TVOut library issues
I am trying to make a simple console using Arduino to play a clone version of classic games like Pong, I've tried installing the TVOut library, however, on two different RCA screens, I do not get any output, just a black screen
It will help if you read the pinned post called 'How to get the most from the forum'
Did you test using one of the example sketches from the TVOut library? That's the first thing to do, to know you have the circuit correct.
Google says: " A library for generating PAL or NTSC video output with an AVR. Supports PAL and NTSC with the max resolution of 128 times 96 pixels.". So the question is: are you using that type of TV set?
