The code I used to get the motor working forward and backward is attached, its just a code I downloaded for testing.
#include "thermistortables.h"
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define X_MIN_PIN 3
#define X_MAX_PIN 2
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Y_MIN_PIN 14
#define Y_MAX_PIN 15
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
#define Z_MIN_PIN 18
#define Z_MAX_PIN 19
#define E_STEP_PIN 26
#define E_DIR_PIN 28
#define E_ENABLE_PIN 24
#define Q_STEP_PIN 36
#define Q_DIR_PIN 34
#define Q_ENABLE_PIN 30
#define SDPOWER -1
#define EXTRUDERS 3
#define TEMP_SENSOR_AD595_OFFSET 0.0
#define TEMP_SENSOR_AD595_GAIN 1.0
#define THERMISTORHEATER_0 1
#define THERMISTORHEATER_1 1
#define THERMISTORHEATER_2 1
#define HEATER_0_USES_THERMISTOR 1
#define HEATER_1_USES_THERMISTOR 1
#define HEATER_2_USES_THERMISTOR 1
static void *heater_ttbl_map[EXTRUDERS] = { (void *)heater_0_temptable
#if EXTRUDERS > 1
, (void *)heater_1_temptable
#endif
#if EXTRUDERS > 2
, (void *)heater_2_temptable
#endif
#if EXTRUDERS > 3
#error Unsupported number of extruders
#endif
static int heater_ttbllen_map[EXTRUDERS] = { heater_0_temptable_len
#if EXTRUDERS > 1
, heater_1_temptable_len
#endif
#if EXTRUDERS > 2
, heater_2_temptable_len
#endif
#if EXTRUDERS > 3
#endif
#define PGM_RD_W(x) (short)pgm_read_word(&x)
#define SDSS 53
#define LED_PIN 13
#define FAN_PIN 9
#define PS_ON_PIN 12
#define KILL_PIN -1
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define TEMP_0_PIN 15 // ANALOG NUMBERING
#define TEMP_1_PIN 14 // ANALOG NUMBERING
#define TEMP_2_PIN 13 // ANALOG NUMBERING
pinMode(TEMP_0_PIN , INPUT);
pinMode(TEMP_1_PIN , INPUT);
pinMode(TEMP_2_PIN , INPUT);
pinMode(FAN_PIN , OUTPUT);
pinMode(HEATER_0_PIN , OUTPUT);
pinMode(HEATER_1_PIN , OUTPUT);
pinMode(LED_PIN , OUTPUT);
pinMode(X_STEP_PIN , OUTPUT);
pinMode(X_DIR_PIN , OUTPUT);
pinMode(X_ENABLE_PIN , OUTPUT);
pinMode(Y_STEP_PIN , OUTPUT);
pinMode(Y_DIR_PIN , OUTPUT);
pinMode(Y_ENABLE_PIN , OUTPUT);
pinMode(Z_STEP_PIN , OUTPUT);
pinMode(Z_DIR_PIN , OUTPUT);
pinMode(Z_ENABLE_PIN , OUTPUT);
pinMode(E_STEP_PIN , OUTPUT);
pinMode(E_DIR_PIN , OUTPUT);
pinMode(E_ENABLE_PIN , OUTPUT);
pinMode(Q_STEP_PIN , OUTPUT);
pinMode(Q_DIR_PIN , OUTPUT);
pinMode(Q_ENABLE_PIN , OUTPUT);
digitalWrite(X_ENABLE_PIN , LOW);
digitalWrite(Y_ENABLE_PIN , LOW);
digitalWrite(Z_ENABLE_PIN , LOW);
digitalWrite(E_ENABLE_PIN , LOW);
digitalWrite(Q_ENABLE_PIN , LOW);
float analog2temp(int raw, uint8_t e) {
#ifdef HEATER_0_USES_MAX6675
if (e == 0)
return 0.25 * raw;
#endif
if(heater_ttbl_map[e] != 0)
float celsius = 0;
byte i;
short (*tt)[][2] = (short (*)[][2])(heater_ttbl_map[e]);
raw = (1023 * OVERSAMPLENR) - raw;
for (i=1; i<heater_ttbllen_map[e]; i++)
if ((PGM_RD_W((*tt)[i][0]) > raw) && ((float)(PGM_RD_W((*tt)[i][0]) - PGM_RD_W((*tt)[i-1][0])) >0))
celsius = PGM_RD_W((*tt)[i-1][1]) +
(raw - PGM_RD_W((*tt)[i-1][0])) *
(float)(PGM_RD_W((*tt)[i][1]) - PGM_RD_W((*tt)[i-1][1])) /
(float)(PGM_RD_W((*tt)[i][0]) - PGM_RD_W((*tt)[i-1][0]));
// Overflow: Set to last value in the table
if (i == heater_ttbllen_map[e]) celsius = PGM_RD_W((*tt)[i-1][1]);
return celsius;
return ((raw * ((5.0 * 100.0) / 1024.0) / OVERSAMPLENR) * TEMP_SENSOR_AD595_GAIN) + TEMP_SENSOR_AD595_OFFSET;
unsigned long prevMillis;
void loop () {
if (millis() %1000 <500)
digitalWrite(LED_PIN, HIGH);
digitalWrite(LED_PIN, LOW);
if (millis() %1000 <300) {
digitalWrite(HEATER_0_PIN, HIGH);
digitalWrite(HEATER_1_PIN, LOW);
digitalWrite(FAN_PIN, LOW);
} else if (millis() %1000 <600) {
digitalWrite(HEATER_0_PIN, LOW);
digitalWrite(HEATER_1_PIN, HIGH);
digitalWrite(FAN_PIN, HIGH);
if (millis() %2000 <1000) {
digitalWrite(X_DIR_PIN , HIGH);
digitalWrite(Y_DIR_PIN , HIGH);
digitalWrite(Z_DIR_PIN , HIGH);
digitalWrite(E_DIR_PIN , HIGH);
digitalWrite(Q_DIR_PIN , HIGH);
else {
digitalWrite(X_DIR_PIN , LOW);
digitalWrite(Y_DIR_PIN , LOW);
digitalWrite(Z_DIR_PIN , LOW);
digitalWrite(E_DIR_PIN , LOW);
digitalWrite(Q_DIR_PIN , LOW);
digitalWrite(X_STEP_PIN , HIGH);
digitalWrite(Y_STEP_PIN , HIGH);
digitalWrite(Z_STEP_PIN , HIGH);
digitalWrite(E_STEP_PIN , HIGH);
digitalWrite(Q_STEP_PIN , HIGH);
delay(1);
digitalWrite(X_STEP_PIN , LOW);
digitalWrite(Y_STEP_PIN , LOW);
digitalWrite(Z_STEP_PIN , LOW);
digitalWrite(E_STEP_PIN , LOW);
digitalWrite(Q_STEP_PIN , LOW);
if (millis() -prevMillis >500){
prevMillis=millis();
int t = analogRead( TEMP_0_PIN);
Serial.print("T0 ");
Serial.print(t);
Serial.print("/");
Serial.print(analog2temp(1024 - t,0),0);
Serial.print(" T1 ");
t = analogRead( TEMP_1_PIN);
Serial.print(t);
Serial.print("/");
Serial.print(analog2temp(1024 - t,1),0);
Serial.print(" T2 ");
t = analogRead( TEMP_2_PIN);
Serial.print(t);
Serial.print("/");
Serial.println(analog2temp(1024 - t,2),0);
It is possible that I have configured Marlin incorrectly, I have also attached some photos of my project, is there anything that you can see that I may need to change in Marlin from the photos? (apart from the fact that the steppers aren’t plugged in)
Thanks for the help anyway, I am kinda new to the stepper motor world lol
Google Drive Link for photos: 2 Axis Stepper Project - Google Drive
