Two Authentication Access System
Hello, I am trying to make a two authentication system (RFID and Fingerprint); the problem is when I scanned my fingerprint it keep showing "Fingerprint not recognized" even though I enrolled my fingerprint. Spoiler I am yet a beginner in coding, so pretty much I tried using chatGPT on creting this code.
-------Code--------
#include <Adafruit_Fingerprint.h>
#include <Servo.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#include <RTClib.h>
#define SS_PIN 10
#define RST_PIN 9
String UID = "F9 FC F4 14";
byte lock = 0;
Servo servo;
LiquidCrystal_I2C lcd(0x27, 16, 2);
MFRC522 rfid(SS_PIN, RST_PIN);
RTC_DS1307 rtc; // RTC object
// Define fingerprint sensor
SoftwareSerial mySerial(2, 3); // RX, TX
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
bool fingerprintScanned = false;
  mySerial.begin(57600); // Make sure this baud rate matches your fingerprint sensor module
  Serial.println("Initializing fingerprint sensor...");
  finger.begin(57600); // No need to check the return value
  servo.write(70);
  lcd.init();
  lcd.backlight();
  servo.attach(3);
  SPI.begin();
  rfid.PCD_Init();
  Wire.begin();
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  rtc.adjust(DateTime(__DATE__, __TIME__));
  lcd.setCursor(0, 0);
  lcd.print("Welcome!");
  lcd.setCursor(0, 1);
  lcd.print("Scan Your Card");
  if (!rfid.PICC_IsNewCardPresent())
    return;
  if (!rfid.PICC_ReadCardSerial())
    return;
  lcd.clear();
  lcd.print("Scanning RFID");
  Serial.print("NUID tag is :");
  String ID = "";
  for (byte i = 0; i < rfid.uid.size; i++) {
    lcd.print(".");
    ID.concat(String(rfid.uid.uidByte[i] < 0x10 ? " 0" : " "));
    ID.concat(String(rfid.uid.uidByte[i], HEX));
    delay(300);
  ID.toUpperCase();
  // Check if fingerprint scanning is in progress
  if (fingerprintScanned) {
    lcd.clear();
    lcd.print("Please wait...");
    delay(2000); // Adjust the delay as needed
    return;
  if (ID.substring(1) == UID && lock == 0) {
    servo.write(70);
    lcd.clear();
    lcd.print("Door is locked");
    delay(1500);
    lcd.clear();
    lock = 1;
  } else if (ID.substring(1) == UID && lock == 1) {
    // Trigger fingerprint scanning
    lcd.clear();
    lcd.print("Place finger...");
    delay(1500); // Adjust the delay as needed
    fingerprintScanned = checkFingerprint();
      servo.write(160);
      lcd.clear();
      lcd.print("Access Granted!");
      delay(1500);
      lcd.clear();
      lock = 0;
      lcd.clear();
      lcd.print("Fingerprint not recognized!");
      delay(1500);
      lcd.clear();
    lcd.clear();
    lcd.print("Denied Access!");
    delay(1500);
    lcd.clear();
  delay(3000);
  lcd.clear();
  lcd.print("Time: ");
  lcd.print(rtc.now().hour());
  lcd.print(":");
  lcd.print(rtc.now().minute());
  lcd.print(":");
  lcd.print(rtc.now().second());
  lcd.print("Date: ");
  lcd.print(rtc.now().year(), DEC);
  lcd.print("-");
  lcd.print(rtc.now().month(), DEC);
  lcd.print("-");
  lcd.print(rtc.now().day(), DEC);
  delay(5000);
bool checkFingerprint() {
  Serial.println("Getting fingerprint image...");
  uint8_t p = finger.getImage();
  Serial.println("Image capture result: " + String(p));
  if (p == FINGERPRINT_OK) {
    Serial.println("Converting image to template...");
    p = finger.image2Tz();
    Serial.println("Conversion result: " + String(p));
      Serial.println("Searching for fingerprint...");
      p = finger.fingerFastSearch();
      Serial.println("Search result: " + String(p));
        lcd.clear();
        lcd.print("Fingerprint recognized!");
        delay(1500);
        lcd.clear();
        fingerprintScanned = true; // Set flag to true
        return true;
        Serial.println("Finger search failed. Error code: " + String(p));
      Serial.println("Image to template conversion failed. Error code: " + String(p));
    Serial.println("Error capturing fingerprint image. Error code: " + String(p));
  Serial.println("Fingerprint not recognized!");
  return false;
Welcome to the forum
Have you tried asking chatGPT what is wrong and how to fix it ?
Yeah, but the output is still the same; so I tried separating the RFID and the Fingerprint and they worfed fine they can both turn the servo 90 degrees, the problem is when I try putting them together.
Don't give up, try again.
One answer could be 42. :grinning:
Yup, I will try and try again until this is good to go; but I'm intrigued on "42", what's that?
42 is the Answer to the Ultimate Question of Life, The Universe, and Everything.
chatGPT is only good for expert coders who understand when the AI is just spitting out crappy code...
if you are a beginner, instead of trying to fix code generated by chatGPT without having the knowledge, you should spend your time acquiring the necessary knowledge.
