Twitter Request Error "HTTP/1.1 301 Moved Permanently" (Uno + Ethernet)
Hi, I have a project that checks for and displays the first tweet on a public twitter account. This is just a way of updating the text of an LCD outside my door.
It used the source of the page api.twitter.com/1/statuses/user_timeline.xml?screen_name=arduino&count=1 to extract the tweet. This is the method that was used in the sample Twitter code provided on arduino.cc.
This method is now deprecated. The page now shows the following message "The Twitter REST API v1 is no longer active. Please migrate to API v1.1."
The sample Twitter code on arduino.cc includes the message: "This example doesn't work anymore because the Twitter authentication mode is now different and not compatible with Arduino libraries."
What I'm trying to do now is extract the tweet from the URL that normal Twitter users visit: twitter.com/arduino
The problem is that when I visit the URL from my arduino program, I don't get the same text I see when I look at the source text on my browser (by pressing ctrl+u). I instead get the following:
date: Fri, 30 Aug 2013 03:01:12 UTC
server: tfe
set-cookie: guest_id=v1%3A137783167277866638; Domain=.twitter.com; Path=/; Expires=Sun, 30-Aug-2015 03:01:12 UTC
Content-Length: 0
Connection: close
When I try my code with a different URL, I get the same source text that I see when using a browser.
Does anyone have any idea on how to get the actual source text for the twitter URL?
Here is a simple test program that prints the source of a URL to the Serial monitor. It uses similar code to my current project:
#include <SPI.h>
#include <Ethernet.h>
IPAddress ip(123,456,789,012);
byte mac[] = {0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF};
char serverName[] = "twitter.com"; //CHANGE THIS IF TESTING ANOTHER SITE*******************************
EthernetClient client;
  Serial.println("Attempting to get an IP address using DHCP:");
  if (!Ethernet.begin(mac)) { // if DHCP fails, start with a hard-coded address:
    Serial.println("failed to get an IP address using DHCP, trying manually");
    Ethernet.begin(mac, ip);
  Serial.print("My address:");
  Serial.println(Ethernet.localIP());
  connectToServer();
//prints website source one char at a time
  if (client.connected()) {
    if (client.available()) {
      char inChar = client.read(); // read incoming bytes:
      Serial.print(inChar);
  else {
    Serial.println("Starting delay between requests.");
    client.stop();
    delay(120000);
    Serial.println("Delay finished.");
    connectToServer();
void connectToServer() {
  Serial.println("Connecting to server...");
  if (client.connect(serverName, 80)) {
    Serial.println("Making HTTP request...\n");
    client.println("GET /arduino HTTP/1.1");
    client.println("HOST: twitter.com");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("Connection to server failed.");
If anyone has a better way to send text from a smartphone (with an app maybe) to an arduino without using twitter, I'd love to hear it. (A web server won't work since I have no access to the router I'm using). Thanks for the help.
That is telling you that you must use a SSL connection (https) to access Twitter. The ethernet library does not support SSL.
Wow thanks! So simple.
It looks like using twitter to transfer messages to an Arduino just isn't an option anymore.
If anyone has any alternative suggestions, that would be great. Otherwise, I'll probably just look into posting to some sort of blog from an app.
danvonn:
You can access twitter (or connect to any https:// url) from an Arduino via the Radio For X:duino gateway system (RFXduino). Details at embeddedcoolness.com.
