Two DC motor and timer setup
I'm using a L298N Motor controller to run two dc motors. I got that to work, but I need help to find out how to set timer in conjunction to delay before starting the motors. I'm aiming for a timer to run for five minutes, after which the motors should start. This is what I have so far.
//L298N
//Motor A
const int motorPin1 = 9; // Pin 14 of L293
const int motorPin2 = 10; // Pin 10 of L293
//Motor B
const int motorPin3 = 6; // Pin 7 of L293
const int motorPin4 = 5; // Pin 2 of L293
int sensorPin = A0; // select the input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
int pwmVal;
//This will run only one time.
void loop(){
//Set pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
//Motor Control - Motor A: motorPin1,motorpin2 & Motor B: motorpin3,motorpin4
//This code will turn Motor A clockwise for 2 sec.
analogWrite(motorPin1, 180);
analogWrite(motorPin2, 0);
analogWrite(motorPin3, 180);
analogWrite(motorPin4, 0);
//This code will turn Motor A counter-clockwise for 2 sec.
analogWrite(motorPin1, 0);
analogWrite(motorPin2, 180);
analogWrite(motorPin3, 0);
analogWrite(motorPin4, 180);
//And this code will stop motors
You need a setup() function, these go in it:
void setup(){ // stuff that runs once
delay (300000); // dumb 5 minute delay
// then the motor run code
    delay(1000);   // <<< that's only 1 second
// and finish with an empty void loop
void loop(){
// do nothing - or maybe do something?
If you wanted to do it smarter, have other things going on while the 5 minutes elapsed, you would use Blink Without Delay code technique within loop() to watch the time passing, when 5 minutes had gone by then run the motor code, with dumb 2 second delay or with more time watching code so other activities could still go on.
