Two different sketch, the same code, libraries and HW: different results...
I can’t understand the reason… the first goes, the second has problem with Wire.endTransmission();…
but, except the sketch name (and directory), the use the same thing… (also the same inclusion)
firts code:
System sys = System(LCD_ROW, LCD_COLUMN, KEYPAD_ROW, KEYPAD_COLUMN);
char key = '\0';
boolean colon = false;
uint8_t second = 0;
void setup(){
  Wire.begin();
  sys.begin();
  sock.begin();
second code
char key = '\0';
uint8_t second = 0;
void setup(){
  Wire.begin();
  sys.begin();
  sock.begin();
libraries: (Sockets creates an instance of itself alone (as Wire))
System.cpp
System::System(uint8_t lcdRow, uint8_t lcdColumn, uint8_t keypadRow, uint8_t keypadColumn){
	_lcdRow = lcdRow;
	_lcdColumn = lcdColumn;
	_keypadRow = keypadRow;
	_keypadColumn = keypadColumn;
	_backlight = false;
void System::begin(){
	// SEE PAGE 45/46 FOR INITIALIZATION SPECIFICATION!
	// according to datasheet, we need at least 40ms after power rises above 2.7V
	// before sending commands. Arduino can turn on way befer 4.5V so we'll wait 50
	delayMicroseconds(50000);
	// Now we pull both RS and R/W low to begin commands
	expanderWrite((_backlight ? LCD_BACKLIGHT : LCD_NOBACKLIGHT));	// reset expanderand turn backlight off (Bit 8 =1)
  	//put the LCD into 4 bit mode
	// this is according to the hitachi HD44780 datasheet
	// figure 24, pg 46
	// we start in 8bit mode, try to set 4 bit mode
	write4bits(0x03);
	delayMicroseconds(4500); // wait min 4.1ms
	// second try
	write4bits(0x03);
	// third go!
	write4bits(0x03);
	delayMicroseconds(150);
	// finally, set to 4-bit interface
	write4bits(0x02);
	// set # lines, font size, etc.
	send(LCD_FUNCTIONSET | LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS | LCD_2LINE);
	// turn the display on with no cursor or blinking default
	send(LCD_DISPLAYCONTROL | LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKOFF);
	// clear it off
	clearLcd();
	// Initialize to default text direction (for roman languages); set the entry mode
	send(LCD_ENTRYMODESET | LCD_ENTRYLEFT | LCD_ENTRYSHIFTDECREMENT);
	send(LCD_RETURNHOME);  // set cursor position to zero
	delayMicroseconds(2000);  // this command takes a long time!
	lcdBacklight(true);
	_currentLcdRow = _secondsWithoutInput = 0;
	refreshClock();
	_lastSecond = getSecond();
void System::send(uint8_t value, uint8_t mode) {
	write4bits((value>>4) | mode);
	write4bits((value & 0x0F) | mode);
void System::write(uint8_t value) {
	write4bits((value>>4) | Rs);
	write4bits((value & 0x0F) | Rs);
void System::write4bits(uint8_t value) {
	expanderWrite(value);
	pulseEnable(value);
void System::expanderWrite(uint8_t data){
	Wire.beginTransmission(LCD_ADDRESS);
	Wire.send((int)(data) | (_backlight ? LCD_BACKLIGHT : LCD_NOBACKLIGHT));
void System::pulseEnable(uint8_t _data){
	expanderWrite(_data | En);	// En high
	delayMicroseconds(1);		// enable pulse must be >450ns
	expanderWrite(_data & ~En);	// En low
	delayMicroseconds(50);		// commands need > 37us to settle
Sockets.cpp
Sockets::Sockets(){
	_totSocket = -1;
	_ls.day = LS_MAX_DAY;
	_ls.minutes = LS_MAX_MINUTES;
void Sockets::begin(){
	if(!isMemoryCorrect())
		formatMemory();
bool Sockets::isMemoryCorrect(){
	return eepromReadData(POSITION_STATUS_MEMORY) == CORRECT_MEMORY;
void Sockets::formatMemory(){
	eepromWriteData(POSITION_STATUS_MEMORY, CORRECT_MEMORY);
	eepromWriteData(POSITION_STATUS_MEMORY + 1, 0);// versione del programma "0"
	eepromWriteData(POSITION_STATUS_MEMORY + 2, 0);// ultimo programma usato "0"
void Sockets::eepromConnectPage(int page){
	Wire.beginTransmission((int) EEPROM_ADDRESS);
	Wire.send((byte)((page) >> 8));
	Wire.send((byte)((page) & 0xFF));
byte Sockets::eepromReadData(int page){
	eepromConnectPage(page);
	Wire.requestFrom((int) EEPROM_ADDRESS, sizeof(byte));
	return Wire.receive();
With some Serial.print I’ve established that (only) in the second sketch it’s wait the firts Wire.endTransmission();…
the first sketch, instead, works almost normally … (do not turn the light on the LCD… though, trying other sketches (which were correctly) reflected the same problem … so I think it is due to a link …)
but… for the “Wire.endTransmission();” some idea?
