TL;DR how to change sync pin on UNO
I am trying to use the TV.out library to display info to my cars head unit and it works well on its own but once I add the can bus shield there are overlapping pins and I can only have one or the other.
I was able to swap the video pin to a few places, now on pin 4 (instead of 7) but the sync pin will not move. Here is the exert of the setup that apples to my UNO:
#elif defined(__AVR_ATmega8__) || defined(__AVR_ATmega88__) || defined(__AVR_ATmega168P__) || defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__)
//video
#if defined(ENABLE_FAST_OUTPUT)
#define PORT_VID PORTD
#define DDR_VID DDRD
#define VID_PIN 7
#else
#define PORT_VID PORTB
#define DDR_VID DDRB
#define VID_PIN 0
#endif
//sync
#define PORT_SYNC PORTB
#define DDR_SYNC DDRB
#define SYNC_PIN 1
//sound
#define PORT_SND PORTB
#define DDR_SND DDRB
#define SND_PIN 3
In theory I should be able to swap the sound and sync as I dont need sound right?
Why does the sync pin define as 1 if its pin nine?
Has anyone swapped the sync pin?
Please help
