Hi I've got a strange issue on my hands here. I've got two flow meters hooked up to a Arduino MEGA R3 (digital pin 2 and 3) that are tied to two interrupts that monitors flow rate of one or the other meter.
Right now I can run water through the "IN" flow meter, and get a reading back that only the "IN" meter had any flow change.. however if I run water through the "OUT" meter, I get a reading that says both "IN" and "OUT" had a flow change.
I'm not sure why the later flow meter's causing both interrupts to get triggered, but I'm at my wits end on this one ![]()
Here is my breadboard schematic:
Here is actual schematic:
Here is my code:
#include <LiquidCrystal.h>
#define FlowPinIn 3
#define FlowPinOut 2
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
float flowInRate, flowOutRate; //float might be over kill, int might be better?
boolean irrigationFlag = false; //Flag used when done flowing to store a value on SD card
volatile unsigned long pulseInFlowCount, pulseOutFlowCount; //our actual pulse counting variables
unsigned long homeMillis; //stored timestamp
lcd.begin(16, 2); //setup LCD screen
//Setup Flow Sensor Pins
pinMode(FlowPinIn, INPUT); //"IN" flow meter
digitalWrite(FlowPinIn, HIGH);
pinMode(FlowPinOut, INPUT); //"out" flow meter
digitalWrite(FlowPinOut, HIGH);
//flow meters being hooked into flow counter methods using digitalPinToInterrupt as prescribed.
attachInterrupt(digitalPinToInterrupt(FlowPinIn), Fill, FALLING);
attachInterrupt(digitalPinToInterrupt(FlowPinOut), Drain, FALLING);
if ((millis() - homeMillis) >= 1000){
checkFlowRates(); //made into function so it can be used here or inside methods for irrigaiton
void checkFlowRates(){
//Get our rate of flow for either irrigation directions
flowInRate = (int)((1000.0 / (millis() - homeMillis)) * pulseInFlowCount) / 5.5; //5.5 is flow meter calibration found in specs
flowOutRate = (int)((1000.0 / (millis() - homeMillis)) * pulseOutFlowCount) / 5.5; //5.5 is flow meter calibration found in specs
//do we have a flow rate for in?
if (flowInRate > 0){
lcd.clear(); //for debugging, not production
lcd.print("FLOW IN"); //for debugging, not production
irrigationFlag = true; //flag irrigation is taking place
//do we have a flow rate for out?
if (flowOutRate > 0){
lcd.print("FLOW OUT"); //for debugging, not production
//did we previously have a flow rate, but now it it seems to have stopped?
if (irrigationFlag == true && flowInRate == 0 && flowOutRate == 0){
//store size to SD card once know we are done filling
irrigationFlag = false; //put flag back to false state
pulseInFlowCount = pulseOutFlowCount = 0; //reset pulse counts for next time around
//flow rate counter for in
void Fill(){
pulseInFlowCount++; //count pulses for "IN" meter
//flow rate counter for out
void Drain(){
pulseOutFlowCount++; //count pulses for "OUT" meter
Any suggestions would greatly be appreciated.
Also take note that I've separated power sources to the flow meters to ensure that current change on one was not effecting the other.
