Turning on LED immediately after Deep Sleep w/ ESP32-C3
Hey guys! I have a slight problem in my code such that my LED does not illuminate immediately after deep sleep. The wakeup reason is GPIO go low so that when a button is depressed, the esp will wake up. That same button is also supposed to turn the LED on which is why I have implemented a counter so that it can turn on on the first depress. However, what happens is that the depress wakes up the esp, but it needs an additional press/depress for the led to turn on. IS there a way I can make the led turn on at the same time as the esp waking up without using an additional button? Thanks for the help!
#include <Arduino.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include <Wire.h>
#include <Preferences.h>
const int buttonPin = 3;  // # for button pin for States/Interrupt
const int buttonPin2 = 2; // # for button pin for BLE
const int ledPin =  5;   // # for the Green LED pin
const int ledPin2 = 6;   // # for the Red LED pin
const int ledPin3 = 7;    // # for the Blue LED pin
// variables will change:
int buttonState = 0;
int lastButtonState = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int ledState = 0;
RTC_DATA_ATTR int counter = 0;
#define SERVICE_UUID        "f0e279fc-a979-4ffd-924c-59ced5392948"
#define CHARACTERISTIC_UUID "7f98738e-382d-43d9-b256-3cf8bd3120b7"
BLEServer *pServer = NULL;
BLEService *pService = NULL;
BLECharacteristic *pCharacteristic = NULL;
Preferences preferences;
bool deviceConnected = false;
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
      Serial.println("True");
      delay(3000);
      Serial.println("Going to Sleep");
      digitalWrite(ledPin3, LOW);  // Turn off LED
      esp_deep_sleep_start();  // Enter deep sleep mode
    void onDisconnect(BLEServer* pServer) {
      Serial.println("Disconnected!");
      Serial.println("Advertising...");
      pServer->startAdvertising();
class MyCallbacks: public BLECharacteristicCallbacks
  void onWrite(BLECharacteristic *pCharacteristic)
    std::string value = pCharacteristic->getValue();
    if (value.length() > 0)
      Serial.println("*********");
      Serial.print("New value: ");
      for (int i = 0; i < value.length(); i++)
        Serial.print(value[i]);
void setupBLEServer(void) {
  Serial.println("Starting BLE Server!");
  BLEDevice::init("Pirouette-IoT-Device");
  pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  pService = pServer->createService(SERVICE_UUID);
  pCharacteristic = pService->createCharacteristic(CHARACTERISTIC_UUID, BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_NOTIFY);
  pCharacteristic->setCallbacks(new MyCallbacks());
  pCharacteristic->setValue("device_state_0_stored");
  pService->start();
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(true);
  pAdvertising->setMinPreferred(0x06);  // functions that help with iPhone connections issue
  pAdvertising->setMinPreferred(0x12);
  pAdvertising->start();
void pairing(){
  digitalWrite(ledPin3, HIGH);
  setupBLEServer();
void print_wakeup_reason() {
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch (wakeup_reason) {
    case ESP_SLEEP_WAKEUP_EXT0:
      Serial.println("Wakeup caused by external signal using RTC_IO");
    case ESP_SLEEP_WAKEUP_EXT1:
      Serial.println("Wakeup caused by external signal using RTC_CNTL");
    case ESP_SLEEP_WAKEUP_TIMER:
      Serial.println("Wakeup caused by timer");
    case ESP_SLEEP_WAKEUP_TOUCHPAD:
      Serial.println("Wakeup caused by touchpad");
    case ESP_SLEEP_WAKEUP_ULP:
      Serial.println("Wakeup caused by ULP program");
    case ESP_SLEEP_WAKEUP_GPIO: //New wakeup reason <--
      Serial.println("Wakeup caused by a GPIO");
    default:
      Serial.printf("Wakeup was not caused by deep sleep: %d\n", wakeup_reason);
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(buttonPin2, INPUT_PULLUP);
  //Enable GPIO Wakeup from buttonPin
  //esp_deep_sleep_enable_gpio_wakeup(1 << buttonPin, ESP_GPIO_WAKEUP_GPIO_HIGH);
  esp_deep_sleep_enable_gpio_wakeup(1 << buttonPin, ESP_GPIO_WAKEUP_GPIO_LOW);
  gpio_set_direction((gpio_num_t)buttonPin, GPIO_MODE_INPUT);  // <<<=== Add this line
  //Set up preferences for led state
  preferences.begin("led-state", false);
  counter = preferences.getInt("counter", 0);
  preferences.putInt("counter", counter);
  preferences.end();
void loop(){
  // read the state of the BLE pushbutton
  buttonState2 = digitalRead(buttonPin2);
  if (lastButtonState2 == HIGH && buttonState2 == LOW) {
    Serial.println("The button is pressed");
    pairing();
  lastButtonState2 = buttonState2;
  //Wake-up ESP from deep sleep
  print_wakeup_reason();
  // read the state of the internal pushbutton:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (lastButtonState == HIGH && buttonState == LOW) {
      counter++;
      Serial.print("Number of button pushes:  ");
      Serial.println(counter);
      // if the current state is HIGH then the button went from off to on:
      ledState = !ledState;
    if(counter == 2){
        buttonState = lastButtonState;
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // sets the LED to the button's state
  if(counter == 1){
    digitalWrite(ledPin, ledState);
    if(pCharacteristic != NULL){
      pCharacteristic->setValue("device_state_1_ready"); //add code for device 1 state ready once buttonPin1 is pushed/released
      pCharacteristic->notify();
  if(counter == 3){
    digitalWrite(ledPin2, HIGH);
    digitalWrite(ledPin, LOW);
      pCharacteristic->setValue("device_state_3_locked"); //add code for device 1 state ready once buttonPin1 is pushed/released
  else if (counter >= 4){
    digitalWrite(ledPin2, LOW);
  delay(50);
Try this
//  *** wakeup! **
digitalWrite(ledPin3, HIGH); // Turn on LED
A detail, here
    counter++;
if buttonState != lastButtonState then for lastButtonState == HIGH it can only be buttonState == LOW, so it is enough to check the value of one of the two variables
  if (lastButtonState == HIGH) {  // or buttonState == LOW
    counter++;
Regards
Unfortunately, that did not work. But what did work is putting
digitalWrite(ledPin, HIGH);
in the actual wake-up reason
