Tutorial for hacking a CP2102 USB from ebay and uploading a sketch to an Atmega
Did you swap them because of the pinout on your arduino, or because the board was mislabeled (that rx was labelled as tx?)?
msev:
My Arduino board uses the standard FTDI pinout if that helps (I only bought the CP2102's to test). I believe this board actually has RX/TX marked correctly since with my other TTL/USB adapter also crosses TX/RX.
FWIW,
Brad.
its common form what I have seen..
some mark it as to what it GOES to.. an some mark it as what it IS..
once of the first things I try to swap when an FTDI sketch upload fails..
what/where are these boards you are getting?? (that has the DTR pin broke out)
my cheapie cables only ave 4 lines (5 if you count the 3.3v pad) 5v+, GND, RX, TX..
I hve to manually hit the reset button to upload sketches.. not a problem.. but going forward.. some projects wont have a reset button at all.
Here are the ones I bought, can't beat the price:
http://www.ebay.com/itm/370532286388?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Lefty
you dont have to use the 6-pin header do you?
I mean treat this like any other FTDI cable..yes?
as long as I run 5v+, GND, RX, TX to my chip.. Im good.. I can then use/tap the DTR pad from the bottom of the board to use on the DTR of the circuit Im uploading my sketch to....right?
a shame it was brought out on top like the other pins.
also is there a driver for it?
thanks
@msev,
a board like you describe is easy to make.
xl97:
Nope. You can wire it up any way you choose. I do use 6pin headers simply to keep with the standard FTDI pinout.
Note the included (very short) cable actually only has 5pins (you can see that in the picture that Lefty posted).
Sure, just get a couple of the 6pin female crimp housings (such as Pololu - 0.1" (2.54mm) Crimp Connector Housing: 1x6-Pin 10-Pack), remove the single pin plastic housing on each pin, and insert the pins in the correct order. Or use whatever size header you want, as long as it matches your board.
I'd suggest testing the pinout first just in case :slight_smile:
You don't really need to pass 5v, but you've got the idea. I was going to post a picture of a modified board but there isn't much to show - simply a cut trace and a jumper wire. Takes 2 minutes and seems to work great.
Yup. I think there is a link earlier in this thread. If not, you can find the driver here An Arduino Compatible Using CP2102 – Kerry D. Wong
Hope this helps,
Brad.
thanks for the reply..
even found it a buck cheaper on ebay too:
http://www.ebay.com/itm/130683943875?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
thanks!
CrossRoads:
@msev,
Are you willing to design it for me since you have a lot of experience (in Eagle)? With Dip atmega328.
Sure - which parts do you want to keep, and how do want the connector?
Thank you very much, you are really kind! it would take ages for me to draw all the connections...I do quite well for a beginner in the schematic editor, but in the board editor I get into trouble :)..
Well I'd like it to be single sided (I think I've already mentioned that :D) and with a dip package atmega and other parts also normal size (let say 3mm leds) not smd size ..
And I'd like the optional parts also (I'm not sure about that pwr led, it just indicates the arduino is being powered right?) and do I need the reset switch, if I have autoreset? I'd like the layout for the programming pins to be as similar as they can be with the modified programmer we are talking about http://www.ebay.com/itm/USB-2-0-UART-TTL-6PIN-Module-Serial-Converter-CP2102-/370532286388?pt=PCC_Drives_Storage_Internal&hash=item564571ffb4#ht_2817wt_1110 ...
I guess I want a female connector if cp2102 has male pins.
I don't need ICSP.
Thats about it I guess :slight_smile:
Also maybe I'd like a led on D13 so I can diagnose if the arduino is properly working with blink sketch (or which pin is it, I know I have a led that blinks on my nano if I upload the sketch on it, its permanently on the board).
Oh another thing, I'd like it to be drawn in Eagle :).
I have another question about the bootloader,..I shouldn't buy atmega with optiboot (or uno bootloader) right, but instead with duemilanove bootloader right?
Physical chip pin 19 is the arduino digital pin 13. Just wire a resistor and led in series from that pin to ground, with the led cathode lead wired to ground. A 1K resistor is used in the standard arduino board.
Lefty
CrossRoads:
So you won't be designing it =( :slight_smile:
Already designed - just needs a little tweaking.
Unfortunately only so many hours in a day, and I don't always get back to a thread I might be interested in (right away).
I assume you can handle naming of pins on the board if I post the files?
Yep that won't be a problem...I see its double sided right? :), I'll have to learn the correct technique to line all the lines right :)..
The board in your previous post isn't the same like in your last post right?
Yes, double sided.
I let eagle auto-route it. It does okay if you have good parts placement to begin with.
The design is almost the same, added a couple of caps to the +5 line, diode in parallel with the reset pullup resistor, the 3mm LED and current limit resistor, and put all the pins in one row to be breadboard friendly (assuming one installs right angle male header there).
Btw would you try and autoroute a single sided version too?
Is anyone planning on sending this to a board house to have it fabricated?
I like the breadboard friendly nature. I currently use Nanos but I might like to try one of these boards.
