Hello'
I am new with arduino. I have arduino uno board and want run 2 continuous servo motor with one joystick (2 axis). But instead of using two axis of the joystick, I want want to use only one axis of the joystick to rotate 2 continuous servo motor which I apply to drive a car and gradually wanted to vary the speed of continuous motors.. Please help....
So you want to use the joystick as a throttle.
Tom.... ![]()
The below might be close to what you want. I don't have servos or pots to test now, so the below may/may not work.
//zoomkat 8-21-15 pot servo test
//opposite side servos rotate together
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2;
int potpinS1 = 0; //analog input pin A0
int newvalS1, oldvalS1;
myservo1.attach(8);
myservo2.attach(9);
Serial.println("servo joystick test"); // so I can keep track of what is loaded
newvalS1 = analogRead(potpinS1);
newvalS1 = map(newvalS1, 0, 1023, 70, 110); //servo operating band
//add some dead band
if (newvalS1 < (oldvalS1-1) || newvalS1 > (oldvalS1+1)){
//value sent to servos
Serial.println(newvalS1);
myservo1.write(newvalS1);
Serial.println(180-newvalS1);
myservo2.write(180-newvalS1);
Serial.println(); //seperate values in serial monitor
oldvalS1=newvalS1;
delay(50); //slow down looping to better read serial monitor
Thanks for the programming #Zoomkat. But the programming is applicable for Normal servo motor. Can not run the continuous servo motor (parallax).. Please help. I'm attaching the data sheet of continuous servo motor.
TomGeorge:
So you want to use the joystick as a throttle.Tom....
Yes TOM.. Can you help???
