Turning YYYY to YY
Hi everyone
I just started to explore the TinyGPS++ library, which I am finding very useful. However, I am trying to convert the YYYY number (e.g.: "2014") into YY ("14"). I've tried snprintf but haven't had any luck. Does anyone have any examples that I could use to achieve this?
Thanks!
#include <TinyGPS++.h>
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
  Serial1.begin(GPSBaud);
  // Dispatch incoming characters
  while (Serial1.available() > 0)
    gps.encode(Serial1.read());
if (gps.date.isUpdated())
          //////////// Print the date & time...
          char datetime_string[18]; //make this big enough to hold the resulting string
          snprintf(datetime_string, sizeof(datetime_string), "%02d/%02d/%2d %02d:%02d:%02d",
          gps.date.month(), gps.date.day(), gps.date.year(), gps.time.hour(), gps.time.minute(), gps.time.second());
          //buffer now contains a string like 02/22/13 05:03:06
          Serial.print(datetime_string);
          Serial.println(" ");
year - 2000 should keep you going until the next century.
Year % 100 will give you a number in the range 0 .. 99 which you can then print however you want.
problem is of course that the number is in a char array
  char year[5] = "2014";
  char yr[3];
  strcpy(yr, &year[2]);
  Serial.println(yr);
or in place (if the cahr array allows)
  strcpy(year, &year[2]);
  Serial.println(yr);
a memmove() should work too
  Serial.println(&year[2]);
Seems simpler to me
AWOL:
Seems simpler to me
even better!
+1
Thank you guys so much for the tips. This makes total sense! And thanks for the tip on how to pass the YY value to a variable... this will come super handy :slight_smile:
