The following code uses 3 LEDs. Each LED has its timer when it should be turned on and off (turn on every 2min20sec, remain turned on for 20 sec, then turn off). These LEDs are connected to GPIO4, GPIO 2 and GPIO17. Is it possible to both let the LED on GPIO4 be controlled by the timer AND remotely from a web-server?
For example, if I turn on the LED via the web-server, the timer should not reset. It should still turn on every 2min and 20 seconds. If I turn on the LED via the web-server and then turn it off and this turning off coincidences with the 20 seconds it should be turned on - it should remain turned on. Basically, can these two be independent from each other?
#include <Arduino.h>
// Pin definitions
const int ledPin1 = 4; // GPIO 4
const int ledPin2 = 2; // GPIO 2
const int ledPin17 = 17; // GPIO 17
const byte TimeOffset = 0;
const byte WaitSwitchOnLed1 = 1;
const byte WaitSwitchOffLed1 = 2;
const byte WaitSwitchOnLed2 = 3;
const byte WaitSwitchOffLed2 = 4;
char myStateNames[][32] = {
"TimeOffset",
"WaitSwitchOnLed1",
"WaitSwitchOffLed1",
"WaitSwitchOnLed2",
"WaitSwitchOffLed2"
byte myStateVar;
unsigned long StartMillis;
unsigned long myWaitTimerVar;
//######### To be executed once to give time ########
//######### for preparation of the camera ########
Serial.println("Setup-Start");
// Initialize LED pins as output
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin17, OUTPUT);
// Code to be executed only once
// Turn off all the lights
Serial.println("LED off");
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin17, LOW);
// Mount the lights on place
Serial.println("LED On");
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin17, HIGH);
delay(180000); // 3min to do this
// Turn off the main lights,
// Blinking blue indicates it starts soon
Serial.println("Blink LED17");
for (int i = 0; i < 3; i++) {
delay(3000);
} // total 12 sec - mounting has to be finished
Serial.println("2 Blink LED17");
for (int i = 0; i < 10; i++) {
} // total 20 sec - camera has to be ready
Serial.println("3 Blink LED17");
} // total 10 sec - camera has to run after the 8th blink
// or 2-3 seconds after the last blink!
myStateVar = TimeOffset; // Go to first case (case 0)
Serial.println("Exiting Setup(), entering Loop()");
// Indicating that it enters the loop
myWaitTimerVar = millis();
//########### Time-keeping function ###########
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
//∞∞∞∞∞∞∞∞∞∞∞∞ End of Time-keeping ∞∞∞∞∞∞∞∞∞∞∞∞
//∞∞∞∞∞∞∞∞∞∞∞∞ function ∞∞∞∞∞∞∞∞∞∞∞∞
//########### Switch-Case function ###########
void myCases() {
switch (myStateVar) {
case TimeOffset:
if ( TimePeriodIsOver (myWaitTimerVar,10000) ) {
myStateVar = WaitSwitchOnLed1;
// as the next step starts immidiately
// you don't need to update myWaitTimerVar
// because updating of myWaitTimerVar
// is done INSIDE function TimePeriodIsOver automatically
case WaitSwitchOnLed1:
if ( TimePeriodIsOver (myWaitTimerVar,130000) ) {
myStateVar = WaitSwitchOffLed1;
case WaitSwitchOffLed1:
if ( TimePeriodIsOver (myWaitTimerVar,20000) ) {
myStateVar = WaitSwitchOnLed2;
case WaitSwitchOnLed2:
myStateVar = WaitSwitchOffLed2;
case WaitSwitchOffLed2:
Serial.println("one cycle finished");
void printStateIfChanged() {
static byte last_myStateVar; // must have static to stay alive over function-calls
// check if myStateVar has changed since last printing
if (last_myStateVar != myStateVar ) {
Serial.print("state changed from ");
Serial.print(myStateNames[last_myStateVar]);
Serial.print(" to ");
Serial.println(myStateNames[myStateVar]);
last_myStateVar = myStateVar; // update variable
//∞∞∞∞∞∞∞∞∞∞∞∞ End of Switch-case ∞∞∞∞∞∞∞∞∞∞∞∞
//########### The Loop ###########
printStateIfChanged();
myCases();
// last tested 13. Juli 2023
