Two if statements = solved by alto777
Hi
I don't have a tone on the first if, on the second if I have it ?
#include <LiquidCrystal.h>
#include <Wire.h>
//LiquidCrystal_I2C lcd(0x3F, 16, 2);
LiquidCrystal_I2C lcd(0x27 , 16, 2);
float fvout = 0.0;
float fvin = 0.0;
float fVo;
int LED = (PB14, PC13);
int fvalue = 0;
int buzzer = PB5;
int (clear);
const int ResetPin = PB12;
  pinMode(ResetPin, INPUT_PULLUP);
  pinMode(PB5, OUTPUT);
  pinMode(PC13, OUTPUT);  // LED1
  pinMode(PB14, OUTPUT);  // LED2
  lcd.begin();
  lcd.backlight();
  float delta = fvin - fVo;
  if (digitalRead(ResetPin) == LOW)
    fVo = fvin;
    fvalue = analogRead(PA7);
    fvout = (fvalue * 3.3) / 4190.0; // 4200
    fvin = fvout;
  lcd.setCursor(0, 0);
  lcd.print(fvin);
  lcd.setCursor(5, 0);
  lcd.print("o");
  lcd.print(fVo, 2);
  lcd.setCursor(11, 0);
  lcd.print (delta);
  if (- 0.2 < delta)
    noTone(buzzer);             //Ok
    digitalWrite(PC13, 1);     //Ok
    tone(buzzer, 2000 );                       // not Ok
    digitalWrite(PC13, 0);      //Ok
  if ( 0.2 > delta)
    noTone(buzzer);               // Ok
    digitalWrite(PB14, 1);      //Ok
    tone(buzzer, 2000 );         // Ok
    digitalWrite(PB14, 0);       //Ok
Add the ability to Serial.print() the values being used in the "if" statements you are referring to. Then you can read the actual numbers being compared. This is the FIRST step in debugging your program.
The LEDs are working properly.
Then what is the problem?
I marked the line with "No ok "= no sound on PB5 from this line
Assuming that 1 turns on your LEDs, you are saying that the LED on PC13 is off and the LED on PB14 is off and there is no tone?
Put your finger on the logic and okay dumb computer. I don’t think the code is doing what you want, but is doing what you observe…
a7
0 turns LEDs on, they are connected to +
OK, so both LEDs are illuminated, and you get no tone.
Is that what you observe? Is that not what you want?
a7
Perhaps you meant
// TURN TONE OFF...
  noTone();
  if (- 0.2 < delta)
//    noTone(buzzer);
    tone(buzzer, 2000 );    // ... UNLESS YOU WANT THE TONE
  if ( 0.2 > delta)
//    noTone(buzzer);
HTH
a7
What's that?
THANKS it is working
"maybe software isn't for you" = you are not my boss to tell me that
If my fix was the solution to your problem, mark it so. TIA.
It is a good case for study. Besides being a bit verbose, your original take had a fatal flaw.
We see sometimes
if (x == y) {
// do the x equals y thing
else if (x != y) {
// do the x does not equal y thing
and point out, to whomever, that the second bit of logic is unnecessary, as we already have tested x against y… if it wasn't true, it must be false.
You made the opposite mistake. Just because you want to turn ON a buzzer doesn't necessarily mean you want to turn it OFF otherwise.
Also, I see you do
if (0.2 > delta)...
which of course is correct and makes sense, but it is enough backwards to normal that it alone made reading your code take 28 percent longer than if you'd stuck to convention. Just sayin.'
I know the trick of using
if (0 == n)…
which can help catch the error of using = where == was meant.
This is not very popular and sticks in the brain of a long time code reader, slowing down the process.
Since compilers can warn about such errors, writing it backwards as any kind of protection is a step in the wrong direction for readability.
Rant off.
a7
Did I ever say I was?
What on Earth would make you make such a bizarre statement?
You'll notice that the compiler didn't point out your boo-boo, because the compiler knows it isn't an error as far as it is concerned.
Edit: I see you have previous form about misunderstanding employment relationships.
Why are you picking on me? Just leave me alone, and disappear from my posts.
Oh..if only I had a pithy come-back :joy:
Without noTone the buzzer is not turning off.
FYI
How your code works first code:
truth_table
That make sense. If you don't call noTone, the buzzer will not turn off.
But you said thanks it works, what works? Post the code.
I put noTone at the top of my adjustment to your code with a huge comment, did you leave that off?
If you still have a problem, post the code.
If you fixed the problem, post the code.
a7
This one is working OK, I have sound when voltage is dropping more than delta or is increasing more than delta.
#include <Wire.h>
float fvout2 = 0.0;
float fvin2 = 0.0;
float fVo2;
int fvalue2 = 0;
int buzzer = PB5;
int (clear);
  lcd.begin();
  lcd.backlight();
  float delta2 = fvin2 - fVo2;
    fVo2 = fvin2;
    fvalue2 = analogRead(PA7);
    fvout2 = (fvalue2 * 3.3) / 4190.0; // 4200
    fvin2 = fvout2;
  lcd.print(fvin2);
  lcd.print("o");
  lcd.print(fVo2, 2);
  lcd.print (delta);
// TURN TONE OFF...
  noTone(buzzer);
  if (- 0.2 < delta2)
//    noTone(buzzer);
    digitalWrite(PC13, 1);  // green
  if ( 0.2 > delta2)
//    noTone(buzzer);
    digitalWrite(PB14, 1); // blue
    tone(buzzer, 800 );
