Two arduino micro only one can be used
Hi.
I have created 3 button boxes to use with DCS. While using the leonardo and 1 micro i had no problems.
Now i made another one using a micro and the same base code i used before (on the other 2) but when i try to map commands to buttons i can only use one of the 2 micros. Also if i disconect one, the other gets the button mapping from the other.
Although they are the same model, they do have different iDs right? I also tried renaming the boards in regedit but the new name only shows in the device manager.
the first time i connect the board to the pc all the buttons worked, now i stopped working and the other shows with the same number of another.
#include <HID.h>
#include <Keypad.h>
#include <Joystick.h>
//DEFINITIONS
#define ENABLE_PULLUPS
#define NUMROTARIES 0  //replace "?" with number of rotary encoders you are using
#define NUMBUTTONS 24  //replace "?"with number of buttong you are using
#define NUMROWS 6      //replace "?" with number of rows you have
#define NUMCOLS 4      //replace "?" with number of columns you have
//BUTTON MATRIX
//first change number of rows and columns to match your button matrix,
//then replace all "?" with numbers (starting from 0)
byte buttons[NUMROWS][NUMCOLS] = {
  { 0, 1, 2, 4 },
  { 5, 6, 7, 8 },
  { 9, 10, 11, 12 },
  { 13, 14, 15, 16 },
  { 17, 18, 19, 20 },
  { 21, 22, 23, 24 }
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
//ROTARY ENCODERS
//each line controls a different rotary encoder
//the first two numbers refer to the pins the encoder is connected to
//the second two are the buttons each click of the encoder wil press
//do NOT exceed 31 for the final button number
rotariesdef rotaries[NUMROTARIES]{
  // {0,1,26,27,0}, //rotary 1
  //  {2,3,28,29,0}, //rotary 2
  // {4,5,23,24,0} //rotary 3
#define DIR_CCW 0x5
#define DIR_CW 0x10
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  { R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START },
  // R_CCW_BEGIN
  { R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START },
  // R_CW_BEGIN
  { R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START },
  // R_START_M (11)
  { R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START },
  // R_CW_BEGIN_M
  { R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW },
  // R_CCW_BEGIN_M
  { R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW },
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  { R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START },
  // R_CW_FINAL
  { R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW },
  // R_CW_BEGIN
  { R_CW_NEXT, R_CW_BEGIN, R_START, R_START },
  // R_CW_NEXT
  { R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START },
  // R_CCW_BEGIN
  { R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START },
  // R_CCW_FINAL
  { R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW },
  // R_CCW_NEXT
  { R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START },
#endif
//BUTTON MATRIX PART 2
byte rowPins[NUMROWS] = { 11, 10, 9, 8, 7, 6 };  //change "?" to the pins the rows of your button matrix are connected to
byte colPins[NUMCOLS] = { 2, 3, 4, 5 };          //change "?" to the pins the rows of your button matrix are connected to trocar a4 e a5
Keypad buttbx = Keypad(makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//JOYSTICK SETTINGS
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
                   JOYSTICK_TYPE_JOYSTICK,
                   24,  //number of buttons
                   0,   //number of hat switches
                   //Set as many axis to "true" as you have potentiometers for
                   false,   // y axis
                   false,   // x axis
                   false,   // z axis
                   false,   // rx axis
                   false,   // ry axis
                   false,   // rz axis
                   false,   // rudder
                   false,   // tot
                   false,   // accelerator
                   false,   // brake
                   false);  // steering wheel
const int numReadings = 20;
int readings[numReadings];  // the readings from the analog input
int index = 0;              // the index of the current reading
int total = 0;              // the running total
int currentOutputLevel = 0;
//POTENTIOMETERS PART 1
//add all the axis' which are enabled above
int yAxis_ = 0;  //posso mudar para o eixo q quiser, tipo xy para procurar alvo numa caixa
int xAxis_ = 0;
int zAxis_ = 0;
int rxAxis_ = 0;
//POTENTIOMETERS  PART 2
//Which pins are your potentiometers connected to?
int potentiometerPin1 = A0;  //Change "?" to the pin your potentiometer is connected to (acho q é o 4)
int potentiometerPin2 = A1;  //Change "?" to the pin your potentiometer is connected to (acho q é o 4)
int potentiometerPin3 = A2;  //Change "?" to the pin your potentiometer is connected to (acho q é o 4)
int potentiometerPin4 = A3;  //Change "?" to the pin your potentiometer is connected to (acho q é o 4)
const bool initAutoSendState = true;
  Joystick.begin();
  rotary_init();
  for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
  CheckAllEncoders();
  CheckAllButtons();
  CheckAllPotentiometers();
//POTENTIOMETERS PART 3
//change the details to match teh details above for each potentiometer you are using
void CheckAllPotentiometers() {
  //potentiometer 1
  currentOutputLevel = getAverageOutput(potentiometerPin1);
  yAxis_ = map(currentOutputLevel, 0, 1920, 0, 1920);
  Joystick.setYAxis(yAxis_);
  //potentiometer 2
  currentOutputLevel = getAverageOutput(potentiometerPin2);
  xAxis_ = map(currentOutputLevel, 0, 1023, 0, 255);
  Joystick.setXAxis(xAxis_);
  //potentiometer 3
  currentOutputLevel = getAverageOutput(potentiometerPin3);
  zAxis_ = map(currentOutputLevel, 0, 1920, 0, 1920);
  Joystick.setZAxis(zAxis_);
  //potentiometer 4
  currentOutputLevel = getAverageOutput(potentiometerPin4);
  rxAxis_ = map(currentOutputLevel, 0, 1023, 0, 255);
  Joystick.setRxAxis(rxAxis_);
int getAverageOutput(int pinToRead) {
  index = 0;
  total = 0;
  while (index < numReadings) {
    readings[index] = analogRead(pinToRead);
    total = total + readings[index];
    index = index + 1;
    //delay (1);
  return total / numReadings;
void CheckAllButtons(void) {
  if (buttbx.getKeys()) {
    for (int i = 0; i < LIST_MAX; i++) {
      if (buttbx.key[i].stateChanged) {
        switch (buttbx.key[i].kstate) {
          case PRESSED:
          case HOLD:
            Joystick.setButton(buttbx.key[i].kchar, 1);
          case RELEASED:
          case IDLE:
            Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i = 0; i < NUMROTARIES; i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
    digitalWrite(rotaries[i].pin1, HIGH);
    digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
  //Serial.print("Processing rotary: ");
  //Serial.println(_i);
  unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
  Serial.println("Checking rotaries");
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Serial.print("Rotary ");
      Serial.print(i);
      Serial.println(" <<< Going CCW");
      Joystick.setButton(rotaries[i].ccwchar, 1);
      delay(50);
      Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Serial.print(i);
      Serial.println(" >>> Going CW");
      Joystick.setButton(rotaries[i].cwchar, 1);
      delay(50);
      Joystick.setButton(rotaries[i].cwchar, 0);
  Serial.println("Done checking");
This is probably outside my area of knowledge.
What are IDs in this context? VID and PID will not change; two Leonardos will have the same VID and PID and so will two Arduino micros.
What is DCS?
(many of this subject in recent months)
digital combat simulator
the long chain of letters and number that appear next to the board name.
2023-09-20 at 12-44-34
on the other board the number starts at 5.
If i connect the first board the key mapping is there, if i disconnect it and plug in the second one it assumes the mapping from the previous one
2023-09-20 at 12-50-37
2023-09-20 at 12-50-08
