Two actions at the same time
I'm sure there are a ton of topics on this but I just figured a direct response would be best.
When input digital pin 3 goes high, I want to sound a buzzer for about 250ms and set digital pin 4 high... The problem is that pin 4 won't go high until the buzzer is done. (Cause I'm using a delay) Any suggestions?
Don't use delay()?
Look and 'Blink without delay'?
When pin 3 goes high set pin 4 high and then sound the buzzer.
If your using Tone() to sound buzzer then it is non blocking and you can specify an options duration.
See my http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html Or Robin2's several things at once http://forum.arduino.cc/index.php?topic=223286.0
