two arduino's, one neopixel led strip.
is it possible that two Arduino's could send data to one neopixel led strip?
what I want to happen is that the two Arduino's switch between who Is sending.
for example, Arduino 1 is sending data and they switch after 30 seconds, now Arduino 1 has stopped sending data and Arduino 2 is sending data. then after 30 seconds, they switch again. This repeats over and over.
I have made a schematic of this.
You can’t connect two outputs together so you must combine the signals somehow.
You can use a data select circuit made from four NAND or NOR gates ( one package ).
The data signal is normally high and gets pulled low so you could combine the signals with two open collector buffers and a pull up resistor.
However synchronising between two Arduinos can be tricky.
Why do you want to use two Arduinos anyway? Most problems can be tackled with one and it is a classic beginners mistake to consider using two.
Grumpy_Mike:
good to know. but could you draw me an example schematic?
I don't know how I could make such a circuit.
what I want is that the Arduino's don't send out at the same time. that's what I'm trying to say.
Grumpy_Mike:
I know that but on one Arduino I have a program that uses almost all the programming space. and this in my other knowledge couldn't find a way to reduce this. the code
So i had no space left for other animations and needed another Arduino.
Another "XY Problem" then. :roll_eyes:
If your code is only 3.61 KB then you should post it here if you want to discuss how to implement it. OK, I peeked - it seems you are reading data from an SD card. I can't see why it would occupy so much space. There does seem to be a code problem rather than a hardware issue.
If you really are short on code space, a good answer is to use an ESP8266 instead but simply ignore (switch off) its WiFi functionality. It is immensely cheaper than a larger Arduino and much more compact to boot as I suspect you desire.
A WeMOS D1 Mini would be a good board for the job! You will need a 74HCT14 buffer to drive NeoPixels.
When I compiled it I got
Sketch uses 14930 bytes (46%) of program storage space. Maximum is 32256 bytes.
Which is nowhere close to being all.
However, the dynamic memory is another matter:-
Global variables use 2075 bytes (101%) of dynamic memory, leaving -27 bytes for local variables. Maximum is 2048 bytes.
Which suggest you need more sram not another Uno. There are Arduinos with more memory, Paul mentioned just a few.
However the large number of LEDs are a problem. You have 360 LEDs and at a maximum of 60mA per LED this requires a current of 21.6 Amps. I note that you are reducing the brightness by a third so that reduces the maximum current to 7.2 Amps, but all from a USB socket!
Paul__B:
One problem I see is that there are two files open at once, which will allocate a lot of ram for file buffers. One is for searching the directory and the other for the actual data file, and could likely be reduced to only needing a single file open at a time.
If you are willing to use consistent and predictable names for your animation files, such as 001.BIN, 002,BIN, 003.BIN, etc, then there is really no need to do a directory search. Just start with the first file name, and open them sequentially, checking each time to see if the file actually exists.
