integrate the code into my future PH code how do I make sure that it wont clash
const int ledPin = 1 ;// the number of the LED pin
int ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 50400000; // interval at which to blink (milliseconds)
pinMode(1, OUTPUT);
if (currentMillis - previousMillis >= interval) {
// save the last time the LED blink
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(1, ledState);
Looks like the LED will be on for 14 hours and off for 14 hours.
50400000ms / 1000ms / 60s / 60m = 14 hours
It's the only timer used. You need to create another timer for 10 hours, do the digitalWrite(pin, HIGH) in the setup. In the loop use 10hr timer to write LOW(LED on for 10hrs then turned off) and use 14hr timer to write HIGH(LED off for 10hrs then turned on).
