Hello! I want to control an application using arduino that is connected to a server. I want to make it work offline too. When the server is connected, both functions are working, and when i go offline, the ManualControl works untill the first if(), if(s=="albastru"). This is a program that controls 2 LED's and you can type which one of them to be ON or OFF, or you can control Both of them in the same time. What should i do?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x11, 0x0E, 0xB9 };
byte ip[] = { 192, 168, 63, 154 };
byte server[] = { 192, 168, 63, 148 }; //connect to this server
EthernetClient client;
String c;
Ethernet.begin(mac, ip);
pinMode(8, OUTPUT); //LED 1
pinMode(9, OUTPUT); //LED 2
Serial.println(F("Connecting..."));
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
if (client.connect(server, 1111)) {
Serial.println(F("Connected"));
Serial.println(F("Hello USER"));
client.println();
else {
Serial.println(F("No Internet Connection"));
Serial.println(F("Connection failed"));
delay(1000); //Ethernet shield initialize
if (client.available())
{ ServerControl();} //Online Control
{ ManualControl(); } //Offline Control
void ServerControl()
{ c = client.readStringUntil('\r');
Serial.println(c);
if(c=="albastru") //Blue LED ON
client.println(F(" Led Albastru Pornit"));
Serial.println(F(" Led albastru pornit"));
digitalWrite(8, HIGH);
if(c=="galben") //Yellow LED ON
client.println(F(" Led Galben Pornit"));
Serial.println(F(" Led Galben Pornit"));
digitalWrite(9, HIGH);
if(c=="toate oprite") //ALL OFF
{ client.println(F(" Leduri Oprite"));
Serial.println(F(" Leduri Oprite"));
digitalWrite(8, LOW);
digitalWrite(9, LOW);
if(c=="toate pornite") //ALL ON
{ client.println(F(" Leduri Pornite"));
Serial.println(F(" Leduri Pornite"));
if(c=="albastru oprit") //BLUE OFF
client.println(F(" Led Albastru OPRIT"));
Serial.println(F(" Led Albastru OPRIT"));
if(c=="galben oprit") //YELLOW OFF
client.println(F(" Led Galben OPRIT"));
Serial.println(F(" Led Galben OPRIT"));
void ManualControl()
String s;
s = Serial.readStringUntil('\r');
Serial.println(s);
if(s=="albastru") //BLUE ON
if(s=="galben") //YELLOW ON
if(s=="toate oprite") //ALL OFF
if(s=="toate pornite") //ALL ON
if(s=="albastru oprit") //BLUE OFF
if(s=="galben oprit") //YELLOW OFF
Thank you!
