Two Button Tie - Computers dont "do" Tie
I have written code to execute a special action in the event two buttons become pressed within a defined "tie" parameter (in this case 1 second). Can this be done better?
//TWO BUTTONS - How to define and act upon a Tie
const int button1 = 2;
const int button2 = 3;
const int buttonDelay = 300;   // button bounce mitigation
unsigned long buttonTime = 0;   // button bounce mitigation
byte button1State = 0;   //variable and initial state for Tie
byte button2State = 0;
byte tieState = 0;   //variable to trigger Tie action
const int tieDelay = 1000;   // button bounce mitigation
unsigned long tieTime = 0;   // button bounce mitigation
   pinMode(button1, INPUT_PULLUP);   // pushbutton pins are high and use built-in resistor
   pinMode(button2, INPUT_PULLUP);
   // read buttons and set buttonStates
   if (millis() - buttonTime >= buttonDelay)   // button bounce mitigation
      if (digitalRead(button1) == LOW)    // button1 is pressed
      button1State = 1;
      if (digitalRead(button2) == LOW)    // button2 is pressed
      button2State = 1;
   if ((button1State == 1) && (button2State == 1))
   tieState = 1;
   // action if only button1 pressed after a second
   if (millis() - tieTime >= tieDelay)   // second to check for tie
         if ((button1State == 1) && (tieState = 0))    // button1 is pressed
	   //Put button1 action here
         button1State = 0;
         button2State = 0;
         tieState = 0;
         buttonTime >= buttonDelay;
         tieTime >= tieDelay;
  // action if only button2 pressed after a second
         if ((button2State == 1) && (tieState = 0))    // button2 is pressed
	   //Put button2 action here
         button1State = 0;
         button2State = 0;
         tieState = 0;
  // action in the event of a tie
   if (tieState = 1)    // tie is recorded
     //Put tie action here
    button1State = 0;
    button2State = 0;
    tieState = 0;
It's unusual to see an assignment in an if statement.
You need to completely restructure the code. Look at the state change detection example. You need to record when each switch BECOMES pressed, and then, if both are pressed, determine the interval (positive or negative) between the events.
Typo. Should be single = (assignment operator)
mchandeysson:
Wrong. There should be two == in that statement.
Even better. Please don't facepalm. You're really helping.
The expression in this if() statement will never evaluate to true and the block will never get executed.
