twitter.wait() is hanging for 4 mins in NeoCat's Twitter for Arduino library
Hello. I use NeoCat's Twitter for Arduino library. I just updated the Twitter library to fix the December 5, 2018 403 error.
The 403 error is fixed but now I have a new problem: twitter.wait() is hanging for 4 minutes before returning 200 (tweet successful).
Below is the portion of my code where the issue occurs. I added several "Serial.print"'s before and after "status = twitter.wait();". The serial output is below the code:
boolean sendTweet(char* hashtag, char* tag, boolean open){
  if(open){
    strcpy(tweet, msg_OPEN);
    strcat(tweet, hashtag);
    strcat(tweet, msg_asOf);
    if (hour12 > 9)
      strcat(tweet, " ");
    strcat(tweet, timestamp);
    strcat(tweet, tag);
    strcpy(tweet, hashtag);
    if (hour12 > 9)
      strcat(tweet, " ");
    strcat(tweet, tag);
  lcd.clear();
  if (twitter.post(tweet)) {
    Serial.println("Tweet sent");
    Serial.println("About to check twitter.wait()");
    Serial.println("twitter.wait() checked");
    Serial.print("Status: ");
    Serial.println(status);
    if (status == 200) {
      lcd.print("Tweet sent!");
      lcd.setCursor(0,2);
      lcd.print(statusString);
      delay(2000);
      return 1;
      lcd.clear();
      lcd.print("Failure! Error ");
      lcd.print(status);
      delay(2000);
      strcpy(statusString, "ERROR Tweet not sent");
      lcd.setCursor(0,2);
      lcd.setCursor(0,3);
      lcd.print("Wait 1 min ");
      // one minute required by NeoCat
      delay(60000);
      return 0;
    lcd.clear();
    lcd.print("Connection failed.");
    delay(2000);
    return 0;
Here is the Serial output:
Tweet sent
Status: 200
Tweet sent
The time between "About to check twitter.wait()" and "twitter.wait() checked" appears to be exactly 4 minutes.
Is it a problem with my code or are others experiencing this?
Thank you, Jeremy
Same here! I'm using Arduino alpha 0022 with NeoCat's library for Botanicalls: https://www.botanicalls.com/ from Rob Faludi.
First I was using "Library-Twitter-1.2.2", all worked fine, until Twitter changed things in dec 2018; 403 error occured :-(
Upgraded to "Library-Twitter-1.3" from http://arduino-tweet.appspot.com/, but that didn't do the trick. Had to download twitter.cpp from https://github.com/NeoCat/Arduno-Twitter-library. Now machine tweets are possible again :) It looks like the tweet is done quickly, but the feedback takes a long time...idk...something takes forever in this process. As my code didn't change, the issue is caused somewhere else...
