Two different problems, starting with simple temperature regulator
I'm working on a project that will extrude recycled pellets, and I have 2 problems with it:
  1. I need to make a simple temperature regulator that will turn on and off the heater, and I just want to use something simple. So far, my idea is to use a delay_until( temperature_sensor == 250 C) sort of function (if that's even a function), but I will take any other function that works.
  2. This is less important, but this idea is to make a settings menu that controls the temperature of the extruder, and that will automatically stop and sound an alarm when the pellets run out via an ir
    sensor, if that's even possible, because I heard that an Arduino can't multitask.
Any answers accepted!!
This is a fairly easy project to deliver... even for a relative beginner.
Well it can't do 2 things at exactly the same time, but it can easily manage to do things so fast that you would think it was. Micro-controllers are incredibly fast... so the technique is to loop quickly around all the things that need to be done, so that they appear to all be done at once.
First place to start is to get a really clear idea about how everything should work. A clear set of requirements is key.
Then start looking for suitable hardware components. e.g. a temperature sensor that can handle 250C.
Then get each one working individually. There are lots of tutorials available.
Then bring it all together.
There are lot of great examples out there, and lots of people on this forum that will help.
If this is for an industrial process my approach would be to get this working first
we need to know more about your experience with arduino, and also the hardware you will be using. - so what the heater is and how you will turn the heater on & off.
Well right now I'm simulating it on Tinkercad so I have no real hardware, but I'm using a 5v relay to control the heater and motor, with 3 buttons. Here is (so far) my code:
//This is written in C++
//#include <EEPROM.h>
#include <Adafruit_LiquidCrystal.h>
 //#define buttonhome 11
 #define buttonstart 10
 #define buttonsettings 9
 #define buttonminus 8
 #define thermistorPin A0
 #define heaterSwitch 3
 #define motorSwitch 2
 #define pinTemp A0
Adafruit_LiquidCrystal lcd_1(0);
  int startPressed = digitalRead(buttonstart);
  int setPressed = digitalRead(buttonsettings);
  int minPressed = digitalRead(buttonminus);
  float sensorInput;
  float temp;
  pinMode(buttonminus, INPUT);
  pinMode(buttonsettings, INPUT);
  pinMode(buttonstart, INPUT);
  pinMode(heaterSwitch, OUTPUT);
  digitalWrite(heaterSwitch, HIGH);
  pinMode(motorSwitch, OUTPUT);
  digitalWrite(motorSwitch, HIGH);
  lcd_1.begin(16, 2);
  buttonStart = digitalRead(8);
  buttonSettings = digitalRead(9);
  buttonMinus = digitalRead(10);
  int heaterThresh = 240;
  /*int buttonStart = 0;
  int buttonSettings = 0;
  int buttonMinus = 0;
  lcd_1.setCursor(0, 0);
  lcd_1.print("Arduino Extruder");
  lcd_1.setCursor(0, 1);
  lcd_1.print("          V1.0.2");
  delay(2500); // Wait for 2500 millisecond(s)
  lcd_1.scrollDisplayLeft();
  delay(90); // Wait for 90 millisecond(s)
  lcd_1.clear();
 // delay(750); // Wait for 750 millisecond(s)
    lcd_1.setCursor(3, 0);
    lcd_1.print("Select Mode");
    lcd_1.print("Start");
    lcd_1.setCursor(6, 1);
    lcd_1.print("DEPRECATED");
  	if(startPressed == HIGH){
		Serial.println("Start");
    } else if (setPressed == HIGH){
      Serial.println("Settings");
    } else if (minPressed == HIGH){
      Serial.println("-");
  Serial.println(pinTemp);
  if (startPressed == HIGH) {
    startScreen();
    int temp = analogRead(pinTemp);
    lcd_1.clear();
    /*lcd_1.print("15");
    delay(1000); // Wait for 1000 millisecond(s)
    lcd_1.print("14");
    lcd_1.print("13");
    lcd_1.print("12");
    lcd_1.print("11");
    lcd_1.print("10");
    lcd_1.clear();
    lcd_1.print("9");
    lcd_1.print("8");
    lcd_1.print("7");
    lcd_1.print("6");
    lcd_1.print("5");
    lcd_1.print("4");
    lcd_1.print("3");
    lcd_1.print("2");
    lcd_1.print("1");
    lcd_1.print("Starting...");
    digitalWrite(2, HIGH);
    delay(2750); // Wait for 2750 millisecond(s)
   /*/// lcd_1.clear();
  } else if (setPressed == HIGH) {
   setScreen();
void startScreen() {
    //int heater = digital(heaterSwitch);
    //int motor = digitalRead(motorSwitch);
    lcd_1.clear();
    lcd_1.print("5");
    lcd_1.print("4");
    lcd_1.print("3");
    lcd_1.print("2");
    lcd_1.print("1");
    lcd_1.print("Heating");
    lcd_1.print("Please Wait...");
    digitalWrite(heaterSwitch, LOW);
    delay(1500); // Wait for 2750 millisecond(s)
    heatScreen1();
void setScreen() {
  lcd_1.clear();
  lcd_1.setCursor(0,0);
  lcd_1.print("The Setting option will come soon            ");
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  delay(120);
  // lcd_1.setCursor(0,1);
  //lcd_1.print("come in future updates");
  //delay(4000);
  lcd_1.clear();
  loop();
void heatScreen1() {
    sensorInput = analogRead(A0);
    temp = sensorInput / 1024;
    temp = temp * 5;
    temp = temp - 0.5;
    temp = temp * 100;
  //  digitalWrite(heaterSwitch, HIGH);
   // heatScreen();
  if (temp >= 120){
    heatScreen();
  }else {
    heatScreen1();
void heatScreen() {
    temp = temp * 5;
    temp = temp - 0.5;
    temp = temp * 100;
  lcd_1.clear();
  lcd_1.print("Starting motor in");
    lcd_1.setCursor(8, 1);
    lcd_1.print("5");
    lcd_1.print("4");
    lcd_1.print("3");
    lcd_1.print("2");
    lcd_1.print("1");
    digitalWrite(motorSwitch, LOW);
    lcd_1.clear();
    heatScreen2();
  delay(200000);
void heatScreen2() {
    temp = temp * 5;
    temp = temp - 0.5;
    temp = temp * 100;
    temp = temp + 0.15;
    lcd_1.print("Temperature is");
    lcd_1.print(temp);
    lcd_1.setCursor(5,1);
    lcd_1.print(" Degrees");
    heatScreen2();
All of the disabled lines were either earlier attempts of the button modes or disabled delays to make the simulation faster.
My advice would be it isnt going to work if you keep using delay().
Study this example
to see how to use millis()
then
Hello vickerstaff
To get started read and study the IPO model. Take piece of paper and a pencil and design a software structure first. In the next step you can start with coding and testing the software modules.
All of that is possible with just single Arduino nano. Don't forget you need a keypad to enter the parameter values. I did all that several years ago for a drying oven to dry ICs shipped from overseas. Never needed to use it.
The thing you need to factor in is the initial heating time, not just the regulation. My oven took 15 minutes for initial heat because the heating element was inside a large piece of cast iron that smoothed out the heat variations.
Also look into using a SSR to control the heat element.
That expresses recursion, which has its place but not normally seen in the very small computer world.
You are possibly calling heatScreen2() from within heatScreen2(). Very quickly that will blow up and fail.
Same thing in heatScreen2() .
I have no idea what your intent is, I am looking through a tiny window. What did you mean for this to accomplish?
a7
I was thinking that it could repeat over and over until the "if" variable was met, which would bring it to another separate function.
can you call loop() within a function?
Good catch.
Looks like recursion to me.
Yet you name the very function you are in.
And this
Is also not a good idea.
When a function returns, it goes back where it was called from.
When loop() returns, it gets called again from, well never we mind, just trust that it gets called over and over and over and over.
You never need to call loop(), doing so is almost certainly an error.
You might a function from a function and so forth, but not in anything that goes in circles, ends up effectively balling itself.
Not usually. I'd say never and be lying, the good kind of lie.
a7
UPDATE: Got the settings menu working! (kinda)
I've got new code, this time including EEPROM. Here it is:
#include <EEPROM.h>
 #define pinTemp A0
  unsigned long previousMillis = 0;
  const long interval = 1000;
  float sensorInput;
  float temp;
  int alarm = 60000;
  int failSafe = 0;
  int DHT = 120; //DHT Stands for Default Heater Temperature.
  //This was set so low becaus the temperature sensor on Tcad only goes to 125 C
  lcd_1.begin(16, 2);
  lcd_1.print("          V1.0.4");
  lcd_1.clear();
    lcd_1.print("Settings");
    startScreen();
   lcd_1.clear();
   setScreen();
  } else if (minPressed == HIGH) {
    invalidScreen();
    lcd_1.clear();
    lcd_1.print("5");
    lcd_1.print("4");
    lcd_1.print("3");
    lcd_1.print("2");
    lcd_1.print("1");
    heatScreen1();
void setScreen() {
  //int DHT = 250;
  lcd_1.print("Heater Temperature");
     DHT = DHT - 1;  // decrement DHT
    DHT = DHT + 1;  // increment DHT
  lcd_1.setCursor(3,1);
  lcd_1.print(DHT);
   EEPROM.write(0, DHT);
    lcd_1.clear();
    alarmSettings();
    setScreen();
void alarmSettings() {
   lcd_1.print("Alarm (minutes)");
  delay(500); //Delay to prevent incrementing while the settings button is pressed
     alarm = alarm - 1;  // deincrement alarm
     alarm = alarm + 1;  // increment alarm
   lcd_1.print(((alarm - 1000) / 60));
    EEPROM.write(1, alarm);
    lcd_1.clear();
    loop();
    alarmSettings();
void invalidScreen() {
  lcd_1.print("    Invalid     ");
  delay(1500);
void heatScreen() {
    temp = temp * 5;
    temp = temp - 0.5;
    temp = temp * 100;
    lcd_1.print("Heating...");
    lcd_1.print("temp");
   // heatScreen();
  if (temp >= 120){
    heatScreen1();
    heatScreen();
    lcd_1.clear();
    lcd_1.print("5");
    lcd_1.print("4");
    lcd_1.print("3");
    lcd_1.print("2");
    lcd_1.print("1");
    heatScreen2();
    temp = temp * 5;
    temp = temp - 0.5;
    temp = temp * 100;
    temp = temp + 0.15;
    lcd_1.print(temp);
    failSafe = failSafe + 1;
    if (failSafe >= alarm) {
      alarmScreen();
    }else {}
    heatScreen2();
void alarmScreen()  {
  lcd_1.clear();
  lcd_1.setCursor(2,0);
  lcd_1.print("Timer done!");
  delay(5000);
Also I added the timer!
On Tinkercad you can (apparently).
You got a stray backslash in there, edit your code right in that post!
Then it compiles.
a7
I did not notice that XD.
lol
OK, I have taken a rapid flight over your sketch and your latest codes still has the errors that have been pointed out in this thread.
Please reread it carefully.
At least:
You should never call loop() yourself.
You should not call heater2() from within heater2().
Or anything else that makes a circuit A - > B -> C -> A, uh-uh.
It will only end up badly or worse.
Please say what a user sees and you mean to present as things that would make the user press buttons for why, or how we can play with it. I didn't get anywhere just stabbing buttons.
TIA
a7
I give up. Now the simulator is so slow it's basically unusable.
Post the code that is too slow on the simulator.
You could also try a real simulator like
which, on a reasonable machine will do real time.
a7
Wow. Just wow. This simulator has SO MANY MORE devices than Tinkercad!
