I don't know what I did wrong.
int buttonApin = 9;//one button to pin 9 on the Arduino
int buttonBpin = 8;//anther button to pin 8 on the Arduino
int red = 3;//Red Color to pin 3 on Arduino
int yellow = 4;//Yellow Color to pin 4 on Arduino
int green = 5;//Green Color to pin 5 on Arduino
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
pinMode(buttonApin, INPUT_PULLUP);
pinMode(buttonBpin, INPUT_PULLUP);
digitalWrite(green, HIGH);
digitalWrite(red, LOW);
digitalWrite(yellow, LOW);
if (digitalRead(buttonApin) == HIGH){
delay(15); // software debounce
if (digitalRead(buttonApin) == HIGH) {
// if the switch is HIGH, ie. pushed down - change the lights!
changeLights();
else {
void changeLights(){
// green off, yellow on for 3 seconds
digitalWrite(green, LOW);
digitalWrite(yellow, HIGH);
delay(3000);
// this is to check if button is still pressed while delaying
for(long int i = 0; i < 600000; i++){
// if button is released
if (digitalRead(buttonApin) == LOW) {
return;
// turn off yellow, then turn red indefintily
digitalWrite(red, HIGH);
if (digitalRead(buttonBpin) == HIGH){
changeLights();
else {
void changeLights loop(){
//turn on green
// if button is pressed
if (digitalRead(buttonBpin) == HIGH) {
return;
