I have always used NewSoftserial with VirtualWire or Easytransfer to send data from a remote control.
The remote goes to sleep after sending, and is woken by interrupt 0 being pulled low from any of the push buttons.
I now have managed to get the cheap but impressive RFM22 wireless transceiver working, ( very much monkey see monkey do approach using library examples ) but the examples in the RFM22 library also use interrupt 0.
I can't see if the interrupt in the RFM22 is used at all in transmitting ( I am only using it simplex for this project ) if not can I just ignore it?
If needed, can I put one of them on interrupt 1 ? I can't see them clashing, as the transmit function cannot happen until the wake up routine ( which disconnects the interrupt until ready for sleep ) has been and gone.
Similarly, I only put the unit back to sleep after the transmission has gone out.
Would it make any difference which I swapped to Interrupt 1 ?
OK after RTFM again, I see the library says that the interrupt is used to signal end of transmission, and that " it is very important if there is another SPI based device, to disable interrupts while transferring to from the other device. Use cli() to disable interrupts and sei() to re-enable them.
I can globally clear them, but I need them for the other device ?
