Turning servo with ds3231
In this part of the code, I want the servo to rotate four times at exactly 3:00 pm.
I have tried so many different code constructs but still the servo doesn't move at the appointed time.
I am using RTClib.
Last version of the code:
void feed(){
  bool counter = 0;
  DateTime now = rtc.now();
  if(now.hour() == 15 && now.minute() == 0 && now.second() == 0){
    counter = 1;
switch(counter){
  case 1:
  Servo1.write(180);
  Servo1.write(0);
  Servo1.write(180);
  Servo1.write(0);
  counter = 0;
  case 0:
  Servo1.write(0);
Please post your full sketch so that variable declarations etc can be seen in context
  Servo1.write(180);
  Servo1.write(0);
  Servo1.write(180);
  Servo1.write(0);
The code does not wait until the servo reaches its commanded position before moving on to the next command. Can you see the problem ?
Thanks a lot. I've been stuck with such a simple problem for a long time.
I am glad that the penny has dropped
Do you know how to fix the problem ?
Is the sketch required to do anything else whilst the servos are moving back and forth ?
