Two different libraries with same name for same project
Hello to everybody,
I am working in a project with the accelerometer MPU6050 and to filter the data I found two libraries "kalman.h", one for the angles and one for the accelerations but I am not able to insert both in the project. How can I do?
(deleted)
Surely the obvious solution is to change the name of one of the libraries?
...R
Post a link to where you got the libraries from. Please use the chain links icon on the toolbar to make it clickable. Or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
Robin2:
...R
What if they're two copies of the same library?
Robin2:
...R
What if some of the functions in the two libraries also share the same names?
We need A LOT more info if you want any help.
--DH
And if they're both (presumably) kalman filters, why in the world do you need two?
Delta_G:
I believe the OP said they are not.
...R
The project is to extract the trajectories from the measurements of accelerations and rotations of the MPU-6050, i started from the example of a librarie about the kalman filter speciphic for the filtering of the angles of this accelerometer (GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope.), than i found a second librarie called always Kalman.h (GitHub - bachagas/Kalman: A simplified one dimensional Kalman filter implementation for Arduino.) in which the filter is more general and appliable to the accelerations. I tried to use the example of the first librarie to filter the angles and than to add the second librarie to filter the accelerations. I tried to give a different name to the libraries but it gives me aways error when i use the functions of both libraries.
Here there is the code of the example:
#include <Wire.h>
#include <Kalman.h> // Source: GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope.
#define RESTRICT_PITCH // Comment out to restrict roll to ±90deg instead - please read: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
Kalman kalmanX; // Create the Kalman instances
Kalman kalmanY;
/* IMU Data */
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
int16_t tempRaw;
double gyroXangle, gyroYangle; // Angle calculate using the gyro only
double compAngleX, compAngleY; // Calculated angle using a complementary filter
double kalAngleX, kalAngleY; // Calculated angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Make calibration routine
Wire.begin();
#if ARDUINO >= 157
Wire.setClock(400000UL); // Set I2C frequency to 400kHz
#else
TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz
#endif
i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once
while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
while (i2cRead(0x75, i2cData, 1));
if (i2cData[0] != 0x68) { // Read “WHO_AM_I” register
Serial.print(F(“Error reading sensor”));
while (1);
delay(100); // Wait for sensor to stabilize
/* Set kalman and gyro starting angle */
while (i2cRead(0x3B, i2cData, 6));
accX = (int16_t)((i2cData[0] << 8) | i2cData[1]);
accY = (int16_t)((i2cData[2] << 8) | i2cData[3]);
accZ = (int16_t)((i2cData[4] << 8) | i2cData[5]);
// Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26
// atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
// It is then converted from radians to degrees
#ifdef RESTRICT_PITCH // Eq. 25 and 26
double roll = atan2(accY, accZ) * RAD_TO_DEG;
double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else // Eq. 28 and 29
double roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
kalmanX.setAngle(roll); // Set starting angle
kalmanY.setAngle(pitch);
gyroXangle = roll;
gyroYangle = pitch;
compAngleX = roll;
compAngleY = pitch;
timer = micros();
/* Update all the values */
while (i2cRead(0x3B, i2cData, 14));
tempRaw = (int16_t)((i2cData[6] << 8) | i2cData[7]);
gyroX = (int16_t)((i2cData[8] << 8) | i2cData[9]);
gyroY = (int16_t)((i2cData[10] << 8) | i2cData[11]);
gyroZ = (int16_t)((i2cData[12] << 8) | i2cData[13]);;
double dt = (double)(micros() - timer) / 1000000; // Calculate delta time
timer = micros();
#endif
double gyroXrate = gyroX / 131.0; // Convert to deg/s
double gyroYrate = gyroY / 131.0; // Convert to deg/s
// This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
compAngleX = roll;
kalAngleX = roll;
gyroXangle = roll;
} else
kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
if (abs(kalAngleX) > 90)
gyroYrate = -gyroYrate; // Invert rate, so it fits the restriced accelerometer reading
kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);
#else
if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
compAngleY = pitch;
kalAngleY = pitch;
gyroYangle = pitch;
} else
kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
if (abs(kalAngleY) > 90)
gyroXrate = -gyroXrate; // Invert rate, so it fits the restriced accelerometer reading
#endif
gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
gyroYangle += gyroYrate * dt;
//gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate
//gyroYangle += kalmanY.getRate() * dt;
compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
// Reset the gyro angle when it has drifted too much
if (gyroXangle < -180 || gyroXangle > 180)
gyroXangle = kalAngleX;
if (gyroYangle < -180 || gyroYangle > 180)
gyroYangle = kalAngleY;
/* Print Data */
#if 0 // Set to 1 to activate
Serial.print(accX); Serial.print("\t");
Serial.print(accY); Serial.print("\t");
Serial.print(accZ); Serial.print("\t");
Serial.print(gyroX); Serial.print("\t");
Serial.print(gyroY); Serial.print("\t");
Serial.print(gyroZ); Serial.print("\t");
Serial.print("\t");
#endif
Serial.print(roll); Serial.print("\t");
Serial.print(gyroXangle); Serial.print("\t");
Serial.print(compAngleX); Serial.print("\t");
Serial.print(kalAngleX); Serial.print("\t");
Serial.print("\t");
Serial.print(pitch); Serial.print("\t");
Serial.print(gyroYangle); Serial.print("\t");
Serial.print(compAngleY); Serial.print("\t");
Serial.print(kalAngleY); Serial.print("\t");
#if 0 // Set to 1 to print the temperature
Serial.print("\t");
double temperature = (double)tempRaw / 340.0 + 36.53;
Serial.print(temperature); Serial.print("\t");
#endif
Serial.print("\r\n");
delay(2);
Please read: Read this before posting a programming question ....
In particular, note Item #6 about using CODE TAGS.
gfvalvo is right, code tags are there for a reason, please use them. They make our lives so much easier.
Also, please show us your exact error message and code where you tried using them both as well as the other library and please label them clearly.
One last suggestion, try using the auto-format button in the Arduino IDE. It will make it easier for everyone (yourself included) to understand your code.
--DH
Sorry for the errors in the presentation of the messages.
Here there is the code that i tried to implement
#include <Wire.h>
#include <Kalman.h> // Source: https://github.com/TKJElectronics/KalmanFilter
#include <Kalman_master>
Kalman kalmanY;
Kalman kalAx, kalAy, kalAz;
/* IMU Data */
int16_t tempRaw;
double roll, pitch;
double ax, ay, az;
double vx, vy, vz = 0;
uint32_t timer;
  Wire.beginTransmission(0x68);
  Wire.write(0x1A);  // the config address
  Wire.write(0x06);  // the config value high pass filter (fc = 5 Hz)
  Wire.endTransmission(true);
  Wire.begin();
#if ARDUINO >= 157
  Wire.setClock(100000UL); // Set I2C frequency to 100kHz
#else
  TWBR = ((F_CPU / 100000UL) - 16) / 2; // Set I2C frequency to 100kHz
#endif
  if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register
    Serial.print(F("Error reading sensor"));
    while (1);
 /* Set Kalman and gyro starting angle */
  kalmanX.setAngle(roll); // First set roll starting angle
  gyroXangle = roll;
  kalmanY.setAngle(pitch); // Then pitch
  gyroYangle = pitch;
  // THIS PART DEFINES THE STARTING ANGLES
#endif
  gyroXangle = roll;
  gyroYangle = pitch;
  timer = micros();
  timer = micros();
#endif
  accX = (accX/16384); //Convert to g
  accY = (accY/16384); //Convert to g
  accZ = (accZ/16384); //Convert to g
    kalAngleX = roll;
    gyroXangle = roll;
  } else
#else
    kalAngleY = pitch;
    gyroYangle = pitch;
  } else
#endif
  double kalAx = kalAngleX * DEG_TO_RAD;
  // Rempoving gravity component on Z
  if (abs(kalAx) < (90* DEG_TO_RAD)){
    if (accZ >= 0){
       accZ = accZ - (1 * cos(kalAx));
       accZ = accZ + (1 * cos(kalAx));
       if (accZ >= 0){
  // Rempoving gravity component on Y
  if (kalAx > 0 ){
       accY = accY - (1* sin(kalAx));
  ay = accY * 9.80;
  az = accZ * 9.80 ;
  ax = kalAx.getFilteredValue(accX);
  ay = kalAy.getFilteredValue(accY);
  az = kalAz.getFilteredValue(accZ);
    vx = vx + (accX * dt); // Calculate velocities
    vy = vy + (accY * dt);
    vz = vz + (accZ * dt);
  /* Print Data */
  Serial.print("\t");
#endif
 /* Serial.print("Angle (deg):"); Serial.print("\t");
  Serial.print("X = ");
  Serial.print(kalAngleX); Serial.println("\t");
  Serial.print("Y = ");
  Serial.println(kalAngleY);
 */ Serial.print(" Accel (cm/s^2)"); Serial.print("\t");
 // Serial.print(" X= ");
 // Serial.print(accX); Serial.print("\t");
  Serial.print(" Y= ");
  Serial.print(ay); Serial.print("\t");
  Serial.print(" Z= ");
  Serial.println(az);
/*  Serial.print(" Vel (m/s)"); Serial.print("\t");
  Serial.print(vx); Serial.print("\t");
  Serial.print(vy); Serial.print("\t");
  Serial.println(vz);
  Serial.print("\t");
#endif
I tried to modify the name but it gaved me the same errors:
 exit status 1
'class Kalman' has no member named 'getFilteredValue'
or
 exit status 1
Error compiling for board Arduino/Genuino Uno.
(deleted)
I posted the links in the first message but ok:
  1. GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate an
  2. GitHub - bachagas/Kalman: A simplified one dimensional Kalman filter implementation for Arduino.</
  3. is a library for the kalman filter speciphic for the angles, 2. is a library with a general kalman filter for the accelerations
Did you try putting “.h” at the end of the second library like this?
#include <Kalman_master.h>
Yes, i tried. Sorry that I forgot to insert the .h when i sent it here because i restarted from the initial example.
You are #including Kalman_master.h but don't appear to create any objects using that library
