Two functions in loop
In the sketch below I am unable to have the functions switchRead() and adjustValue() give the desired display value.
when switchRead is commented The rotary encoder increments/decrements as desired. it roll overs from 9 to 0 and 0 to 9.
and when the adjustValue() function and PORTB |= (1<<PB0) are commented out the display digits are selected individually on single, double triple and ffour taps and all displays off on hold, and all four displays on on tapandhold. the sketch is
//For ATmega328
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdio.h>
/*  Defines for encoder  and button(sw)*/
#define CLK PC0
#define DATA PC1
#define SW PC2
static uint8_t prevNextCode = 0;
static uint16_t store = 0;
static int8_t rot_enc_table[] = {0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0};
int lastButtonState = HIGH;   // the previous reading from the input pin
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
bool buttonState = HIGH; //saving state of the switch
volatile byte tapCounter; //for saving no. of times the switch is pressed
int timediff; //for saving the time in between each press and release of the switch
bool flag1, flag2; //just two variables
long double presstime, releasetime; //for saving millis at press and millis at release
/*  Defines for Seven segment display */
#define disp1 PB0
#define disp2 PB1
#define disp3 PB2
#define disp4 PB3
//volatile uint8_t digit[4];
volatile uint8_t segmentsfa[] = {0b11111100, 0b00011000, 0b01101100, 0b00111100, 0b10011000, 0b10110100, 0b11110100, 0b00011100, 0b11111100, 0b10111100};
volatile uint8_t segmentsg[] = {0b00000000, 0b00000000, 0b00100000, 0b00100000, 0b00100000, 0b00100000, 0b00100000, 0b00000000, 0b00100000, 0b00100000};
volatile int k, j, i, h, val = 0 ;
volatile int temp;
void setup()  {
  DDRC &= ~((1 << DDC2) | (1 << DDC1) | (1 << DDC0)); //Set PC0 and PC1 and PC2 as input
  PINC |= ((1 << PINC2) | (1 << PINC1) | (1 << PINC0));  // Input pullups enabled
  PORTD = 0xFF; /*  Writing all bits on port D to 0 */
  DDRD = 0xFF;  /*    Port D set as ouput */
  DDRD &= ~(1 << DDD0); //  Setting PDO as input
  PIND = (1 << PIND0);  // Enabled input pullup.
  PORTB = 0b00000000;
  DDRB = 0b11111111 ; /* define port direction for PB0 to PB5 as  output */
  noDisp();
void loop () {
  adjustValue();
  PORTB |=(1 << PB0);
  //switchRead();
int switchRead () {
  int reading = PINC & (1 << PC2);
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
  //when switch is pressed
  if (buttonState == 0 && flag2 == 0)
    presstime = millis(); //time from millis fn will save to presstime variable
    flag1 = 0;
    flag2 = 1;
    tapCounter++; //tap counter will increase by 1
  //when sw is released
  if (buttonState == 1 && flag1 == 0)
    releasetime = millis(); //time from millis fn will be saved to releasetime var
    flag1 = 1;
    flag2 = 0;
    timediff = releasetime - presstime; //here we find the time gap between press and release and stored to timediff var
  if ((millis() - presstime) > 400 && buttonState == 1) //wait for some time and if sw is in release position
    if (tapCounter == 1) //if tap counter is 1
      if (timediff >= 400) //if time diff is larger than 400 then its a hold
        //Serial.println("Hold");
        hold(); //fn to call when the button is hold
      else //if timediff is less than 400 then its a single tap
        //Serial.println("single tap");
        singleTap(); //fn to call when the button is single taped
    else if (tapCounter == 2 ) //if tapcounter is 2
      if (timediff >= 400) // if timediff is greater than  400 then its single tap and hold
        // Serial.println("single tap and hold");
        tapAndHold(); //fn to call when the button is single tap and hold
      else // if timediff is less than 400 then its just double tap
        //Serial.println("double tap");
        doubleTap(); //fn to call when doubletap
    else if (tapCounter == 3) //if tapcounter is 3 //then its triple tap
      //Serial.println("triple tap");
      tripleTap(); //fn to call when triple tap
    else if (tapCounter == 4) //if tapcounter is 4 then its 4 tap
      //Serial.println("four tap");
      fourTap();//fn to call when four tap
    tapCounter = 0;
  lastButtonState = reading;
void noDisp()
  PORTB &= ~((1 << PB0) | (1 << PB1) | (1 << PB2) | (1 << PB3));
void singleTap()
  noDisp();
  PORTB |= (1 << PB0);
void doubleTap()
  noDisp();
  PORTB |= (1 << PB1);
void tripleTap()
  noDisp();
  PORTB |= (1 << PB2);
void fourTap()
  noDisp();
  PORTB |= (1 << PB3);
void hold()
  noDisp();
void tapAndHold()
  noDisp();
  PORTB |= ((1 << PB0) | (1 << PB1) | (1 << PB2) | (1 << PB3));
  //PORTB &= ~(1 << PB1);
  //PORTB &= ~(1 << PB2);
  //PORTB &= ~(1 << PB3);
// A valid CW or CCW move returns 1, invalid returns 0
int read_rotary()  {
  prevNextCode <<= 2;
  if (PINC & (1 << DATA)) prevNextCode |= 0x02; //digitalRead the DATA pin
  if (PINC & (1 << CLK)) prevNextCode |= 0x01; //digitalRead the CLK pin
  prevNextCode &= 0x0f;
  //if valid store as 16 bit data
  if (rot_enc_table[prevNextCode])  {
    store <<= 4;
    store |= prevNextCode;
    if ((store & 0xff) == 0x2b) return -1;
    if ((store & 0xff) == 0x17) return 1;
  return 0;
int adjustValue () {
  PORTB = segmentsg[temp];
  PORTD = segmentsfa[temp];
  if (val = read_rotary())  {
    temp += val;
    if (temp >= 10) {
      temp  = 0;
    if (temp <= -1) {
      temp = 9;
How can I rewrite get these functions to get them working like a thumbwheel interface, I am not getting it. I am using Arduino Uno .
What you have is
int switchRead () {
which claims that switchRead() will return an int.
What you may need is
void switchRead () {
which claims that switchRead() returns nothing.
Of course, I may be completely wrong because no error message or good explanation has been provided.
I'd start by re-writing your code to just use the IDE built-in functions digitalRead(), digitalWrite() and pinMode() rather than all the direct port manipulation. You also have volatile variables, but no interrupt functions.
Your switchRead() function seems overly complicated - look at the StateChangeDetection example in the IDE for a simpler version (File->examples-02.Digital->stateChangeDetection)
blh64:
I have rewritten the code is put up for perusal and improvements.
/*The rotary read is from https://www.best-microcontroller-projects.com/rotary-encoder.html
and   code for shaft switchis from www.diyusthad.com  */
#define CLK A0
#define DATA A1
#define sw A2
#define digit1Sel 8
#define digit2Sel 9
#define digit3Sel 10
#define digit4Sel 11
volatile int temp, num;
void setup()  {
  pinMode(CLK, INPUT);
  pinMode(CLK, INPUT_PULLUP);
  pinMode(DATA, INPUT);
  pinMode(DATA, INPUT_PULLUP);
  pinMode(sw, INPUT_PULLUP);
  pinMode(sw, INPUT_PULLUP); //setting pin A2 as input with internal pull up resistor
  pinMode(digit1Sel, OUTPUT); digitalWrite(digit1Sel, LOW);
  pinMode(digit2Sel, OUTPUT); digitalWrite(digit2Sel, LOW);
  pinMode(digit3Sel, OUTPUT); digitalWrite(digit3Sel, LOW);
  pinMode(digit4Sel, OUTPUT); digitalWrite(digit4Sel, LOW);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  TIMSK1 = (1 << OCIE1A); /* Enable Timer1 overflow interrupts */
  TCNT1 = 0;  /* load TCNT0, count for 10ms*/
  TCCR1A &= ~((1 << WGM11) | (1 << WGM10));
  TCCR1B |= ((1 << CS12) | (1 << WGM12)); /* start timer1 with /256 prescaler in CTC Mode*/
  TCCR1B &= ~((1 << CS11) | (1 << CS10) | (1 << WGM13));
  OCR1A = 150;  // for refresh of > 80Hz per digit
  noDigit();
  sei();
void loop () {
  adjustValue();
  switchRead();
  int reading = digitalRead(sw);
    flag1 = 0;
    flag2 = 1;
    flag1 = 1;
    flag2 = 0;
        Serial.println(k);
        Serial.println(j);
        Serial.println(i);
        Serial.println(h);
        Serial.println(k);
        Serial.println(num);
        Serial.println(j);
      Serial.println (i);
      Serial.println(h);
    tapCounter = 0;
void noDigit()
  PORTB &= ~((1 << digit4Sel) | (1 << digit3Sel) | (1 << digit2Sel) | (1 << digit1Sel));
void singleTap()
  noDigit();
  adjustValue();
  segmentsEnable();
  digitalWrite(digit1Sel, HIGH);
  k = temp;
  temp = 0;
void doubleTap()
  noDigit();
  adjustValue();
  segmentsEnable();
  digitalWrite(digit2Sel, HIGH);
  j = temp;
  temp = 0;
void tripleTap()
  noDigit();
  segmentsEnable();
  digitalWrite(digit3Sel, HIGH);
  adjustValue();
  i = temp;
  temp = 0;
void fourTap()
  noDigit();
  segmentsEnable();
  digitalWrite(digit4Sel, HIGH);
  adjustValue();
  h = temp;
  temp = 0;
void hold()
  noDigit();
void tapAndHold()
  noDigit();
  segmentsEnable();
  num = k * 1000 + (j * 100) + (i * 10) + h;
int read_rotary()  {
  prevNextCode <<= 2;
  if (digitalRead(DATA)) prevNextCode |= 0x02; //digitalRead the DATA pin
  if (digitalRead(CLK)) prevNextCode |= 0x01; //digitalRead the CLK pin
    store <<= 4;
  return 0;
    temp += val;
    if (temp >= 10) {
      temp  = 0;
    if (temp <= -1) {
      temp = 9;
void segmentsEnable()  {
ISR(TIMER1_COMPA_vect)
  static byte digit = 0;
  switch (digit)
    case 0:
      PORTB = segmentsg[k];
      PORTD = segmentsfa[k];
    case 1:
      PORTB = segmentsg[j];
      PORTD = segmentsfa[j];
    case 2:
      PORTB = segmentsg[i];
      PORTD = segmentsfa[i];
    case 3:
      PORTB = segmentsg[h];
      PORTD = segmentsfa[h];
  digit++;
  if (digit > 3)
    digit = 0;
the display digit does not respond to rotary movement. But when switch is clicked once the leftmost digit comes alive and displays a value as mirrored in the serial monitor. Another twirl and double click sets the next digit. Like wise for the remaining digits.
hints for improvement are awaited.
BTW code is compiled and tested on an UNO.
