The purpose of this code is to turn on and off a PIR Sensor, which activates the piezo buzzer if the sensor detects movement. The activation of the buzzer portion of the code works, but I am stuck on the on and off switch part. I attempted to use an if-else statements, but the code didn't work. Would anyone mind taking a look at my code?
Ty in advance
int speakerOut = 9;//Piezo buzzer's positive terminal is connected to digital pin 9
byte names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'};
int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
byte melody[] = "2d2a1f2c2d2a2d2c2f2d2a2c2d2a1f2c2d2a2a2g2p8p8p8p";
// count length: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
// 10 20 30
int count = 0;
int count2 = 0;
int count3 = 0;
int MAX_COUNT = 24;
const int BUTTON = 7;
const int MOTION = 2;
int val = 0;
int statePin = LOW;
void siren();
volatile byte intruder;
attachInterrupt(0, intruder_detect, RISING);//Initialize the intterrupt pin for the motion sensor (Arduino digital pin 2)
intruder = 0;
void loop(){
val = digitalRead(BUTTON);
if (val == HIGH) {
digitalWrite(MOTION, HIGH);
digitalWrite(MOTION, LOW);
void intruder_detect()//This function is called whenever an intruder is detected by the arduino
intruder++;
Serial.println("Intruder detected");
for(int i=0; i<3; i++)//Play the alarm three times
siren();
void siren()//This function will make the alarm sound using the piezo buzzer
for (count = 0; count < MAX_COUNT; count++) {
for (count3 = 0; count3 <= (melody[count*2] - 48) * 30; count3++) {
for (count2=0;count2<8;count2++) {
if (names[count2] == melody[count*2 + 1]) {
analogWrite(speakerOut,1023);
delayMicroseconds(tones[count2]);
analogWrite(speakerOut, 0);
if (melody[count*2 + 1] == 'p') {
// make a pause of a certain size
delayMicroseconds(100);
