ik heb deze code kunnen vinden maar hoe kan ik dit aanpassen dat het op twee sloten werkt ??
ik dacht eerst zo
void loop1(void) {...}
void loop2(void) {...}
void loop(void) {
loop1(); //run loop1
loop2(); //run loop2
loopn(); //run loopn
maar hoe verwerk ik dat dan in de volgende ??
zodat zeg 1234 slot een opend
en 5678 slot twee opend
alvst bedankt
groetjes uit udenhout
dennis
#include <Password.h> //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip //tells to use keypad library
#include <Servo.h> //tells to use servo library
Servo myservo; //declares servo
Password password = Password( "0000" ); //password to unlock, can be changed
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
Serial.write(254);
Serial.write(0x01);
delay(200);
pinMode(11, OUTPUT); //green light
pinMode(12, OUTPUT); //red light
myservo.attach(13); //servo on digital pin 9 //servo
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
keypad.getKey();
myservo.write(0);
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
Serial.print("Enter:");
Serial.println(eKey);
delay(10);
Serial.write(254);
switch (eKey){
case '*': checkPassword(); delay(1); break;
case '#': password.reset(); delay(1); break;
default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){ //if password is right open
Serial.println("Accepted");
Serial.write(254);delay(10);
//Add code to run if it works
myservo.write(150); //deg
digitalWrite(11, HIGH);//turn on
delay(5000); //wait 5 seconds
digitalWrite(11, LOW);// turn off
}else{
Serial.println("Denied"); //if passwords wrong keep locked
//add code to run if it did not work
myservo.write(0);
digitalWrite(12, HIGH); //turn on
delay(500); //wait 5 seconds
digitalWrite(12, LOW);//turn off
