I have been developing a small project for a MIDI controller. My code has been uploading and working fine, but just recently my Pro Micro 5V stopped responding. I decided to try uploading the sketch to another spare board and it has done the same to that one. It's possible I bricked them by setting the voltage wrong (3.3v instead of 5v in the processor menu), but I'm not sure at this stage)
I would like help if anyone is able, to revive my boards.
Apologies if I am making any rookie errors, I am new to both programming and hardware tinkering. Much of the code is butchered from existing examples, but it was working for a while!
Unfortunately I can't remember the last changes I made and am not using version control, so I am not sure what broke everything, but maybe someone more familiar with the hardware might be able to help.
The situation:
- Board does not show up in IDE
- Board does not show up as a USB device
- Green LED is lit solid, does not blink, red LED does not light
- Grounding RST pin does nothing, the light stays on (this seems very strange to me)
My setup:
- MacOS X Mojave
- Latest Arduino IDE
- Pro Micro Boards (left over from keyboard projects, sorry don't know exact origin)
- Not connected to any hardware (other than the incoming USB cable)
- 'Board' was originally set to 'Arduino Micro' because I didn't have the Sparkfun boards installed. I've installed those as part of the troubleshooting process. I've seen that setting the voltage wrong can brick your boards, it's possible this is what I did
Things I have tried:
- Grounding RST (no effect)
- Double tapping RST
- Using many different USB cables
Reading around it seems I may have bricked the controllers and need to replace the bootloader.
Thank you for any tips!
Update: I've found a third fresh Pro Micro. My question now - what can I do to avoid the same fate again, and is there anything I can do to retrieve the first two boards using the third?
My sketch in case it helps is below:
// This code is placed in the public domain by its author, Ian Harvey
// October 2016.
#include "MIDIUSB.h"
// Needs MIDIUSB library to be installed
static void MIDI_setup();
static void MIDI_noteOn(int ch, int note, int velocity);
static void MIDI_noteOff(int ch, int note);
const int MIDI_CHANNEL=1;
const int BAUD_RATE=115200;
const int scalePin = A0;
const int keyPin = A1;
const int NCHANNELS = 3;
const int KEYRANGE = 12; // Range in semitones
const int NSCALES = 10; // Number of modes/scales
const int BASENOTE = 50; // Lowest available note (MIDI number)
const int inPins[NCHANNELS] = { A2, A3};
const int thresholdLevel[NCHANNELS] = { 5, 5 }; // ADC reading to trigger; lower => more sensitive
const int maxLevel[NCHANNELS] = { 200, 200 }; // ADC reading for full velocity; lower => more sensitive
const int SCALES[NSCALES][9] = {
{0,2,4,5,7,9,11,12,14}, // Ionian, Major
{0,4,7,11,12,16,18,19,23}, // Aegean
{0,3,7,10,12,14,15,19,21}, // Voyager
{0,3,7,8,10,13,15,16,20}, // Equinox
{0,5,7,8,10,12,14,15,17}, // Dorian
{0,7,8,10,12,14,15,19,21}, // Phrygian
{0,5,7,8,12,13,17,19,20}, // Ake Bono
{0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0}
int midiNotes[NCHANNELS];
int scaleCounter;
int key;
int scale;
static unsigned int vmax[NCHANNELS] = { 0 };
static unsigned int trigLevel[NCHANNELS];
static unsigned int counter[NCHANNELS] = { 0 };
static unsigned int CTR_NOTEON = 10; // Roughly 5ms sampling peak voltage
static unsigned int CTR_NOTEOFF = CTR_NOTEON + 30; // Duration roughly 15ms
// 0 -> not triggered
// 1..CTR_NOTEON -> sampling note on
// CTR_NOTEON+1 .. CTR_NOTEOFF -> note off
static int statusPin = 2;
Serial.begin(BAUD_RATE);
analogReference(DEFAULT);
pinMode(statusPin, OUTPUT);
digitalWrite(statusPin, LOW);
for (int i = 0; i < NCHANNELS; i++)
pinMode(inPins[i], INPUT);
analogRead(inPins[i]);
trigLevel[i] = thresholdLevel[i];
MIDI_setup();
// volumeCheck();//check the volume knob
drumCheck();//check if any of the capacitive pads have been touched
// dcValCheck();//check the decay knob
// buttonCheck();//check for button presses to change the scale
scaleCounter++;
if(scaleCounter == 100);//check scale and key periodically
scaleCheck();
scaleCounter = 0;
// counter++;
// if(counter == 10000);//don't check battery all the time, slows opperation
// getBattery();
// counter = 0;
// oledPrint();//print to TeensyView
void scaleCheck() {
int sv = analogRead(scalePin);
int s = map(sv, 0, 1023, 0, NSCALES);
int kv = analogRead(keyPin);
int k = map(kv, 0, 1023, 0, KEYRANGE);
if ( s != scale || k != key )
int n;
for (n=0; n < NCHANNELS; n++)
midiNotes[n] = BASENOTE + k + SCALES[s][n];
s = scale;
k = key;
void drumCheck() {
int ch;
for (ch=0; ch < NCHANNELS; ch++)
unsigned int v = analogRead(inPins[ch]);
if ( counter[ch] == 0 )
if ( v >= trigLevel[ch] )
vmax[ch] = v;
counter[ch] = 1;
digitalWrite(statusPin, HIGH);
if ( v > vmax[ch] )
vmax[ch] = v;
counter[ch]++;
if ( counter[ch] == CTR_NOTEON )
long int vel = ((long int)vmax[ch]*127)/maxLevel[ch];
//Serial.println(vel);
if (vel < 5) vel = 5;
if (vel > 127) vel = 127;
MIDI_noteOn(MIDI_CHANNEL, midiNotes[ch], vel);
trigLevel[ch] = vmax[ch];
else if ( counter[ch] >= CTR_NOTEOFF )
MIDI_noteOff(MIDI_CHANNEL, midiNotes[ch]);
counter[ch] = 0;
// The signal from the piezo is a damped oscillation decaying with
// time constant 8-10ms. Prevent false retriggering by raising
// trigger level when first triggered, then decaying it to the
// threshold over several future samples.
trigLevel[ch] = ((trigLevel[ch] * 29) + (thresholdLevel[ch] * 1)) / 30;
// MIDI Code
// See https://www.midi.org/specifications/item/table-1-summary-of-midi-message
void MIDI_setup()
midiEventPacket_t noteOn = {0x09, 0x90 | (ch-1), note & 0x7F, velocity & 0x7F};
MidiUSB.sendMIDI(noteOn);
MidiUSB.flush();
midiEventPacket_t noteOff = {0x08, 0x80 | (ch-1), note, 1};
MidiUSB.sendMIDI(noteOff);
MidiUSB.flush();
