I am doing an online class and currently I am learning how to use a 4x4 keypad as a passcode. I copied the example code the class gave me perfectly and when I went to verify it gave me the: "'validatePIN' was not declared in this scope" validatePIN is never declared in the example code. Then I decided to copy paste the example code into a sketch and it verified where my code did not. I have no idea how this could happen. If I made a mistake and my code is not the same please let me know. Here is the code.
#include <Keypad.h>
#include "Arduino.h"
const byte ROWS = 4;
const byte COLS = 4;
const byte PIN_LENGTH = 4; //pin code is 4 button presse
char current_pin[PIN_LENGTH] = { '0', '0', '0', '0' };
* Character Type (char)
* In Arduino C++ we have previously used strings of characters using double quotes
* ("my string"). But for a single character we need to use single quotes to indicate that there
* is just ONE character ('A').
const char BUTTONS[ROWS][COLS] = {
{'1', '2', '3', 'A' },
{'4', '5', '6', 'B' },
{'7', '8', '9', 'C' },
{'*', '0', '#', 'D' },
const byte ROWS_PINS[ROWS] = {5, 4, 3, 2 };
const byte COLS_PINS[COLS] = {6, 7, 8, 9 };
//Define row and column pins driving the keypad
Keypad heroKeypad = Keypad(makeKeymap(BUTTONS), ROWS_PINS, COLS_PINS, ROWS, COLS );
const byte BUZZER_PIN = 10;
pinMode(BUZZER_PIN, OUTPUT);
delay(200); // delay a brief period to let things settle before displaying prompt.
Serial.println("Press * to enter new PIN or # to access the system.");
char button_character = heroKeypad.waitForKey();
//serial.println(button_character);
tone(BUZZER_PIN, 880, 100);
if (button_character == '#') { //button to access the system
bool access_allowed = validatePIN();
if (access_allowed) {
Serial.println ("Welcome, authorized user. You may now begin using the system.");
}} else {
Serial.println("Access Denied. ");
Serial.println("\nPress * to enter new PIN or # to access the system. ");
if (button_character == '*') { //button to change PIN
Serial.println("WELCOME, Authorized user. Please enter a new PIN: ");
for (int i = 0; i < PIN_LENGTH; i++) {
button_character = heroKeypade.waitForKey();
curren_pin[i] = button_character;
Serial.print("*");
Serial.println(); // add new line after last asterisk so next message is on next line
Serial.println("PIN Successfully Changed! ");
} else{
Serial.println("ACCESS DENIED. Cannot change PIN without the old or default PIN.")
Serial.println("\nPress * to enter new PIN or # to access the system.");
// \n means "new line"
* This function prompts the used ot enter a PIN and returns true or false depending
* on whether the PIN mathces our saved PIN.
* NOTE: this function indroduces the concept of a function that returns a signle
* value. First, we must indicate what type of value that will be returned
* in the initial fintion declaration. the "bool" at the beginning of
* the declaration indicates that this function will return a "boolean" value
* of either true or false.
bool validatePIN() {
Serial.println("Enter PIN to continue.");
tone (BUZZER_PIN, 880, 100);
if (current_pin[i] != button_character) {
Serial.prinln();
Serial.print("WRONG PIN DIGIT: ");
Serial.println(button_character);
return false; //reutrn false and exit function
Serial.print("*");
Serial.println(); //add new lline afer last asterisk so next message is on new line
Serial.println("Deivice Successfully Unlocked!");
return true;
And this is what the example lesson looks like:
// Include Keypad library#include <Keypad.h>
#include <Keypad.h>
// Our HERO keypad has 4 rows, each with 4 columns.
const byte PIN_LENGTH = 4; // PIN code is 4 button presses
char current_pin[PIN_LENGTH] = { '0', '0', '0', '0' }; // Initial PIN is four zeros.
// Define what characters will be returned by each button
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ '*', '0', '#', 'D' }
// Define row and column pins connected to the keypad
const byte ROW_PINS[ROWS] = { 5, 4, 3, 2 };
const byte COL_PINS[COLS] = { 6, 7, 8, 9 };
Keypad heroKeypad = Keypad(makeKeymap(BUTTONS), ROW_PINS, COL_PINS, ROWS, COLS);
const byte BUZZER_PIN = 10; // pin 10 drives the buzzer
Serial.begin(9600); // Begin monitoring via the serial monitor
delay(200); // Delay a brief period to let things settle before displaying prompt.
// Serial.println(button_character);
if (button_character == '#') { // button to access system
Serial.println("Welcome, authorized user. You may now begin using the system.");
Serial.println("Access Denied.");
if (button_character == '*') { // button to change PIN
Serial.println("Welcome, authorized user. Please Enter a new PIN: ");
current_pin[i] = button_character;
Serial.print("*");
Serial.println("PIN Successfully Changed!");
Serial.println("Access Denied. Cannot change PIN without the old or default.");
* This function prompts the user to enter a PIN and returns true or false depending
* on whether the PIN matches our saved PIN.
* NOTE: this function introduces the concept of a function that returns a single
* in the initial function declaration. The "bool" at the beginning of
Serial.println(); // start next message on new line
return false; // return false and exit function
Serial.print("*");
Serial.println("Device Successfully Unlocked!");
return true;
