Using two 4x 7219 displays with UNO have been working perfectly. Starting at one end and scrolling through all eight 8x8 matricies.
On the unit that was working fine, I just opened it up to replace one 8x8 matrix....it was brighter than the other 7....I had mixed and matched 8x8's when I built it. So now I wanted to put back one with the same brightness.
Result is:
a) all now match in brightness
b) Scrolling starts ON EACH set of 4 matricies, so Hello World is scrolling concurrently rather than continuously.
I assume my sketch is not the problem, and something I did when I opened it up caused the simultaneous scrolling. I tried unplugging and replugging, and resetting. Still the same.
Does anyone have a suggestion as to what may be the problem?
Thank You
Disconnecting and connecting makes a physical exercise for the cables and connectors.
To pinpoint any cable You would need to supply schematics and links to the display modules.
Please clarify the fault description. Show the display before and after a shift.
