Greetings,
I am new to Arduino and I thought it would be cool to make Arduino Pong so, I followed this intractable:
and I am getting this error message:
Arduino: 1.6.1 (Mac OS X), Board: “Arduino Uno”
sketch_mar15a.ino:10:21: fatal error: TVout.h: No such file or directory
compilation terminated.
Error compiling.
“Show verbose output during compilation”
enabled in File > Preferences.
If someone could help that would be great!
Thank you,
Dave
and I used this code:
- Arduino Pong
- By Pete Lamonica
- modified by duboisvb
- A simple implementation of Pong on the Arduino using a TV for output.
#include <TVout.h>
#define WHEEL_ONE_PIN 0 //analog
#define WHEEL_TWO_PIN 1 //analog
#define BUTTON_ONE_PIN 2 //digital to start game
// #define BUTTON_TWO_PIN 3 //digital to reset and go back to main menu
#define PADDLE_HEIGHT 14
#define PADDLE_WIDTH 1
#define RIGHT_PADDLE_X (TV.horz_res()-4)
#define LEFT_PADDLE_X 2
#define IN_GAMEA 0 //in game state - draw constants of the game box
#define IN_GAMEB 0 //in game state - draw the dynamic part of the game
#define IN_MENU 1 //in menu state
#define GAME_OVER 2 //game over state
#define LEFT_SCORE_X (TV.horz_res()/2-15)
#define RIGHT_SCORE_X (TV.horz_res()/2+10)
#define SCORE_Y 4
#define MAX_Y_VELOCITY 6
#define PLAY_TO 7
#define LEFT 0
#define RIGHT 1
TVout TV;
unsigned char x,y;
boolean button1Status = false;
// boolean button2Status = false;
int wheelOnePosition = 0;
int wheelTwoPosition = 0;
int rightPaddleY = 0;
int leftPaddleY = 0;
unsigned char ballX = 0;
unsigned char ballY = 0;
char ballVolX = 2;
char ballVolY = 2;
int leftPlayerScore = 0;
int rightPlayerScore = 0;
int frame = 0;
int state = IN_MENU;
void processInputs() {
wheelOnePosition = analogRead(WHEEL_ONE_PIN);
// delay(50);
wheelTwoPosition = analogRead(WHEEL_TWO_PIN);
// delay(50);
button1Status = (digitalRead(BUTTON_ONE_PIN) == LOW);
// button2Status = (digitalRead(BUTTON_TWO_PIN) == LOW);
if ((button1Status == true)&& (state == GAME_OVER))
drawMenu ();
// button1Status = (digitalRead(BUTTON_ONE_PIN));
//cdubois
// Serial.println(BUTTON_ONE_PIN);
// Serial.println(BUTTON_TWO_PIN);
// delay(500);
// Serial.println(button1Status);
// Serial.println(button2Status);
// Serial.println(wheelOnePosition);
// Serial.println(wheelTwoPosition);
// delay(1000);
void drawGameScreen() {
// TV.clear_screen();
//draw right paddle
rightPaddleY = ((wheelOnePosition /8) * (TV.vert_res()-PADDLE_HEIGHT))/ 128;
x = RIGHT_PADDLE_X;
for(int i=0; i<PADDLE_WIDTH; i++) {
TV.draw_line(x+i,rightPaddleY,x+i,rightPaddleY+PADDLE_HEIGHT,1);
//draw left paddle
leftPaddleY = ((wheelTwoPosition /8) * (TV.vert_res()-PADDLE_HEIGHT))/ 128;
x = LEFT_PADDLE_X;
TV.draw_line(x+i,leftPaddleY,x+i,leftPaddleY+PADDLE_HEIGHT,1);
//draw score
TV.print_char(LEFT_SCORE_X,SCORE_Y,‘0’+leftPlayerScore);
TV.print_char(RIGHT_SCORE_X,SCORE_Y,‘0’+rightPlayerScore);
//draw ball
TV.set_pixel(ballX, ballY, 2);
//player == LEFT or RIGHT
void playerScored(byte player) {
if(player == LEFT) leftPlayerScore++;
if(player == RIGHT) rightPlayerScore++;
//check for win
if(leftPlayerScore == PLAY_TO || rightPlayerScore == PLAY_TO) {
state = GAME_OVER;
ballVolX = -ballVolX;
void drawBox() {
TV.clear_screen();
//draw net
for(int i=1; i<TV.vert_res() - 4; i+=6) {
TV.draw_line(TV.horz_res()/2,i,TV.horz_res()/2,i+3,1);
// had to make box a bit smaller to fit tv
TV.draw_line(0, 0, 0,95,1 ); // left
TV.draw_line(0, 0, 126,0,1 ); // top
TV.draw_line(126, 0, 126,95,1 ); // right
TV.draw_line(0, 95, 126,95,1 ); // bottom
state = IN_GAMEB;
void drawMenu() {
x = 0;
y = 0;
char volX =3;
char volY = 3;
TV.clear_screen();
TV.select_font(_8X8);
TV.print_str(10, 5, “Arduino Pong”);
TV.select_font(_5X7);
TV.print_str(22, 35, “Press Button”);
TV.print_str(30, 45, “To Start”);
while(!button1Status) {
processInputs();
TV.delay_frame(3);
if(x + volX < 1 || x + volX > TV.horz_res() - 1) volX = -volX;
if(y + volY < 1 || y + volY > TV.vert_res() - 1) volY = -volY;
if(TV.get_pixel(x + volX, y + volY)) {
TV.set_pixel(x + volX, y + volY, 0);
if(TV.get_pixel(x + volX, y - volY) == 0) {
volY = -volY;
else if(TV.get_pixel(x - volX, y + volY) == 0) {
volX = -volX;
else {
volX = -volX;
volY = -volY;
TV.set_pixel(x, y, 0);
x += volX;
y += volY;
TV.set_pixel(x, y, 1);
state = IN_GAMEA;
// Serial.begin(9600);
x=0;
y=0;
TV.start_render(_NTSC); //for devices with only 1k sram(m168) use TV.begin(_NTSC,128,56)
ballX = TV.horz_res() / 2;
ballY = TV.vert_res() / 2;
// pinMode(BUTTON_ONE_PIN, INPUT); // sets the digital pin as output
processInputs();
if(state == IN_MENU) {
drawMenu();
if(state == IN_GAMEA) {
drawBox();
if(state == IN_GAMEB) {
if(frame % 3 == 0) { //every third frame
ballX += ballVolX;
ballY += ballVolY;
// change if hit top or bottom
if(ballY <= 1 || ballY >= TV.vert_res()-1)
{ ballVolY = -ballVolY;
delay(100);
TV.tone( 2000,30 );
// test left side for wall hit
if(ballVolX < 0 && ballX == LEFT_PADDLE_X+PADDLE_WIDTH-1 && ballY >= leftPaddleY && ballY <= leftPaddleY + PADDLE_HEIGHT) {
ballVolY += 2 * ((ballY - leftPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2);
delay(100);
TV.tone(2000,30 );
// test right side for wall hit
if(ballVolX > 0 && ballX == RIGHT_PADDLE_X && ballY >= rightPaddleY && ballY <= rightPaddleY + PADDLE_HEIGHT) {
ballVolY += 2 * ((ballY - rightPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2);
delay(100);
TV.tone( 2000,30 );
//limit vertical speed
if(ballVolY > MAX_Y_VELOCITY) ballVolY = MAX_Y_VELOCITY;
if(ballVolY < -MAX_Y_VELOCITY) ballVolY = -MAX_Y_VELOCITY;
// Scoring
if(ballX <= 1) {
playerScored(RIGHT);
// sound
delay(100);
TV.tone( 500,300 );
if(ballX >= TV.horz_res() - 1) {
playerScored(LEFT);
// sound
delay(100);
TV.tone( 500,300 );
// if(button1Status) Serial.println((int)ballVolX);
drawGameScreen();
if(state == GAME_OVER) {
drawGameScreen();
TV.print_str(29,25,“GAME”);
TV.print_str(68,25,“OVER”);
processInputs();
delay(50);
TV.select_font(_5X7); //reset the font
//reset the scores
state = IN_MENU;
TV.delay_frame(1);
if(++frame == 60) frame = 0; //increment and/or reset frame counter
