# Two-button clock
**URL:** <https://forum.arduino.cc/t/two-button-clock/393414>\
**Category:** Showcase\
**Created:** [June 22, 2016, 12:46pm UTC](https://forum.arduino.cc/t/two-button-clock/393414 "2016-06-22T12:46:55Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![odometer](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/odometer/32/1013044_2.png) [@odometer](https://forum.arduino.cc/u/odometer)\
**Post date:** [June 22, 2016, 12:46pm UTC](https://forum.arduino.cc/t/two-button-clock/393414/1 "2016-06-22T12:46:55Z")
</div>
If you are making a clock, and you would rather not recompile your code every time you want to set the time, here is a way you can do it using only two buttons.
Notes:
1. This code requires the use of an LCD character display, like for example [this one](https://www.adafruit.com/products/181), but the same basic idea would also work with other displays.
2. I have not yet written support for an external RTC. The point here is not to make a good clock, but rather to demonstrate a procedure for **setting** a clock.
3. Buttons are cheaper and easier to put in place than an external RTC. For "quick and dirty" projects, this code might be an acceptable substitute for an external RTC.
```cpp
// packed time  hhmmssff
uint32_t pt = 0x23594500; // intentionally bogus (for testing)
uint32_t last_tick_usec = 0UL;
const uint32_t ONE_TICK_USEC = 20000UL; // 0.02 second is plenty of resolution
const uint32_t ONE_TICK_PACKED = 0x00000002; // see previous line
char buf[50]; // this is intentionally bigger than I need
uint8_t set_state = 0;
// set_state indicates what is currently being set, as follows:
// 7 for hour tens,   6 for hour ones,
// 5 for minute tens, 4 for minute ones,
// 3 for second tens, 2 for second ones,
// 1 for normal timekeeping mode (i.e. finished setting the time)
// and it is 0 if the time has not yet been set
const uint32_t TIME_SET_MAX = 0x29595999;
// each digit is at max possible value for time
const uint8_t BUTTON_PIN_A = 9; // this button moves the cursor
const uint8_t BUTTON_PIN_B = 8; // this button makes the numbers change
uint8_t button_a_now;
uint8_t button_a_last;
uint8_t button_b_now;
uint8_t button_b_last;
#include <LiquidCrystal.h>
//                RS  EN DB4 DB5 DB6 DB7
LiquidCrystal lcd( 7,  6,  5,  4,  3,  2);
  pinMode(BUTTON_PIN_A, INPUT_PULLUP);
  pinMode(BUTTON_PIN_B, INPUT_PULLUP);
  // pressing either button makes its pin's voltage go low
  button_a_now = (digitalRead(BUTTON_PIN_A)==LOW);
  button_a_last = button_a_now;
  button_b_now = (digitalRead(BUTTON_PIN_B)==LOW);
  button_b_last = button_b_now;
  lcd.begin(16, 2); // LCD dimensions
  disptime();
  // remember, pressing either button makes its pin's voltage go low
  // has either button just been pushed down?
  uint8_t pushed_a = (button_a_now && !button_a_last);
  uint8_t pushed_b = (button_b_now && !button_b_last);
  // what happens next depends on what mode we're in
  if (set_state <= 1) {
    // if we're in here, then the clock is running
    if (pushed_a) {
      // enter time setting mode
      pt &= 0xFFFFFF00;
      set_state = 7;
      disptime();
    else {
      // this is what makes the clock actually keep track of time
      uint32_t old_pt = pt;
      while ((micros()-last_tick_usec)>=ONE_TICK_USEC) {
        // figure out how much time has passed
        last_tick_usec += ONE_TICK_USEC;
        pt = timeAdd(pt, ONE_TICK_PACKED);
      if ((((pt+0x00000030)^(old_pt+0x00000030))&0xFFFFFF80)!=((uint32_t)0)) {
        // the magic in the previous line means "do this once every 1/2 second"
        if (pt>=0x24000000) {
          pt = timeSub(pt, 0x24000000);
          // when I implement a calendar, I will put code here to advance the date
        disptime();
  else if ((set_state >= 2) && (set_state <= 7)) {
    // if we're in here, then we're in the midst of setting the time
    if (pushed_a) {
      // move the cursor
      set_state--;
        // if we're finished setting the time, we start the clock running
        last_tick_usec = micros();
      disptime();
    else if (pushed_b) {
      // change the number that the cursor is pointing to
      // (that is, the number itself gets changed; the cursor does not move)
      uint32_t digit_mask = (((uint32_t)0x0000000F)<<(4*set_state));
      if ((pt & digit_mask) >= (TIME_SET_MAX & digit_mask)) pt &= ~digit_mask;
      else pt += (digit_mask & 0x11111111);
      // show the new time
      disptime();
  delay(10); // poor man's switch debounce
void disptime() {
  // set cursor to beginning of top row
  lcd.setCursor(0, 0);
  //                                01234567890123456
  if      (set_state==0) lcd.print("Set me, please! ");
  else if (set_state==1) lcd.print("Current time:   ");
  else if (set_state<=7) lcd.print("Set the time:   ");
  else                   lcd.print("Oops, Error!    ");
  // set cursor to beginning of bottom row
  lcd.setCursor(0, 1);
  // make "tick-tock" animation
  char ticky = ' ';
  if ((set_state == 0) && (((byte)pt) < 0x50)) ticky = '?';
  if ((set_state == 1) && (((byte)pt) < 0x50)) ticky = '.';
  //                                                    0123456789012345
  // show the time on the display, using this format:   HH:MM:SS.
  //            01  234  567  8 90123456
  sprintf(buf, "%02x:%02x:%02x%c       ", ((byte)(pt>>24)), ((byte)(pt>>16)), ((byte)(pt>>8)), ticky);
  lcd.print(buf);
  switch (set_state) {
    case 7: lcd.setCursor(0, 1); lcd.cursor(); break; // cursor under hour tens
    case 6: lcd.setCursor(1, 1); lcd.cursor(); break; // cursor under hour ones
    case 5: lcd.setCursor(3, 1); lcd.cursor(); break; // cursor under minute tens
    case 4: lcd.setCursor(4, 1); lcd.cursor(); break; // cursor under minute ones
    case 3: lcd.setCursor(6, 1); lcd.cursor(); break; // cursor under second tens
    case 2: lcd.setCursor(7, 1); lcd.cursor(); break; // cursor under second ones
    default: lcd.noCursor();                          // if not seting the time, then no cursor
// some old time manipulation functions I dug up for this
uint32_t timeAdd (uint32_t x, uint32_t y) {
  // no sanity checking of input
  // format is hhmmssff with ff being decimal fractions of a second
  // "out of range" results are e.g. A0000000 for 100 hours
  uint32_t binsum = x + y;
  uint32_t carry = ((binsum + 0x06A6A666) ^ x ^ y) & 0x11111110;
  return (binsum + ((carry - (carry>>4)) & 0x06A6A666));
uint32_t timeSub (uint32_t x, uint32_t y) {
  // "negative" results are e.g. F9595999 for -0.01 second
  uint32_t bindiff = x - y;
  uint32_t borrow = (bindiff ^ x ^ y) & 0x11111110;
  return (bindiff - ((borrow - (borrow>>4)) & 0x06A6A666) );
   Usage example:
   2 h 58 min 30.98 s --> 0x02583098
   0 h  1 min 44.06 s --> 0x00014406
   Addition:
   timeAdd(0x02583098, 0x00014406) gives 0x03001504
                             which means 3 h 0 min 15.04 s
   Subtraction:
   timeSub(0x02583098, 0x00014406) gives 0x02564692
                             which means 2 h 56 min 46.92 s
**Author:** ![stievenart](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/stievenart/32/223491_2.png) [@stievenart](https://forum.arduino.cc/u/stievenart)\
**Post date:** [June 25, 2016, 4:28am UTC](https://forum.arduino.cc/t/two-button-clock/393414/2 "2016-06-25T04:28:34Z")
</div>
Hello odometer,
Which RTC clock chip are you using. I see no reference in you code or the body of your post. I am working on a DS1307 2-button and was looking for inspiration.
Thanks in advance and I apologize if I just missed the information,
stievenart
**Post date:** [June 26, 2016, 2:50am UTC](https://forum.arduino.cc/t/two-button-clock/393414/3 "2016-06-26T02:50:55Z")
</div>
> stievenart:
There is no reference because there is no external RTC.
**Post date:** [June 26, 2016, 10:28pm UTC](https://forum.arduino.cc/t/two-button-clock/393414/4 "2016-06-26T22:28:21Z")
</div>
I did some work on support for the date as well as the time.
Here is what I have so far.
**Note: This is a work in progress.** It might well contain bugs I haven't found yet. It also isn't as "clean" as it could be.
[settable\_clock\_test\_2c.ino](https://forum.arduino.cc/uploads/short-url/3wxhX8vodgsZi4ri1EyOHynDUE2.ino) (11 KB)
**Post date:** [June 30, 2016, 2:06pm UTC](https://forum.arduino.cc/t/two-button-clock/393414/5 "2016-06-30T14:06:15Z")
</div>
Here is what I have now.
This will work with or without an external RTC.
Disclaimer: I finished this version only a few hours ago so it might have bugs.
[settable\_clock\_test\_2d\_bkup\_5.ino](https://forum.arduino.cc/uploads/short-url/xnQ8qa43cVeuYlUdTNlNHfD9n0k.ino) (14 KB)
**Post date:** [July 1, 2016, 9:48pm UTC](https://forum.arduino.cc/t/two-button-clock/393414/6 "2016-07-01T21:48:29Z")
</div>
I sort of cleaned up what I had, and now here is what I have.
Features:
- Date and time display, crammed into one line of a 16x2 character LCD
- Date and time manually settable by means of two push buttons
- Support for an external RTC, but will still run without an RTC
Limitations:
- No support for Daylight Saving Time
- No sanity checking of dates (it will happily let you set the date to Feb. 30)
- No alarms, no bells, no whistles, just the date and time
[settable\_clock\_optional\_rtc.ino](https://forum.arduino.cc/uploads/short-url/wZCBBJkRnxb9oz8toTEjydj4dV2.ino) (15.3 KB)
**Post date:** [July 11, 2016, 6:09am UTC](https://forum.arduino.cc/t/two-button-clock/393414/7 "2016-07-11T06:09:10Z")
</div>
Now it chimes the hours, too. (Yes, I know, feature creep.)
**Note #1:** The chimes use [the ToneAC library](http://playground.arduino.cc/Code/ToneAC).
**Note #2:** In order to make room for the speaker, I had to move the buttons to different pins. See comments in the code.
[settable\_clock\_optional\_rtc\_m2.ino](https://forum.arduino.cc/uploads/short-url/lHhKg7wbHgaMs1nMNulsk99HzRc.ino) (17.6 KB)
**Post date:** [May 6, 2021, 12:35pm UTC](https://forum.arduino.cc/t/two-button-clock/393414/8 "2021-05-06T12:35:29Z")
</div>
Closed on May 6, 2021, 12:35pm UTC
