Two libraries wont play nice
So i have these two chunks of code which work fine independently but when i try to join them I either get stuck inside my loop or the dht22 fails to read itself.
parts i’m trying to get to work
chronodot rtc
http://docs.macetech.com/doku.php/chronodot
and dht22 humid sensor
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
chronodot code
#include <Wire.h>
#include "DHT.h"
  Wire.begin();
  // clear /EOSC bit
  // Sometimes necessary to ensure that the clock
  // keeps running on just battery power. Once set,
  // it shouldn't need to be reset but it's a good
  // idea to make sure.
  Wire.beginTransmission(0x68); // address DS3231
  Wire.write(0x0E); // select register
  Wire.write(0b00011100); // write register bitmap, bit 7 is /EOSC
  Wire.endTransmission();
  // send request to receive data starting at register 0
  Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
  Wire.write((byte)0); // start at register 0
  Wire.requestFrom(0x68, 3); // request three bytes (seconds, minutes, hours)
  while (Wire.available())
    int seconds = Wire.read(); // get seconds
    int minutes = Wire.read(); // get minutes
    int hours = Wire.read();   // get hours
    seconds = (((seconds & 0b11110000) >> 4) * 10 + (seconds & 0b00001111)); // convert BCD to decimal
    minutes = (((minutes & 0b11110000) >> 4) * 10 + (minutes & 0b00001111)); // convert BCD to decimal
    hours = (((hours & 0b00100000) >> 5) * 20 + ((hours & 0b00010000) >> 4) * 10 + (hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode)
    Serial.print(hours); Serial.print(":"); Serial.print(minutes); Serial.print(":"); Serial.println(seconds);
ATTEMPT AT BOTH
#include <Wire.h>
#include "DHT.h"
void setup(){
  Wire.begin();
  // clear /EOSC bit
dht.begin();
    return;
  Serial.print(h);
  Serial.print(t);
  Serial.print(f);
  Serial.print(hic);
  Serial.print(hif);
this last attempt at both outputs failed to read from dht sensor
How can these two chunks of code be put together in a way such that they both work? can it even happen?
The more important question, to us, is how did you try to combine them, to prove that they don't work together?
Of course "it" can be made to work, for some definitions of "it".
Welcome to the Forum. Please read the two posts at the top of this Forum by Nick Gammon on guidelines for posting here, especially the use of code tags ("</>") when posting source code files. Also, before posting the code, use Ctrl-T in the IDE to reformat the code in a standard format, which makes it easier for us to read.
Please post your effort to combine the two sketches. How else can we guess what you’re doing?
thx for replies. fixed code that was my first attempt at combing the two, i get into loop but niether works.
You're welcome. However, it appears that you did not read the replies.
dude thats not helpful! i did read them i ctrl t'd my post and i showed u how i attempted to combine them adn added code tags? ?
thats exactly how i tried to get em to work basically copy pasted them into one another. there is no error code to post.
Oh, I see… I missed that you edited the original post. Good. However, the post now refers to two chunks of code that are now invisible. We don’t need them, really, so if you just change that sentence it should be clear.
Now, what is not working? What happens when you compile and run it?
just doesn’t tell us enough.
It is that “fixed” code that you have not posted. In general, one says “I have this code and this code. I tried to combine them, like this, and…”. That’s THREE pieces of code (so 3 code windows), not two (and certainly not one).
ok ok....now that it looks as we need can we get down to some business?
spacecat: ok ok....now that it looks as we need can we get down to some business?
Sure. Just answer reply #6...
OK THIS ATTEMPT (NEW)
outputs to the serial monitor
and thats it
#include <Wire.h>
#include "DHT.h"
void setup(){
  Wire.begin();
  // clear /EOSC bit
dht.begin();
    return;
  Serial.print(h);
  Serial.print(t);
  Serial.print(f);
  Serial.print(hic);
  Serial.print(hif);
... what is the symptom of the "failure to read DHT", i.e., what are you seeing? Bad data? By "outputs", do you mean "outputs the time"?
I see you removed the 2 second wait between measurements... could that be it?
no data at all infact if i remove the return part of the failure statement it outputs this.
Failed to read from DHT sensor! Humidity: nan % Temperature: nan *C nan *F Heat index: nan *C nan *F
aarg: ... what is the symptom of the "failure to read DHT", i.e., what are you seeing? Bad data? By "outputs", do you mean "outputs the time"?
no i added it back in, no help same error
You're getting nan. Not a Number. That's possibly informative. We should have a look at the code in that dht library and see under what conditions it might return NAN. It often means you've tried to divide by zero or something illegal like that.
Serial.println(“Failed to read from DHT sensor!”);
Well yeah, that's where your code checks to see if you're getting NAN. Now let's see if we can figure out why the DHT sensor is returning NAN.
My reading of the program is that with a failed read of the DHT, you should see this:
etc.
thats what happens aarg, i cant find anything in the library or cpp that tell nme what nan means
not a number...but why!?
https://github.com/adafruit/DHT-sensor-library
spacecat: thats what happens aarg, i cant find anything in the library or cpp that tell nme what nan means
Did you try reading reply #14? I told you exactly what it means there.
