Two interrupt pins
Hi all,
I have been using the following interrupt on my Teensy 3.2 and it's been working perfectly:
  pinMode(pin_VSS, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(pin_VSS), SpeedPulse, RISING);
I use this to detect pulses on a particular pin to work out a speed pulse. I have now added another pulse to the picture and was hoping I could duplicate the code like this:
  pinMode(pin_RPM, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(pin_RPM), RPMPulse, RISING);
but when I use this code, I lose the signal from the original pin. Is there way to get both pins to play nicely and interrupt without stopping each other?
Thanks!
how did you define pin_VSS and pin_RPM ? (they are different, right?)
of course both ISR won't execute 'at the same time', it will be one after the other.
what are the ISR doing ? post full code
EDIT: just noted the teensy mention...
on teensy attachInterrupt() first parameter is the PIN number, I never tried to see if digitalPinToInterrupt() does the right thing
EDIT 2: just checked in source code, it does the right thing (of course !)
  #define digitalPinToInterrupt(p)  ((p) < NUM_DIGITAL_PINS ? (p) : -1)
Thanks, see full code here:
#include <AccelStepper.h>
#include <AnalogSmooth.h>
AccelStepper SPEED_STEPPER(AccelStepper::DRIVER, 5, 6); //Step, Direction
AccelStepper RPM_STEPPER(AccelStepper::DRIVER, 7, 8); //Step, Direction
AccelStepper CT_STEPPER(AccelStepper::DRIVER, 11, 12); //Step, Direction
AccelStepper FL_STEPPER(AccelStepper::DRIVER, 9, 10); //Step, Direction
const int RESET = 18; // pin for RESET
//Milli Time -----------------------------
unsigned long currentMillis = 0;
unsigned long Prev_Time_Pot = 0;      // will store last time LED was updated
unsigned long Pot_Interval = 100;          // interval at which to blink (milliseconds
unsigned long Time_Millis = 0;
unsigned long Serial_Interval = 0;
unsigned long Prev_Time_Serial = 0;
//Speed-----------------------------------------
volatile unsigned long VSS_count = 0;
unsigned long VSS_prior_count = 0;
int pin_VSS = 14;
int SPEED_MPH;
int SPEED_STEPS;
unsigned long SpeedLastMicro;
unsigned long VSS_new_count;
int Speed_Teeth = 17;
float diffRatio = 3.42;
int WheelCirc = 2126; //mm
float GearboxToothGap = (1.0 / (Speed_Teeth));
float TyreTravelled = WheelCirc / diffRatio;
unsigned long SpeedTimeCount;
unsigned long speedRaw;
int Speed_Pulses = 0;
unsigned long SpeedTime;
//RPM
volatile unsigned long RPM_count = 0;
unsigned long RPM_prior_count = 0;
int pin_RPM = 14;
int RPM;
int RPM_STEPS;
unsigned long RPMLastMicro;
unsigned long RPM_new_count;
int RPM_Teeth = 4;
unsigned long RPMTimeCount;
unsigned long RPMRaw;
int RPM_Pulses = 0;
unsigned long RPMTime;
//Coolant_T
int CT_Pin = 17;
int CT_STEPS;
int COOLANT_TEMP = 0;
//Fuel_L
int FL_Pin = 16;
int FL_STEPS;
int FUEL_LEVEL = 0;
//Pot Damper -----------------------------
float damping_coefficient = 0.01;
float Hz = 0;
int i = 1;
// Defaults to window size 10
AnalogSmooth as = AnalogSmooth();
// Window size can range from 1 - 100
AnalogSmooth as100 = AnalogSmooth(50);
AnalogSmooth as101 = AnalogSmooth(50);
//Serial
char rc;
String readString;
int StrS1;
int StrF1;
int StrS2;
int StrF2;
int StrS3;
int StrF3;
int StrS4;
int StrF4;
String Pkt1;
String Pkt2;
String Pkt3;
String Pkt4;
String inChar;
int SPEED_SEND;
int RPM_SEND;
int CT_SEND;
int FL_SEND;
  //Serial1.begin(250000);
  pinMode(RESET, OUTPUT);
  digitalWrite(RESET, LOW);
  delay(1);  // keep reset low min 1ms
  digitalWrite(RESET, HIGH);
  SPEED_STEPPER.setMaxSpeed(10000.0);
  SPEED_STEPPER.setAcceleration(50000.0);
  SPEED_STEPPER.runToNewPosition(3780);
  SPEED_STEPPER.runToNewPosition(0);
  //Speed Setup---------------------------------------------------
  GearboxToothGap = GearboxToothGap * TyreTravelled;
  //attachInterrupt(digitalPinToInterrupt(pin_RPM), RPMPulse, RISING);
  NVIC_SET_PRIORITY(IRQ_PORTA, 0);
  noInterrupts ();
  VSS_new_count = VSS_count;
  RPM_new_count = RPM_count;
  interrupts ();
  SpeedTime = micros();
  RPMTime = micros();
  //----Speed Pulse Read----------
  Speed_Pulses = VSS_new_count - VSS_prior_count;
  if (Speed_Pulses >= 10) {
    SpeedTimeCount = (SpeedTime - SpeedLastMicro) / 1000;
    speedRaw = ((VSS_new_count - VSS_prior_count) * 60 * 1000 / (GearboxToothGap * SpeedTimeCount)) / 10;
    VSS_prior_count = VSS_new_count;
    SpeedLastMicro = SpeedTime;
  //----RPM Pulse Read----------
  //  RPM_Pulses = RPM_new_count - RPM_prior_count;
  //  if (RPM_Pulses >= 4) {
  //    RPMTimeCount = (RPMTime - RPMLastMicro) / 1000;
  //    RPMRaw = 1000000 / RPMTimeCount;
  //    RPM_prior_count = RPM_new_count;
  //    RPMLastMicro = RPMTime;
  //------Get Fuel & Temp Data
  //Serial.println(SpeedTime);
  currentMillis = millis();
  Time_Millis = currentMillis - Prev_Time_Pot;
  if (Time_Millis > Pot_Interval)
    //=========READ SERIAL=========
    Get_Serial_Data();
    //=========OR READ POTS========
    //      COOLANT_TEMP = as100.analogReadSmooth(CT_Pin) / 10;
    //      //COOLANT_TEMP = 81798 / CT_Val; //Define line curve here
    //      COOLANT_TEMP = map(CT_Pin, 10, 1023, 20, 150);        // map temp
    //      FUEL_LEVEL = as101.analogReadSmooth(FL_Pin) / 10;
    //      //FUEL_LEVEL = 81798 / FL_Val; //define line curve here
    //      FUEL_LEVEL = map(FL_Pin, 10, 1023, 0, 57);        // map fuel level
    Prev_Time_Pot = currentMillis;
    Prev_Time_Serial = currentMillis;
  //=====SPEED CALC=============
  SPEED_MPH = speedRaw * 1.6;  //speed conversion
  SPEED_STEPS = map(SPEED_MPH, 0, 200, 0, 3189);
  SPEED_STEPPER.moveTo(SPEED_STEPS);
  SPEED_STEPPER.run();
  //=====RPM CALC=============
  RPM_STEPS = map(RPM, 0, 7000, 0, -2835);
  //=====CT CALC=============
  CT_STEPS = map(COOLANT_TEMP, 20, 150, 2216, 0);
  //=====FL CALC=============
  FL_STEPS = map(FUEL_LEVEL, 0, 57, -2216, 0);
  //Send Serial Data=============================
  Time_Millis = currentMillis - Prev_Time_Serial;
  if (Time_Millis > Serial_Interval)
    Send_Serial_Data();
//================================END OF LOOP=============================
//================================FUNCTIONS===============================
void SpeedPulse() {
  VSS_count = VSS_count + 1;
void RPMPulse() {
  RPM_count = RPM_count + 1;
void Get_Serial_Data() {
  //inChar = Serial1.read();
  if (Serial1.available() > 0) {
    rc = Serial1.read();
    if (rc == '>') {
      //do stuff
      //Serial.println();
      //Serial.print("captured String is : ");
      //Serial.println(readString); //prints string to serial port out
      if (readString.indexOf("S") > 0) {  //is speed in the data packet?
        StrS1 = readString.indexOf('S');  //finds start location
        StrF1 = readString.lastIndexOf('S'); //finds finish location
        Pkt1 = readString.substring(StrS1 + 1, StrF1); //captures data String
      if (readString.indexOf("R") > 0) {  //is speed in the data packet?
        StrS2 = readString.indexOf('R');  //finds start location
        StrF2 = readString.lastIndexOf('R'); //finds finish location
        Pkt2 = readString.substring(StrS2 + 1, StrF2); //captures data String
      if (readString.indexOf("T") > 0) {  //is speed in the data packet?
        StrS3 = readString.indexOf('T');  //finds start location
        StrF3 = readString.lastIndexOf('T'); //finds finish location
        Pkt3 = readString.substring(StrS3 + 1, StrF3); //captures data String
      if (readString.indexOf("F") > 0) {  //is speed in the data packet?
        StrS4 = readString.indexOf('F');  //finds start location
        StrF4 = readString.lastIndexOf('F'); //finds finish location
        Pkt4 = readString.substring(StrS4 + 1, StrF4); //captures data String
      //      Serial.print("Speed = ");
      //      Serial.println(Pkt1);
      //      Serial.print("RPM = ");
      //      Serial.println(Pkt2);
      //      Serial.print("Coolant = ");
      //      Serial.println(Pkt3);
      //      Serial.print("Fuel = ");
      //      Serial.println(Pkt4);
      //      Serial.println();
      readString = ""; //clears variable for new input
      //SPEED_MPH = Pkt1.toInt();
      RPM = Pkt2.toInt();
      COOLANT_TEMP = (Pkt3.toInt() / 10) + 40; //Adjust to tune
      FUEL_LEVEL = Pkt4.toInt();
    else {
      readString += rc; //makes the string readString
void Send_Serial_Data() {
  Serial1.print('<');
  if (SPEED_MPH != SPEED_SEND) {
    SPEED_SEND = SPEED_MPH;
    Serial1.print('S');
    Serial1.print(SPEED_SEND);
    Serial1.print('S');
  if (RPM != RPM_SEND) {
    RPM_SEND = RPM;
    Serial1.print('R');
    Serial1.print(-RPM_SEND);
    Serial1.print('R');
  if (COOLANT_TEMP != CT_SEND) {
    CT_SEND = COOLANT_TEMP;
    Serial1.print('T');
    Serial1.print(CT_SEND);
    Serial1.print('T');
  if (FUEL_LEVEL != FL_SEND) {
    FL_SEND = FUEL_LEVEL;
    Serial1.print('F');
    Serial1.print(-FL_SEND);
    Serial1.print('F');
  Serial1.print('>');
well you have int pin_VSS = 14; and int pin_RPM = 14; so you use the same pin... the second call to attachInterrupt() is attaching a new ISR to that pin 14 (overlapping the first one)
not sure what you are trying to do, if they are actually the same signal then just merge what the ISRs are doing in one ISR
const byte pin_cnt = 14;
    attachInterrupt(digitalPinToInterrupt(pin_cnt), pin14Pulse, RISING);
void pin14Pulse() {
  VSS_count++;
  RPM_count++;
B*gger. What a howler! copy paste error - works now! Thank you
sometimes we are so into our code we don't see the obvious... happens to all of us :slight_smile:
usually I declare all my pins at the top of the sketch (as const byte). this way they are all in one easy place to check and such mistakes are easy to spot
