I have made a circuit so that I can control a tactile switch which has a bi-color led inside it ( the red/green led has two legs only)
I am trying to keep the footprint small and therefore wonder if having only transistors reduce power to the led is adequate or would I need to add a current limiting resistor for each led also?
johnwasser:
Are 'arduino 1' and 'arduino 2' just two pins on the same Arduino?
Is the "-5V" really MINUS five volts? If so, why?
Why not just connect the LED directly to two data pins:
Pin2 ----- Resistor----- LED----Pin3
Then you will get one color with Pin2 HIGH and Pin3 LOW and the other color with Pin2 LOW and Pin3 HIGH.
Hello , thank you very much for your reply. : )
I would really like to use only two pins for this. wow, the footprint would be so much smaller.
My mega ardunio will be powered via a 12v regulator and there is a "+5v" reg available also. However I need to power:
12 bi colour leds tactile switches, (only 6 will be on at a time of course)
15 single colour leds. ( < these could be powered via transistors instead)
I have 2 shift registers running a dual segment display. ( from only 3 pins of course)
I was fearing that I may overheat the arduino? i presume the above would be approx 500 ma. So I thought to use transistors here to keep the arduino cool.
do you think I would be o.k with the above ? maybe i should just use transistors on the single leds instead? that would certainly help.
Do you need to individually control 6 bi-color LEDs? If you don't have 12 pins to spare you could always use more shift registers.
Did you want to control all 6 bi-color LEDs together with two pins? I think that can be done with two transistors each:
+5 ----- Resistor ---(a)--- LED ---(b)--- Resistor ----- +5
Use NPN transistors to ground point (a) for one color and point (b) for the other color. The transistors should be able to share a common data pin but may need separate base resistors.
yes i need to individually control all leds. i have just rewired my circuit so that all the bi-color leds use just 2 pins and a current limiting resistor. and all the other individual leds now have a transistor and limiting resistor each so to keep the arduino cooler.
i was really keen to use more shift registers.
i use max/msp to trigger all these leds, I use serial and standard firmata. thats the limit of my arduino knowledge. so i had to figure a way to control the seven segment displays from max msp
and still have acces to all the remaining ins and outs.
i ended up creating a sequencer in max that would fire out 1's and 0's in the correct order/time to control the shift register. very inefficeint .but it works.
i know there are arduinio sketchs that do this far far better , but there are no sketches that i could find that would allow the use of multiple shift registers and also allow max to have access to the rest of the ins and outs on the arduino all at the same time. so i had to compromise.
hope that made sense.
thanks for your help, saved me some soldering, and i can widen my traces pheeew. : )
