Hi All,
Newbie here.
Is it possible to run 2 arduino boards at the same time using the same MatLab code?
In short, I have an Arduino Uno running and collecting data from an IR break beam sensor. Now I am trying to time lock the onset of the IR Break Beam to the opening of a solenoid valve. I plan to control the solenoid valves with a PS12DC LabJack power switching board and an other Arduino Uno board.
Is this possible/practical?
Could you point me in the right direction?
Thanks!
It is unclear why you would need 2 Unos and how the communication with Matlab fits in. Perhaps you could describe your project in more detail.
What does this mean? Do you mean delay the solenoid for some time after the beam event?
Okay,
I need to deliver an odor via a pump to a receptacle and begin recording from my IR sensors at the same time. I am using an Uno to control the IR sensors, this takes 3 out of the 14 digital IO pins in my Uno. I use Matlab to control the board and record the resulting data.
The delivery of the odor happens after a solenoid valve is opened. I am using a PS12DC power switching board to control the solenoid valves, I just need to find a way to interface my power switching board with my computer so that I can switch the solenoid valve on and begin recording from the IR sensors at the same time. I have two options, one of it being using an Uno to interface with the power switching board. Ideally, I would control both my IR sensors and power switching board (solenoid valves) with a single Uno and the matlab code I already use to control and record data from my IR sensors. However, my IR senors already take up 3 out of the 14 digital pins in my Uno. The power switching board needs to use 12 of the digital ports plus a ground. (I will attach a PDF describing this connection).
https://labjack.com/sites/default/files/2014/05/LabJack-PS12DC-Datasheet-052014.pdf
I hope this is clearer.
Are you aware that the analog inputs are digital pins by default? They are 6 more digital pins (accessed as digital pins14-19).
I wasn't aware. It shouldn't make a difference then. I'll try this out, thanks!
