I'm trying to use a momentary switch to turn off/on this rgb rainbow LED. It turns on fine with the switch but doesn't turn it off.
It turns itself off after what seems like one cycle through all the colours and i can't figure out why...any thoughts? Perhaps i'm going about it the wrong way. The LED is common annode, which is connected to pb2 on an attiny85. The cathodes are on pb0, pb1, and pb4. I'm basically trying to send pb2 alternately high and low to turn on/off the LED.
#include <ezButton.h>
const int BUTTON_PIN = 3; // footswitch connected to attiny (2)
const int PWR_PIN = 2; // relay connected to attiny (7)
int onTime = 10;
ezButton button(BUTTON_PIN); // create ezButton object that attach to pin 7;
// variables will change:
int PWRState = LOW; // the current state of relay
int lastButtonState; // the previous state of button
int currentButtonState; // the current state of button
// uint8_t is the same as byte
// uint16_t is unsigned int
// I just noticed that I mixed these in this sketch, sorry
const uint8_t lights[360]={
0, 0, 0, 0, 0, 1, 1, 2,
2, 3, 4, 5, 6, 7, 8, 9,
11, 12, 13, 15, 17, 18, 20, 22,
24, 26, 28, 30, 32, 35, 37, 39,
42, 44, 47, 49, 52, 55, 58, 60,
63, 66, 69, 72, 75, 78, 81, 85,
88, 91, 94, 97, 101, 104, 107, 111,
114, 117, 121, 124, 127, 131, 134, 137,
141, 144, 147, 150, 154, 157, 160, 163,
167, 170, 173, 176, 179, 182, 185, 188,
191, 194, 197, 200, 202, 205, 208, 210,
213, 215, 217, 220, 222, 224, 226, 229,
231, 232, 234, 236, 238, 239, 241, 242,
244, 245, 246, 248, 249, 250, 251, 251,
252, 253, 253, 254, 254, 255, 255, 255,
255, 255, 255, 255, 254, 254, 253, 253,
252, 251, 251, 250, 249, 248, 246, 245,
244, 242, 241, 239, 238, 236, 234, 232,
231, 229, 226, 224, 222, 220, 217, 215,
213, 210, 208, 205, 202, 200, 197, 194,
191, 188, 185, 182, 179, 176, 173, 170,
167, 163, 160, 157, 154, 150, 147, 144,
141, 137, 134, 131, 127, 124, 121, 117,
114, 111, 107, 104, 101, 97, 94, 91,
88, 85, 81, 78, 75, 72, 69, 66,
63, 60, 58, 55, 52, 49, 47, 44,
42, 39, 37, 35, 32, 30, 28, 26,
24, 22, 20, 18, 17, 15, 13, 12,
11, 9, 8, 7, 6, 5, 4, 3,
2, 2, 1, 1, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0};
const uint8_t HSVlights[61] =
{0, 4, 8, 13, 17, 21, 25, 30, 34, 38, 42, 47, 51, 55, 59, 64, 68, 72, 76,
81, 85, 89, 93, 98, 102, 106, 110, 115, 119, 123, 127, 132, 136, 140, 144,
149, 153, 157, 161, 166, 170, 174, 178, 183, 187, 191, 195, 200, 204, 208,
212, 217, 221, 225, 229, 234, 238, 242, 246, 251, 255};
const uint8_t HSVpower[121] =
{0, 2, 4, 6, 8, 11, 13, 15, 17, 19, 21, 23, 25, 28, 30, 32, 34, 36, 38, 40,
42, 45, 47, 49, 51, 53, 55, 57, 59, 62, 64, 66, 68, 70, 72, 74, 76, 79, 81,
83, 85, 87, 89, 91, 93, 96, 98, 100, 102, 104, 106, 108, 110, 113, 115, 117,
119, 121, 123, 125, 127, 130, 132, 134, 136, 138, 140, 142, 144, 147, 149,
151, 153, 155, 157, 159, 161, 164, 166, 168, 170, 172, 174, 176, 178, 181,
183, 185, 187, 189, 191, 193, 195, 198, 200, 202, 204, 206, 208, 210, 212,
215, 217, 219, 221, 223, 225, 227, 229, 232, 234, 236, 238, 240, 242, 244,
246, 249, 251, 253, 255};
uint8_t outputPins[6] = {0, 1, 4, 9, 10, 11}; // PWM pins
// setRGBpoint (0, ...) for pins 3, 5, 6; setRGBpoint (1, ...) for pins 9, 10, 11.
// See array above
void setRGBpoint(byte LED, uint8_t red, uint8_t green, uint8_t blue)
// this code is for common anode LEDs. If you use common cathode ones,
// remove the '255-' bits.
analogWrite(outputPins[LED*3], 255-red);
analogWrite(outputPins[LED*3+1], 255-green);
analogWrite(outputPins[LED*3+2], 255-blue);
// the real HSV rainbow
void trueHSV(byte LED, int angle)
byte red, green, blue;
if (angle<60) {red = 255; green = HSVlights[angle]; blue = 0;} else
if (angle<120) {red = HSVlights[120-angle]; green = 255; blue = 0;} else
if (angle<180) {red = 0, green = 255; blue = HSVlights[angle-120];} else
if (angle<240) {red = 0, green = HSVlights[240-angle]; blue = 255;} else
if (angle<300) {red = HSVlights[angle-240], green = 0; blue = 255;} else
{red = 255, green = 0; blue = HSVlights[360-angle];}
setRGBpoint(LED, red, green, blue);
// the 'power-conscious' HSV rainbow
void powerHSV(byte LED, int angle)
if (angle<120) {red = HSVpower[120-angle]; green = HSVpower[angle]; blue = 0;} else
if (angle<240) {red = 0; green = HSVpower[240-angle]; blue = HSVpower[angle-120];} else
{red = HSVpower[angle-240]; green = 0; blue = HSVpower[360-angle];}
// sine wave rainbow
void sineLED(byte LED, int angle)
setRGBpoint(LED, lights[(angle+120)%360], lights[angle], lights[(angle+240)%360]);
pinMode(BUTTON_PIN, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(PWR_PIN, OUTPUT); // set arduino pin to output mode
button.setDebounceTime(30); // set debounce time to 50 milliseconds
digitalWrite(PWR_PIN, PWRState);
button.loop(); // MUST call the loop() function first
if (button.isPressed()) {
// toggle state of relay
PWRState = !PWRState;
// control relay arccoding to the toggled state
for (int k=0; k<360; k++)
// uncomment the mode (or modes) you need below.
// with all six PWM outputs connected you may use 2 modes, change one 0 to 1.
trueHSV(0, k);
//powerHSV(0, k);
//sineLED(0, k);
delay(60);
