Two ATTiny45 via I2C
Hi, everybody!
I have one little project for home, so I decided to use ATTiny45 because of its size. The problem is that i cant use Wire libriary. So i dig a lot and found [this](http://playground.arduino.cc//Code/USIi2c). I wrote a code for master and slave, but...it doesnt work stable: LED is flashing not as I expect(500ms on, 500ms off), it can stay OFF for minutes and then turn ON for some seconds, for example. Can someone explain what I am doing wrong?
Pull-up 5k-resistors are set.
Code for master:
#include <TinyWireM.h>
void setup() {TinyWireM.begin();}
void loop(){
  delay(500); //a little delay for slave to get ready
  TinyWireM.beginTransmission(0x33); //start transmission to slave
  TinyWireM.send(0); //send him zero
  TinyWireM.endTransmission(); //finish transmission
  TinyWireM.send(1); //send him one
Code for slave:
#include <TinyWireS.h>
void setup(){
  pinMode(4, OUTPUT); //set pinMode for pin with LED
  TinyWireS.begin(0x33); //set adress for slave
void loop(){
  byte byteRcvd;
  if (TinyWireS.available()) //wait for master to start transmission
    byteRcvd = TinyWireS.receive(); //get a byte from master
    if (byteRcvd==1) {digitalWrite(4, HIGH);} //if byte was 1 then light up the led
    if (byteRcvd==0) {digitalWrite(4, LOW);} //if byte was 0 then light down the led
It looks like you send integers:
please try like this
TinyWireM.send("0"); //send him zero
same with receive
if (byteRcvd=="1")
wimb
Thanks for the answer, but no, program dont go that way. Function *TinyWireM.send* cant send char variable.
Any other ideas, please?
