two analogue sensors?
hi all,
I have been trying to get the below code working with an analogue sensor connected to both A0 and A2 with no luck, I have tried various bits of code but nothing seems to allow them to read separately, could anyone help with this?
thank you in advance
  #include "DHT.h"
  #include <sd.h>
  File myFile;
  int pinCS = 10;
  const int RED_PIN = 7;
  const int BLUE_PIN = 8;                                .
  const int GREEN_PIN = 9;
  int DISPLAY_TIME = 10;  // In milliseconds
  int temt6000Pin = 0;
  int airquality = 2;
  #define DHTPIN 2
  #define DHTTYPE DHT22
  DHT dht(DHTPIN, DHTTYPE);
  pinMode(RED_PIN, OUTPUT);
  pinMode(GREEN_PIN, OUTPUT);
  pinMode(BLUE_PIN, OUTPUT);
  pinMode(pinCS, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
    digitalWrite(BLUE_PIN, HIGH);
    digitalWrite(BLUE_PIN, LOW);
    } else
   Serial.println("SD card initialization failed");
   digitalWrite(GREEN_PIN, HIGH);
   digitalWrite(GREEN_PIN, LOW);
   return;
  dht.begin();
  delay(3000);
  int value = analogRead(temt6000Pin);
  Serial.print("Light is: ");
  Serial.println(value);
  int sensorValue = analogRead(A0);
  Serial.print("Air Quality = ");
  Serial.print(sensorValue);
  Serial.println(" PPM ");
  float h = dht.readHumidity();
  float f = dht.readTemperature();
  if (isnan(h)||isnan(f)) {
  return;
  myFile = SD.open("Logger.txt", FILE_WRITE);
  if (myFile) {
  Serial.print("Temperature: ");
  Serial.print(f);
  Serial.println(" *C ");
  Serial.print("humidity: ");
  Serial.print(h);
  Serial.println(" % ");
  myFile.print("Light level = ");
  myFile.println(value);
  myFile.print("Air Quality = ");
  myFile.print(sensorValue);
  myFile.println(" PPM ");
  myFile.print("Temperature = ");
  myFile.print(f);
  myFile.println(" *C ");
  myFile.print("humidity = ");
  myFile.print(h);
  myFile.println(" % ");
  myFile.println("DONE");
  myFile.println();
  myFile.close();
  Serial.println("Done.");
  digitalWrite(RED_PIN, HIGH);
  digitalWrite(RED_PIN, LOW);
  else {
    Serial.println("error opening Logger.txt");
Should "#define DHTPIN 2" not have been ""#define DHTPIN A2"?
I have been using the dht11 connected to D2
This makes no sense, since you are apparently reading the same pin..
thanks you for pointing that out, I have managed to make the pin correction and the logger now works :smiley: :smiley:
