Two GPS Devices with Software Serial ports. Using TinyGPS++ Custom Fields
I am trying to capture GPS NMEA sentences from two devices connected at two different SoftwareSerial ports.
The sketch is adapted from TinyGPS++ Custom Fields for a single GPS.
It works fine if one of instances of capture is commented but does not work at all if both instances are enabled.
Could someone point to me what I shoud do to could encode from both ports , one followed by the other ?
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(2, 3); // GPS PINS RX TX
SoftwareSerial ss2(8, 9);// GPS PINS RX TX
TinyGPSCustom A(gps, "GNRMC", 3); // $GNRMC sentence, 3th element  Latitude
TinyGPSCustom B(gps, "GNRMC", 4); // $GNRMC sentence, 4th element  N /S
TinyGPSCustom C(gps, "GNRMC", 5); // $GNRMC sentence, 5th element  Longitude
TinyGPSCustom D(gps, "GNRMC", 6); // $GNRMC sentence, 6th element  W/ E
  ss.begin(9600);
  ss2.begin (9600);
  Serial.println(F("UsingCustomFields.ino"));
////////////////GPS ONE
ss.begin(9600);
ss.listen();
  while (ss.available() > 0)
    gps.encode(ss.read());
    if (A.isUpdated() || B.isUpdated() ||
    C.isUpdated() || D.isUpdated())
    Serial.print(F("A=")); Serial.print(A.value());
    Serial.print(F(" ")); Serial.println(B.value());
    Serial.print(F("C=")); Serial.print(C.value());
    Serial.print(F(" ")); Serial.println (D.value());
/////////////// GPS TWO
//ss2.begin(9600);
//ss2.listen();
//while (ss2.available() > 0)
//    gps.encode(ss2.read());
//    if (A.isUpdated() || B.isUpdated() ||
//    C.isUpdated() || D.isUpdated())
//    Serial.print(F("A1=")); Serial.print(A.value());
//    Serial.print(F(" ")); Serial.println(B.value());
//    Serial.print(F("C1=")); Serial.print(C.value());
//    Serial.print(F(" ")); Serial.println (D.value());
//    Serial.println();
Whats the application, two GPSs attached to one Arduino ?
Puzzled as to why you are using custome sentences too, TinyGPS++ does what the custom sentences do by default anyway ?
That sentences are for an example. In future my devices will generate its own sentences.
It's not practical to use two instances of SoftwareSerial because only one of them can be listening at any one time.
If you need multiple serial ports then use a Mega which has three spare HardwareSerial ports.
...R
Indeed using two instances of software serial is not a good idea, you ought to be able to make it work, but it never seems to be reliable in my experience.
In any case the logic of your code is flawed.
You turn on software serial for one GPS and before a character can arrive you check if one has (it wont have) and then move onto the next GPS.
The code runs flawlessy if only one instance is enabled. Please point where are the fault.
I do know that could not have two Soft serials running aside. My intention was close one instance before switch to another.
There are a command to "end" the "ss.begin(9600) ;" ?
You also appear to want to take characters from two different GPS and feed them into one instance of the TinyGPS++ library.
I dont see how that can work unless the outputs of the two GPSs are exactly the same at exactly the same time ?
I understand that GPS output of each GPS may be at the same time (about 1Hz each). No problem if I capture the GPS outputs interleaved. 1,2,1,2,.. at 0.5Hz each...
The sentences of my example are the same, but the main problem is how switch the input ports after each capture with TinYGPS++
You're already switching software serial instances using listen. The issue is that you need two TinyGPS objects too, as noted in reply #6.
I have tryed with two objects but still not working.
Had also ended the serial instance with ss.end(); before switch to other GPS but also not work.
The code works if any of GPS sections are commented.
TinyGPSPlus gps;
TinyGPSPlus gps2;
TinyGPSCustom E1(gps2, "GNRMC", 3); // $GNRMC sentence, 3th element  Latitude
TinyGPSCustom F1(gps2, "GNRMC", 4); // $GNRMC sentence, 4th element  N /S
TinyGPSCustom G1(gps2, "GNRMC", 5); // $GNRMC sentence, 5th element  Longitude
TinyGPSCustom H1(gps2, "GNRMC", 6); // $GNRMC sentence, 6th element  W/ E
  ss.begin(9600);
  ss2.begin (9600);
//ss.begin(9600);
ss.listen();
    ss.end();
//ss2.begin(9600);
ss2.listen();
    gps2.encode(ss2.read());
    if (E1.isUpdated() || F1.isUpdated() ||
    G1.isUpdated() || H1.isUpdated())
    Serial.print(F("A1=")); Serial.print(E1.value());
    Serial.print(F(" ")); Serial.println(F1.value());
    Serial.print(F("C1=")); Serial.print(G1.value());
    Serial.print(F(" ")); Serial.println (H1.value());
   ss2.end();
It might help to explain what you project is trying to achieve .
The project is read custom NMEA style sentences from 2 different devices. Hw may be the Uno or Nano (328p)
acjacques:
Uno or Nano is a very poor choice. Myself I would not even consider it.
It might work if you could arrange to have one GPS on the hardware serial port normally used for the Serial Monitor and program upload and the other GPS on a single software instance. But that setup would make debugging a chalenge.
A bare bones ATmega1284P would work, that has two hardware serial ports and you could run a software serial instance at tha same time, so two GPSs and the serial monitor.
It possible that if you tell the forum what the project is actually trying to do that someone will suggest a solution or workaround.
You have told us what you want the code to do, but not why you want to do it.
The problem should be not solved by changing the hardware. By this aproach I could easily add an analog swicth like CD4053 SPDT and redirect the input to wanted GPS device.
But this is not the case.
I can't understand why it is not possible in the same program to change the input pin.
Can't you close one object and start another on another input pin?
There has to be a way to do this.
There is. But you're ignoring the folks telling you how to do it.
Sorry Wildbill;
I did not see any folks solutions that not have pointed to change the HW.
You have suggested to build two objects but this also doesnt work.
There has to be a way to do this maybe even with some modification in the TinyGPS++ library
acjacques:
You can switch between pins but it could introduce what would be significant delays between reading each GPSs.
With the actual project not revealed, I guess the volunteers that provide help in this forum dont want to waste their time suggesting stuff that may innapropriate.
acjacques:
Post your code for this.
Dear wildbill;
The message #9 was my code to test two TinyGPS objects that doest work.
About the time to capture there is no problem if each GPS device was captured at half of rate. It be interleaved.
Regards
acjacques
